  3. Quick question about sketches
3 Posts 2 Posters 743 Views 2 Watching
  • HomerH
    HomerH
    Homer
    Hi everyone!
    This is a very nooby question, but I have to ask it because it's kind of got me stopped at the moment... When it comes to sketches, it doesn't matter what type of controller we are using when it comes to how the sketch looks and what libraries we use, right? The libraries that we include area purely for getting the hardware to actually work right? And it's the controller and it's plugins that determine how to use the info sent to it right? So basically if I create a sensor of some sort, I can use different libraries not mentioned here?
    I know it's a silly question, and I think I'm right, but right now it's holding me back so hoping someone can confirm our deny my conclusions. Much thanks.
    dbemowskD 1 Reply Last reply
    • HomerH Homer
      Hi everyone!
      dbemowskD
      dbemowskD
      @homer said in Quick question about sketches:
      In some cases a library may not work with a certain chip/controller, but for the most part you just have to compile the sketch for whatever chip/controller you are using and it should work.
      Yes, the libraries are written to the specifications of the particular piece of hardware and are designed to make a piece of hardware function.
      If by plugins you are referring to the board definitions, then yes. The board definitions tell the compiler the specifications of the MCU chip being programmed so it knows how to compile the code.
      Yes. You are not limited to the libraries listed here, although there can be cases where a piece of hardware has more than one available library. With that, in some cases, certain hardware may require a certain library for it to function correctly with MySensors. If you have trouble with a library, search the forums for information and if you can't find the answer to your question, post a comment in the forum.
      • HomerH
        HomerH
        Homer
        Cool, thanks for your help!
