  3. Radio setup give: "check wires"
94 Posts 17 Posters 72.9k Views 3 Watching
  • m26872M
    m26872M
    m26872
    wrote on last edited by m26872
    #78
    Hm what's this? I haven't had time to test it yet, but it looks very suspicious. I'm pretty sure I ordered via MyS store on Jan 10 (soon after the Ali-links just were introduced). Is it worth the hassle to test or should I throw it straight into the garbage and order a new batch from a proven supplier (which one)?
    Bought it from here.
    axillentA slartiS 2 Replies Last reply
    • m26872M m26872
      axillentA
      axillentA
      axillent
      @m26872 this is most probably based on a Chinese clone of the nordic chip
      it could probably work
      At least nobody will charge you for the try :)
      sense and drive
      • m26872M m26872
        slartiS
        slartiS
        slarti
        @m26872 Didn't work for me. Please tell me how you do.
        "One is never alone with a rubber duck"
        axillentA 1 Reply Last reply
        • slartiS slarti
          axillentA
          axillentA
          axillent
          @slarti start from the RF24 example named GettingStarted
          connect wires according to hek's instruction http://www.mysensors.org/build/connect_radio
          sense and drive
          slartiS 1 Reply Last reply
          • axillentA axillent
            slartiS
            slartiS
            slarti
            @axillent I tried it and it worked with the modules but none of the MySensors example sketches work with them. Thread about it.
            • slartiS slarti
              axillentA
              axillentA
              axillent
              @slarti what is the output from printDetails ?
              is your chip recognized as NRF24L01+ or just NRF24L01?
              sense and drive
                slartiS
                slartiS
                slarti
                @axillent That's the funny thing, they were recognized as NRF24L01+ but still refuse to work. I don't get "check wires". I just don't get anything.
                • slartiS slarti
                  axillentA
                  axillentA
                  axillent
                  @slarti getting nothing is already something)
                  GettingStarted can be used to connect two arduinos. Have you tested this? You told that examples are working.
                  sense and drive
                    wrote on last edited by hek
                    #86
                    Might be possible to tweak initialization to get them to work. If someone has too much time on their hands this could be added as a new RFM73 driver in the development branch.
                    http://forum.mysensors.org/topic/300/rfm73-experience/14
                      slartiS
                      slartiS
                      slarti
                      @axillent Yes, the pingpong sketch from @olaeke works after I import the MySensors library to the sketch and comment out
                      //#include "nRF24L01.h" //#include "RF24.h"
                      and
                      #define MINIMAL from RF24_config.h
                      None of the "normal" examples work or give anything over serial.
                      axillentA O 2 Replies Last reply
                      • slartiS slarti
                        and
                        axillentA
                        axillentA
                        axillent
                        @slarti it is probably a limited set of configurable parameters are allowed for your chip
                        you can investigate this but no success guaranteed
                        sense and drive
                        • slartiS
                          slartiS
                          slarti
                          We'll know tomorrow or the day after as I found a Finnish guy with some radios that should be either the real thing or the SI24R1 -clone that should work.
                          • m26872M
                            m26872M
                            m26872
                            Thank you for the info. I never inteded to develop any driver so I will simply buy a new batch with more care this time.
                            • slartiS slarti
                              and
                              O
                              O
                              olaeke
                              @slarti You can test to set a static id on the sensor in the gw.begin like;
                              gw.begin(NULL, 25);
                              this sample set id fixed to 25 on this node. At least that was one of my problem with this radios, but my advice is to by new radios the cost is so smal compared to the effort. However it is the shiping that is the problem.
                              • O olaeke
                                gw.begin(NULL, 25);
                                slartiS
                                slartiS
                                slarti
                                @olaeke Thanks, made it easy to test the new radios I got today.
                                If someone in Europe needs to get radios fast, try this guy in Finland. He advertises the radios as NRF24L01, but they are in fact NRF24L01+.
                                O 1 Reply Last reply
                                • slartiS slarti
                                  O
                                  O
                                  olaeke
                                  @slarti HaHa so in China they sell NRF24L01+. and you get NRF24L01 but in Finland they sell NRF24L01 and you get NRF24L01+. :)
                                  • otolosaO
                                    otolosaO
                                    otolosa
                                    wrote on last edited by otolosa
                                    #94
                                    Hi everybpdy.....any news on this topic?
                                    my radio chips say NRF24L01+, however are detected as NRF24L01.
                                    Got 3 of em working perfectly on Uno and Nano...but on pro mini always gettin the f**n "check wires" message...the only difference is the regulator (I'm using arduino pro mini 5V), but i checked and radio is getin 3.3 as it should be.
