  3. Nano losing program code
1 Posts 1 Posters 374 Views 2 Watching
  • W
    W
    Woodside
    wrote on last edited by Woodside
    I have an irrigation system with an arduino nano (clone) driving 4 relays that control the irrigation valves. This has been working the vast majority of the time for 2 years.
    However once every few weeks, the nano loses its program code.
    The nano and relays are mounted outside in a waterproof box. They are mains powered and turned on at the same time as the water butt pump. If I initiate a valve opening within sight of the gateway (indoors) I can tell the relay node is not working as there is no initial handshake visible on the gateway leds.
    When I go to reload the program into the relay node, the red onboard led is flashing every second as if it is running the 'blink' code. There is nothing being output from the serial monitor.
    Controller: Vera 3
    MySensors Lib version: 2.3.0
     * Version 1.0 - Henrik Ekblad Relays remembered previous state at start up
     * Version 1.2 - M Young Relays reset to off at startup
     * Update latest version of software in variale 'VERSION' below
    //Set node id manually out of the range of the soil moisture sensors
    #define MY_NODE_ID 100
    //#define MY_DEBUG
    #define MY_REPEATER_FEATURE
    #define NUMBER_OF_RELAYS 4 // Total number of attached relays
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    #define VERSION "V1.3"
    void before()
        pinMode(pin, OUTPUT);
        //digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF);
        //Set relay to always be off at startup
        digitalWrite(pin, RELAY_OFF);
      Serial.println(F("Relay Actuator - "VERSION));//F means use program memory, dont copy to RAM
      sendSketchInfo("Relay Actuator", VERSION);
        present(sensor, S_BINARY);
      if (message.type==V_STATUS) {
        // Change relay state
        // Store state in eeprom
        // Write some debug info
        Serial.print(message.sensor);
    Inside Relay enclosure
    Why would the nano lose its code?
    Is there any method of diagnosing the cause?
