  3. OpenHAB
  4. MQTT gateway - Openhab & Mosquitto
mqttmosquittoopenhabbroker
4 Posts 2 Posters 6.6k Views 1 Watching
  • A
    A
    alexeinz
    Hi guys, I am running 1.4 version of mqtt gateway with some sensors.
    What I found that in my case if I subscribe to MQTT gateway directly using mosquitto ( to check sensors communication ) , it will disconnect OpenHab client and will never reconnect until I restart Openhab mqtt bundle or the gateway. I wonder if there any workaround to this .. or is it maybe possible to somehow subscribe to mqtt using mosquitto and forward these under different topic to openhab ? That would make it easier instead of configuring 2 different brokers in Openhab.
    Appreciate any suggestions.....
    mqtt gw 1.4 /openhab / zwave
    • greglG
      greglG
      gregl
      set the mysensor gw to connect to mosquito, then Openhab to Mosquito
      • A
        A
        alexeinz
        Do you know what would I need to configure for this to work automatically ?
        Does mosquitto automatically re publish topics its subscribed to ?
        A 1 Reply Last reply
        • A alexeinz
          A
          A
          alexeinz
          @alexeinz figured it out, apparently had to add experimental and get latest mosquitto for the conf file to work correctly , now the bridge is working perfectly :+1:
          --- broker.conf file in /etc/mosquitto/conf.d
          the topics coming from gw will appear under sensor/# on mosquitto
          connection MMQTTtoSensor
          address 192.168.1.234 <-gw ip
          clientid MyMQTT
          cleansession true
          notifications true
          topic # in 2 sensor/ MyMQTT/
