  3. Rfid sketch
Rfid sketch
9 Posts 3 Posters 1.8k Views 4 Watching
  • T
    The-Holgi
    can anyone help me to change the
    The relay should only put on for 3 seconds.
     * Version 1.0 - Henrik Ekblad
     * RFID Lock sensor/actuator
     * Use RFID tag to lock/unlock a door or trigger a scene on your controller.
     * This example sketch allows you to add an optional relay or solenoid
     * which can be activated/opened by RFID or controller.
     * Use the I2C wiring option for your RFID module and connect to the following Arduino pins.
     * RFID       Arduino
     * GND   ->   GND
     * VCC   ->   +5V
     * SCL   ->   A5
     * SDA   ->   A4
     * Use normal wiring for NRF24L01 radio
     * Attach a optional relay or solonoid lock to pin 4
     * http://www.mysensors.org/build/rfid
    #include <PN532_I2C.h>
    #include <PN532.h>
    // Add your valid rfid keys here. To find you your key just run sketch; hold your new RFID tag in fron ot the reader;
    // and copy the key from serial output of this sketch.
    const uint8_t maxKeyLength = 7;
    uint8_t validKeys[][maxKeyLength] = {
                        { 0xB3, 0xC6, 0xD9, 0x80, 0x00, 0x00, 0x00 },
                        { 0, 0, 0, 0, 0, 0, 0 },    // ADD YOUR KEYS HERE!
                        { 0, 0, 0, 0, 0, 0, 0 }};
    int keyCount = sizeof validKeys / maxKeyLength;
    #define CHILD_ID 99   // Id of the sensor child
    // Pin definition
    const int lockPin = 4;         // (Digital 4) The pin that activates the relay/solenoid lock.
    bool lockStatus;
    MyMessage lockMsg(CHILD_ID, V_LOCK_STATUS);
    PN532_I2C pn532i2c(Wire);
    PN532 nfc(pn532i2c);
      pinMode(lockPin, OUTPUT);
      nfc.begin();
      uint32_t versiondata = nfc.getFirmwareVersion();
      if (! versiondata) {
        Serial.print("Couldn't find PN53x board");
        while (1); // halt
      Serial.print("Found NFC chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
      Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
      Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
      // Set the max number of retry attempts to read from a card
      // This prevents us from waiting forever for a card, which is
      // the default behaviour of the PN532.
      nfc.setPassiveActivationRetries(0x3);
      // configure board to read RFID tags
      nfc.SAMConfig();
      lockStatus = loadState(0);    // Read last lock status from eeprom
      setLockState(lockStatus, true); // Now set the last known state and send it to controller
    void presentation()  {
      sendSketchInfo("RFID Lock", "1.0");
      present(CHILD_ID, S_LOCK);
      bool success;
      uint8_t key[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
      uint8_t currentKeyLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
      // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
      // 'uid' will be populated with the UID, and uidLength will indicate
      // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
      success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], &currentKeyLength);
      if (success) {
        Serial.print("Found tag id: ");
        for (uint8_t i=0; i < currentKeyLength; i++)
          if (i>0) Serial.print(",");
          Serial.print("0x");Serial.print(key[i], HEX);
        for (uint8_t i=currentKeyLength; i < maxKeyLength; i++)
          Serial.print(",0x00");
        Serial.println("");
        bool valid = false;
        // Compare this key to the valid once registered here in sketch
        for (int i=0;i<keyCount && !valid;i++) {
          for (int j=0;j<currentKeyLength && !valid;j++) {
            if (key[j] != validKeys[i][j]) {
            if (j==currentKeyLength-1) {
              valid = true;
        if (valid) {
          // Switch lock status
          setLockState(!lockStatus, true);
        // Wait for card/tag to leave reader
        while(nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], &currentKeyLength));
    // Unlocks the door.
    void setLockState(bool state, bool doSend){
      if (state)
         Serial.println("open lock");
         Serial.println("close lock");
      if (doSend)
        send(lockMsg.set(state));
      digitalWrite(lockPin, state);
      saveState(0,state);
      lockStatus = state;
      if (message.type==V_LOCK_STATUS) {
         // Change relay state
         setLockState(message.getBool(), false);
         Serial.print("Incoming lock status:");
    }l```
    • T The-Holgi
       * RFID       Arduino
       * GND   ->   GND
       * VCC   ->   +5V
       * SCL   ->   A5
       * SDA   ->   A4
      #include <PN532.h>
      // Pin definition
      bool lockStatus;
        nfc.begin();
          while (1); // halt
        nfc.SAMConfig();
        bool success;
        if (success) {
          Serial.println("");
          bool valid = false;
                valid = true;
          if (valid) {
        if (state)
        if (doSend)
        saveState(0,state);
        lockStatus = state;
      }l```
      change
        if (state)
        if (doSend)
        saveState(0,state);
        lockStatus = state;
      to
      void setLockState(bool state, bool doSend) {
        if (state)
          digitalWrite(lockPin, true);
          wait(3000);
          digitalWrite(lockPin, false);
      • T
        The-Holgi
        Thank you, it work´s perfect.
        greetings Holger
        • T
          The-Holgi
          Hm,
          now in fhem the state is not transmitted.
          rejoe2R 1 Reply Last reply
          • T The-Holgi
            Hm,
            rejoe2R
            rejoe2R
            rejoe2
            @the-holgi
            That's obvious... as now the state of the lock switches rather fast, the behaviour should be differen. I'd suggest to send both info (on/off) (on before wait(), off after) to get the events in FHEM also.
            • T
              The-Holgi
              I´ve change the code, now the state on transmitted to fhem, but state off not.
                if (state)
                  wait(5000);
                if (doSend)
              • T The-Holgi
                  if (state)
                    wait(5000);
                  if (doSend)
                @the-holgi this should work
                  if (state)
                  if (doSend)
                    send(lockMsg.set(true));
                    wait(5000);
                  if (doSend)
                    send(lockMsg.set(false));
                  if (doSend)
                • T
                  The-Holgi
                  wrote on last edited by The-Holgi
                  Thank you it works perfect.
                  Here the complete sketch:
                   * RFID       Arduino
                   * GND   ->   GND
                   * VCC   ->   +5V
                   * SCL   ->   A5
                   * SDA   ->   A4
                  #include <PN532.h>
                                      { 0x5B, 0xFC, 0x7A, 0xD, 0x00, 0x00, 0x00 },    // ADD YOUR KEYS HERE!
                                      { 0xF1, 0x13, 0x54, 0x63, 0x00, 0x00, 0x00 },
                                      { 0xCB, 0x6F, 0x2D, 0xD, 0x00, 0x00, 0x00 },
                                      { 0x9B, 0x33, 0x2C, 0xD, 0x00, 0x00, 0x00 },
                                      { 0x73, 0xFA, 0xF6, 0x1A, 0x00, 0x00, 0x00 },
                                      { 0x83, 0x59, 0x36, 0x1A, 0x00, 0x00, 0x00 },
                                      { 0x83, 0x1A, 0x3C, 0x1A, 0x00, 0x00, 0x00 },
                                      { 0xB6, 0xB2, 0x52, 0xF8, 0x00, 0x00, 0x00 },
                                      { 0x17, 0xE5, 0xD2, 0x2B, 0x00, 0x00, 0x00 },
                                      { 0x79 ,0xF7, 0x88, 0x5A, 0x00, 0x00, 0x00 },
                                      { 0x2B, 0xDC, 0x49, 0xB, 0x00, 0x00, 0x00 }};
                  // Pin definition
                  bool lockStatus;
                    nfc.begin();
                      while (1); // halt
                    nfc.SAMConfig();
                    bool success;
                    if (success) {
                      Serial.println("");
                      bool valid = false;
                            valid = true;
                      if (valid) {
                    if (state)
                    if (doSend)
                      wait(5000);
                    if (doSend)
                    if (doSend)
                  • T The-Holgi
                     * RFID       Arduino
                     * GND   ->   GND
                     * VCC   ->   +5V
                     * SCL   ->   A5
                     * SDA   ->   A4
                    #include <PN532.h>
                    // Pin definition
                    bool lockStatus;
                      nfc.begin();
                        while (1); // halt
                      nfc.SAMConfig();
                      bool success;
                      if (success) {
                        Serial.println("");
                        bool valid = false;
                              valid = true;
                        if (valid) {
                      if (state)
                      if (doSend)
                        wait(5000);
                      if (doSend)
                      if (doSend)
                    The-Holgi
                    now i´m write the sketch to another arduino with rfid and relay.
                    It doesn´t work .
                    From fhem i can trigger the relay and in serial monitor the card´s where shown with serial.
                    In fhem the lockstatus is set to off, when the card is in near of the reader, the lockstatus on doesn´t send to fhem.
                    But the relay doesn´t trigger by card.
                    Where is the mistake?
                    The problem is the lockstate doesnt set to on.
                     * RFID       Arduino
                     * GND   ->   GND
                     * VCC   ->   +5V
                     * SCL   ->   A5
                     * SDA   ->   A4
                    #include <PN532.h>
                    // Pin definition
                    bool lockStatus;
                      nfc.begin();
                        while (1); // halt
                      nfc.SAMConfig();
                      bool success;
                      if (success) {
                        Serial.println("");
                        bool valid = false;
                              valid = true;
                        if (valid) {
                      if (state)
                      if (doSend)
                        wait(5000);
                      if (doSend)
                      if (doSend)
                    Hm, with other arduino now it works.
