  3. Beginner question: How does the MQTT Gateway communicate with a RFM69 Gateway
2 Posts 2 Posters 854 Views 2 Watching
  • R
    R
    rjgmba
    Hi all, I have a real beginner question and struggling to understand how the different components work together using the info on Mysensor.org just from a concept perspective. I am trying to build an architecture where I use Home Assistant as a controller to use MQTT sensors via RFM69 radio. So I think I need a MQTT gateway, and a RFM69 Gateway, as well as sensors connected to RFM69 radio. I have seen the description of both the MQTT gateway, as well as the RFM69 Gateway:
    • MQTT Gateway: https://www.mysensors.org/build/mqtt_gateway which seems a combination of ethernet GW with MQTT client
    • RFM69 Gateway: https://www.mysensors.org/build/connect_radio which seems a serial gateway(?) with RFM69 radio (but I might be mistaken) -> how does this talk to the MQTT gateway? Does it need to be combined with an ethernet GW?
    I have seen other architectures (other websites) where the RFM gateway is combined with the MQTT gateway, which I can understand. I am struggling to see how the Controller (Home Assistant) communicates with the sensors using MQTT via RFM69 radio but I must be missing something obvious...
    • R rjgmba
      @rjgmba hi and welcome to the forum!
      https://www.mysensors.org/build/connect_radio decribes how to connect the radio for any node or gateway - it is not limited to serial.
      A gateway has 1 transport and 1 controller interface.
      The transport can be rfm69, nrf24, rs485, etc
      The controller interface can be serial, ethernet(tcp), mqtt
      So what you want is probably a gateway with rfm69 transport and mqtt controller interface.
      1. Program the gateway based on the instructions on the first link you posted. Change the code from
      #define MY_RADIO_RF24
      //#define MY_RADIO_RFM95
      to
      //#define MY_RADIO_RF24
      #define MY_RADIO_RFM69
      1. connect the radio based on the instructions on the second link.
