  3. Need help for my first time
7 Posts 2 Posters 947 Views 2 Watching
  • R Offline
    R Offline
    redfirebrooks
    I finally decided to give a try to my sensors but with no luck yet.
    I have configured my sensors gateway as a MGTT on a RPI 3 on with I am running Domoticz
    I wanted to test a first sensor based on the MQ135 gaz sensor.
    I have uploaded on my Arduino nano the sketch AirQualitySensor.ino
    But it looks that the Arduino is booting every few seconds.
    Whats wrong ?
    The serial monitor logs :
    16 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
    26 TSM:INIT
    27 TSF:WUR:MS=0
    33 TSM:INIT:TSP OK
    35 TSM:FPAR
    37 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    429 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    434 TSF:MSG:FPAR OK,ID=0,D=1
    2046 TSM:FPAR:OK
    2048 TSM:ID
    2049 TSM:ID:REQ
    2052 TSF:MSG:SEND,255-255-0-0,s=1,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4059 TSM:ID
    4060 TSM:ID:REQ
    4062 TSF:MSG:SEND,255-255-0-0,s=220,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    6070 TSM:ID
    6071 TSM:ID:REQ
    6073 TSF:MSG:SEND,255-255-0-0,s=183,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    8081 TSM:ID
    8082 TSM:ID:REQ
    8084 TSF:MSG:SEND,255-255-0-0,s=146,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    10092 !TSM:ID:FAIL
    10093 TSM:FAIL:CNT=1
    10095 TSM:FAIL:DIS
    10097 TSF:TDI:TSL
    20100 TSM:FAIL:RE-INIT
    20102 TSM:INIT
    20108 TSM:INIT:TSP OK
    20110 TSM:FPAR
    20113 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22120 !TSM:FPAR:NO REPLY
    22122 TSM:FPAR
    22124 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    23088 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    23093 TSF:MSG:FPAR OK,ID=0,D=1
    24132 TSM:FPAR:OK
    24133 TSM:ID
    24135 TSM:ID:REQ
    24137 TSF:MSG:SEND,255-255-0-0,s=71,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    26145 TSM:ID
    26146 TSM:ID:REQ
    26149 TSF:MSG:SEND,255-255-0-0,s=34,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    28157 TSM:ID
    28158 TSM:ID:REQ
    28162 TSF:MSG:SEND,255-255-0-0,s=254,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    30169 TSM:ID
    30170 TSM:ID:REQ
    30173 TSF:MSG:SEND,255-255-0-0,s=218,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    32180 !TSM:ID:FAIL
    32181 TSM:FAIL:CNT=2
    32183 TSM:FAIL:DIS
    32185 TSF:TDI:TSL
    42188 TSM:FAIL:RE-INIT
    42190 TSM:INIT
    42196 TSM:INIT:TSP OK
    42199 TSM:FPAR
    42202 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    44209 !TSM:FPAR:NO REPLY
    44211 TSM:FPAR
    44213 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    46221 !TSM:FPAR:NO REPLY
    46223 TSM:FPAR
    46225 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    46716 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    46722 TSF:MSG:FPAR OK,ID=0,D=1
    48233 TSM:FPAR:OK
    48234 TSM:ID
    48235 TSM:ID:REQ
    48238 TSF:MSG:SEND,255-255-0-0,s=107,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    50246 TSM:ID
    50247 TSM:ID:REQ
    50250 TSF:MSG:SEND,255-255-0-0,s=71,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    52257 TSM:ID```
    • R redfirebrooks
      Whats wrong ?
      26 TSM:INIT
      27 TSF:WUR:MS=0
      33 TSM:INIT:TSP OK
      35 TSM:FPAR
      2046 TSM:FPAR:OK
      2048 TSM:ID
      2049 TSM:ID:REQ
      4059 TSM:ID
      4060 TSM:ID:REQ
      6070 TSM:ID
      6071 TSM:ID:REQ
      8081 TSM:ID
      8082 TSM:ID:REQ
      10092 !TSM:ID:FAIL
      10095 TSM:FAIL:DIS
      10097 TSF:TDI:TSL
      20102 TSM:INIT
      20110 TSM:FPAR
      22122 TSM:FPAR
      24132 TSM:FPAR:OK
      24133 TSM:ID
      24135 TSM:ID:REQ
      26145 TSM:ID
      26146 TSM:ID:REQ
      28157 TSM:ID
      28158 TSM:ID:REQ
      30169 TSM:ID
      30170 TSM:ID:REQ
      32180 !TSM:ID:FAIL
      32183 TSM:FAIL:DIS
      32185 TSF:TDI:TSL
      42190 TSM:INIT
      42199 TSM:FPAR
      44211 TSM:FPAR
      46223 TSM:FPAR
      48233 TSM:FPAR:OK
      48234 TSM:ID
      48235 TSM:ID:REQ
      50246 TSM:ID
      50247 TSM:ID:REQ
      52257 TSM:ID```
      Hi @redfirebrooks, welcome to the MySensors community!
      !TSM:ID:FAIL
      means that the node did not receive any id from the controller. I don't think Domoticz supports dynamic id assignment over mqtt. You'll need to assign id to your nodes manually by adding
      #define MY_NODE_ID 42
      before including MySensors.h, where 42 is the unique number (1-254) you want to give the node. More info: https://www.mysensors.org/apidocs/group__RoutingNodeSettingGrpPub.html#gac677233da7f20bbf93cb479471e3234e
      The node is not rebooting. If it was rebooting you would see MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1 over and over again.
      If you haven't already, check out https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problem and how to troubleshoot them most efficiently, including how touse the log parser to translate the logs to something that's easer to read.
      • R Offline
        R Offline
        redfirebrooks
        Thanks, looks promising
        my serial monitor gives now
        26 TSM:INIT
        27 TSF:WUR:MS=0
        33 TSM:INIT:TSP OK
        35 TSM:INIT:STATID=42
        37 TSF:SID:OK,ID=42
        39 TSM:FPAR
        75 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        91 TSF:MSG:READ,0-0-42,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        96 TSF:MSG:FPAR OK,ID=0,D=1
        2083 TSM:FPAR:OK
        2084 TSM:ID
        2085 TSM:ID:OK
        2087 TSM:UPL
        2093 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2099 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2104 TSF:MSG:PONG RECV,HP=1
        2107 TSM:UPL:OK
        2108 TSM:READY:ID=42,PAR=0,DIS=1
        2113 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2122 TSF:MSG:READ,0-0-42,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        2129 TSF:MSG:SEND,42-42-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
        2139 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        4150 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Air Quality Sensor
        4159 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
        4167 TSF:MSG:SEND,42-42-0-0,s=0,c=0,t=22,pt=0,l=0,sg=0,ft=0,st=OK:
        4173 MCO:REG:REQ
        4177 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        4184 TSF:MSG:READ,0-0-42,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        4189 MCO:PIM:NODE REG=1
        4191 MCO:BGN:STP
        29201 MCO:BGN:INIT OK,TSP=1
        LPG:0ppm    CO:0ppm    SMOKE:0ppm
        30211 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
        30216 TSF:TDI:TSL
        30218 MCO:SLP:WUP=-1
        30220 TSF:TRI:TSB
        31232 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
        31238 TSF:TDI:TSL````
        So values are always 0 so something is wrong with the sensor.
        And I can't find it in Domoticz also.
        Not so easy :(
        • R redfirebrooks
          26 TSM:INIT
          27 TSF:WUR:MS=0
          33 TSM:INIT:TSP OK
          37 TSF:SID:OK,ID=42
          39 TSM:FPAR
          2083 TSM:FPAR:OK
          2084 TSM:ID
          2085 TSM:ID:OK
          2087 TSM:UPL
          2107 TSM:UPL:OK
          4173 MCO:REG:REQ
          4191 MCO:BGN:STP
          30216 TSF:TDI:TSL
          30220 TSF:TRI:TSB
          Not so easy :(
          Nice work @redfirebrooks
          The log shows that the sensor does not send any values. Domoticz only shows sensors after they have sent their first value, so that's why the sensor does not show in Domoticz. (Why Domoticz behaves like this is a mystery to everyone.)
          I don't have experience with this sensor, but my guess would be a problem with the wiring. Could you post photos of the wiring? A second pair of eyes is often helpful to spot problems.
          • R Offline
            R Offline
            redfirebrooks
            wrote on last edited by redfirebrooks
            Not sure it will help
            Have tested the wiring with another sketch and it is good, it returns me values
              Programme de test du MQ135 permettant de mesurer la présence de polluants dans l'atmosphère (CO, CO2 Alcool, fumées...)
              Pour plus d'infos ici https://www.projetsdiy.fr/mq135-mesure-qualite-air-polluant-arduino
              Utilise la librairie mq135.cpp mise à disposition par Georg Krocker https://github.com/GeorgK/MQ135
              Projets DIY - Mars 2016 - www.projetsdiy.fr
            #include "MQ135.h"
            const int mq135Pin = 0;     // Pin sur lequel est branché de MQ135
            MQ135 gasSensor = MQ135(mq135Pin);  // Initialise l'objet MQ135 sur le Pin spécifié
                Serial.begin(9600);     // Initialise le port série à 9600 bps
                //float rzero = gasSensor.getRZero();
                //Serial.print("R0: ");
                //Serial.println(rzero);  // Valeur à reporter ligne 27 du fichier mq135.h après 48h de préchauffage
                float ppm = gasSensor.getPPM();
                Serial.print(rzero);
                Serial.print(" A0: ");
                Serial.print(analogRead(mq135Pin));
                Serial.print(" ppm CO2: ");
                Serial.println(ppm);
                delay(1000);        // Actualise la mesure chaque seconde```
            • R Offline
              R Offline
              redfirebrooks
              Ok so I managed to make it works using a specific MQ135 sketch, I thought the one in the examples folder was compatible with a MQ135...
              But, even if now I have readings, I do not see them in Domoticz.
              Something wrong on the Domoticz side ? but what ?
              26 TSM:INIT
              27 TSF:WUR:MS=0
              33 TSM:INIT:TSP OK
              35 TSF:SID:OK,ID=42
              37 TSM:FPAR
              73 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              679 TSF:MSG:READ,0-0-42,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              684 TSF:MSG:FPAR OK,ID=0,D=1
              2081 TSM:FPAR:OK
              2082 TSM:ID
              2083 TSM:ID:OK
              2085 TSM:UPL
              2088 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2095 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2100 TSF:MSG:PONG RECV,HP=1
              2103 TSM:UPL:OK
              2104 TSM:READY:ID=42,PAR=0,DIS=1
              2109 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2115 TSF:MSG:READ,0-0-42,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2123 TSF:MSG:SEND,42-42-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
              2131 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              4141 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=11,pt=0,l=16,sg=0,ft=0,st=OK:AIQ Sensor MQ135
              4150 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
              4158 TSF:MSG:SEND,42-42-0-0,s=0,c=0,t=22,pt=0,l=0,sg=0,ft=0,st=OK:
              4164 MCO:REG:REQ
              4168 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              4174 TSF:MSG:READ,0-0-42,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              4179 MCO:PIM:NODE REG=1
              4182 MCO:BGN:STP
              4184 MCO:BGN:INIT OK,TSP=1
              Val / Ro / value:19523 / 30443.00 / 0.004188 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
              4195 TSF:TDI:TSL
              4197 MCO:SLP:WUP=-1
              4199 TSF:TRI:TSB
              Val / Ro / value:22654 / 35325.00 / 0.004206 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
              4213 TSF:TDI:TSL
              4215 MCO:SLP:WUP=-1
              4217 TSF:TRI:TSB
              Val / Ro / value:29383 / 45818.00 / 1217.494228 TSF:MSG:SEND,42-42-0-0,s=0,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:1617
              4234 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
              4239 TSF:TDI:TSL
              4241 MCO:SLP:WUP=-1
              4243 TSF:TRI:TSB
              Val / Ro / value:27682 / 43165.00 / 1436.084253 TSF:MSG:SEND,42-42-0-0,s=0,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:1836
              4259 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
              4264 TSF:TDI:TSL```
              • R redfirebrooks
                26 TSM:INIT
                27 TSF:WUR:MS=0
                33 TSM:INIT:TSP OK
                35 TSF:SID:OK,ID=42
                37 TSM:FPAR
                2081 TSM:FPAR:OK
                2082 TSM:ID
                2083 TSM:ID:OK
                2085 TSM:UPL
                2103 TSM:UPL:OK
                4164 MCO:REG:REQ
                4182 MCO:BGN:STP
                4195 TSF:TDI:TSL
                4197 MCO:SLP:WUP=-1
                4199 TSF:TRI:TSB
                4213 TSF:TDI:TSL
                4215 MCO:SLP:WUP=-1
                4217 TSF:TRI:TSB
                4239 TSF:TDI:TSL
                4241 MCO:SLP:WUP=-1
                4243 TSF:TRI:TSB
                4264 TSF:TDI:TSL```
                @redfirebrooks according to the log, the node is not sending any measurement data. It just goes to sleep over and over again.
                Hard to tell why this happens without seeing the exact sketch code. Would you mind posting it?
                EDIT: Sorry, was on mobile and didn't see that the values were being sent, just not on the first two sleep periods. These lines show that the node is sending values (first the value 1617, later the value 1846).
                So it seems like the problem is that Domoticz is unable to display the information.
                What does the Hardware->Setup page looks for the MySensors gateway?
                What is shown on the "Devices" page in Domoticz?
