  3. compiling issue with MYSBootloader.
6 Posts 4 Posters 3.5k Views 2 Watching
  • D
    D
    Dheeraj
    wrote on last edited by Dheeraj
    @tekka need your help here...
    not sure i'm missing something. getting following error while compiling MYSBootloader. OTABootloader working fine for me..
    Any idea what is the difference between two bootloaders.
    make: [clean] Error 1 (ignored)
    "avr-gcc" -x c -mno-interrupts -funsigned-char -funsigned-bitfields -DF_CPU=16000000L-Os -fno-inline-small-functions -fno-split-wide-types -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -Wall -mmcu=atmega328p -c -std=gnu99 -MD -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o" -I../libraries/MySensors MYSBootloader.c -o MYSBootloader.o
    In file included from MYSBootloader.c:35:0:
    MYSBootloader.h:11:18: fatal error: boot.h: No such file or directory
    #include "boot.h"
    compilation terminated.
    make: *** [MYSBootloader.o] Error 1
    hekH 1 Reply Last reply
    • D Dheeraj
      #include "boot.h"
      @Dheeraj
      You should probably ping @tekka here.
      D 1 Reply Last reply
        @Dheeraj
        D
        D
        Dheeraj
        @hek said:
        h
        ok thanks.
        tekkaT 1 Reply Last reply
        • D Dheeraj
          @hek said:
          h
          ok thanks.
          tekkaT
          tekkaT
          tekka
          wrote on last edited by tekka
          @Dheeraj try changing in MYSBootloader.h
          #include "boot.h"
          to
          #include <avr/boot.h>
          that should eliminate the reported error.
          • V
            V
            vikasjee
            wrote on last edited by vikasjee
            By any chance, can we change the CE and CSN pins from 9-10 to 7-8 in the MYSBootloader safely and easily? I tried running through the code but stopped short at MYSBootloaderHW.h file where
            #define SPI_CSN 2 // Arduino Pin 10 <-> Bit 2 of port B
            #define SPI_CE 1 // Arduino Pin 9 <-> Bit 1 of port B
            have been defined and since pins 7-8 change would mean the port change the operations may differ.
            I am using the 9-10 pins elsewhere for their PWM.
            • V vikasjee
              tekkaT
              tekkaT
              tekka
              @vikasjee Moving CSN and CE to PORTA should work - do not forget to set DDRA accordingly.
