  3. !MCO:PRO:RC=1
!MCO:PRO:RC=1
9 Posts 3 Posters 939 Views 3 Watching
  • J
    J
    jlb
    Hello
    !MCO:PRO:RC=1 what does it mean?
    23:24:04.518 -> 710797 TSF:MSG:READ,0-0-31,s=9,c=1,t=24,pt=0,l=2,sg=0:62
    23:24:04.518 -> 710802 TSF:MSG:ECHO REQ
    23:24:04.518 -> 710806 TSF:MSG:SEND,31-31-0-0,s=9,c=1,t=24,pt=0,l=2,sg=0,ft=0,st=OK:62
    23:24:04.518 -> 710814 TSF:MSG:SEND,31-31-0-0,s=10,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
    23:24:04.518 -> 710820 !MCO:PRO:RC=1
    23:24:04.518 -> 710822 !MCO:PRO:RC=1
    23:24:04.518 -> 710824 !MCO:PRO:RC=1
    23:24:04.518 -> 710827 !MCO:PRO:RC=1
    23:24:04.518 -> 710830 TSF:MSG:READ,0-0-31,s=10,c=1,t=2,pt=2,l=2,sg=0:0
    23:24:04.518 -> 710835 TSF:MSG:ECHO
    23:24:41.714 -> 748047 TSF:MSG:SEND,31-31-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:51.6
    23:24:41.714 -> 748058 TSF:MSG:READ,0-0-31,s=0,c=1,t=0,pt=7,l=5,sg=0:51.6
    23:24:41.714 -> 748063 TSF:MSG:ECHO
    Thanks for your help
    Jean-luc
    • J jlb
      Hello
      Jean-luc
      @jlb according to https://github.com/mysensors/MySensors/blob/40f4deb18c49b1eb6b91f59e3602e9f5c56a2a1a/core/MySensorsCore.cpp#L61 a recursive call has been detected.
      My guess would be that the sketch is calling send() from within receive(), but there could be lots of other reasons. Could you post the full debug log and the full sketch?
      • J
        J
        jlb
        @mfalkvidd
        actually the sketch calls sense () from the inside of receive ()
          if (message.isAck()) {
            ack = true;   //Serial.println("This is an ack from gateway");
          else  {
            if (message.type == V_VAR1 && message.sensor == child_id_watchdog) {           // watchdog
              watchdog = message.getLong();                                                // recoit nouvelle valeur watchdog de jeedom toutes les minutes
              dateDernierChangement = millis();
              jeton=!jeton;
              send_state(10,jeton);
            if (message.type == V_STATUS && message.sensor == child_id_salle_manger) {
              etat_salle_manger = message.getBool();
              time_out_salle_manger = millis();
            if (message.type == V_STATUS && message.sensor == child_id_sejour) {
        I didn't know you shouldn't do it
        I moved it to void loop () and everything works perfectly
          else  {
              watchdog_recu=true;                // sert pour envoyer jeton a jeedom
        in the void loop()
        if (watchdog_recu == true)  {
            watchdog_recu = false;
            jeton=!jeton;
            send_state(10,jeton);   // envoi jeton à jeedom pour indiquer que la comm est ok
        thanks again for your help so fast
        I wish you a happy new year from Aix en Provence (France)
        Jean-luc
        • J jlb
          @mfalkvidd
            else  {
                jeton=!jeton;
            else  {
          in the void loop()
              jeton=!jeton;
          Jean-luc
          Great work @jlb, thanks for reporting back.
          Not being able to call send() from within receive() is something that trips up a lot of people. I'd like to find a good way to fix it, but I don't know any good way unfortunately. Adding the MCO:PRO:RC message made it a bit easier to see when the problem happens, but it would be even better if there was a way that made it easier to not make the mistake at all. You are very welcome to share ideas if you have any.
          Happy new year to you as well!
          • R
            R
            Radi-M
            Hi all,
            I've got the same message when call wait(xx);
            while (CurrentLevel[SensorID] != toLevel) {
            	CurrentLevel[SensorID] += delta;
            	analogWrite(SensorPIN, (int)(CurrentLevel[SensorID] / 100. * 255));
            //    delay(FADE_DELAY);
            	wait(FADE_DELAY);
            23902 TSF:MSG:READ,0-0-1,s=0,c=1,t=3,pt=0,l=1,sg=0:5
            23907 !MCO:PRO:RC=1
            23909 !MCO:PRO:RC=1
            23911 !MCO:PRO:RC=1
            23913 !MCO:PRO:RC=1
            23915 !MCO:PRO:RC=1
            23916 !MCO:PRO:RC=1
            23918 !MCO:PRO:RC=1
            23920 !MCO:PRO:RC=1
            23922 !MCO:PRO:RC=1
            23924 !MCO:PRO:RC=1
            23926 !MCO:PRO:RC=1
            23928 !MCO:PRO:RC=1
            23930 !MCO:PRO:RC=1
            23931 !MCO:PRO:RC=1
            23933 !MCO:PRO:RC=1
            23936 !MCO:PRO:RC=1
            23938 !MCO:PRO:RC=1
            23940 !MCO:PRO:RC=1
            23942 !MCO:PRO:RC=1
            23944 !MCO:PRO:RC=1
            23946 !MCO:PRO:RC=1
            23948 !MCO:PRO:RC=1
            23949 !MCO:PRO:RC=1
            23951 !MCO:PRO:RC=1
            23953 !MCO:PRO:RC=1
            23955 !MCO:PRO:RC=1
            23957 !MCO:PRO:RC=1
            When I replace wait with delay the message doesn't appear.
            Why is that?
            Regards,
            Radi
            • R Radi-M
              Hi all,
              	wait(FADE_DELAY);
              23907 !MCO:PRO:RC=1
              23909 !MCO:PRO:RC=1
              23911 !MCO:PRO:RC=1
              23913 !MCO:PRO:RC=1
              23915 !MCO:PRO:RC=1
              23916 !MCO:PRO:RC=1
              23918 !MCO:PRO:RC=1
              23920 !MCO:PRO:RC=1
              23922 !MCO:PRO:RC=1
              23924 !MCO:PRO:RC=1
              23926 !MCO:PRO:RC=1
              23928 !MCO:PRO:RC=1
              23930 !MCO:PRO:RC=1
              23931 !MCO:PRO:RC=1
              23933 !MCO:PRO:RC=1
              23936 !MCO:PRO:RC=1
              23938 !MCO:PRO:RC=1
              23940 !MCO:PRO:RC=1
              23942 !MCO:PRO:RC=1
              23944 !MCO:PRO:RC=1
              23946 !MCO:PRO:RC=1
              23948 !MCO:PRO:RC=1
              23949 !MCO:PRO:RC=1
              23951 !MCO:PRO:RC=1
              23953 !MCO:PRO:RC=1
              23955 !MCO:PRO:RC=1
              23957 !MCO:PRO:RC=1
              Why is that?
              Regards,
              Radi
              Welcome to the forum @Radi-M
              delay() will block processing of any incoming messages. My guess is that the sketch has a call to send() within receive(). By blocking, the recursive call is avoided.
              If you post the entire sketch it would be possible to give a definitive answer.
              • R
                R
                Radi-M
                Hi mfalkvidd,
                Thank you for the prompt response.
                The code is the following:
                //#define MY_DEBUG
                #define MY_RX_MESSAGE_BUFFER_FEATURE
                #define MY_RF24_IRQ_PIN 2
                #include <Bounce2.h>
                #include <elapsedMillis.h>
                #define SN "Stairs Wall Lights"
                #define SV "1.2"
                #define TopLED_ID 0
                #define BottomLED_ID 1
                #define TopSwitch_ID 2
                #define BottomSwitch_ID 3
                #define TopSwitchLev_ID 4
                #define BotSwitchLev_ID 5
                #define TopLED_PIN 3
                #define BottomLED_PIN 5
                #define TopSwitch_PIN A3  // External switch 1
                #define BottomSwitch_PIN A4  // External switch 2
                #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                #define Light_On 100
                #define Light_Off 0
                #define HEARTBEAT_TIME 605000 // 10 minutes
                #define HEARTBEAT_NO_RETURN 3
                uint8_t CurrentLevel[2];  // Current dim level...
                bool LastState[2];
                byte updateSensor;
                MyMessage TopDimmerMsg(TopLED_ID, V_DIMMER);
                MyMessage TopLightMsg(TopLED_ID, V_LIGHT);
                MyMessage BotDimmerMsg(BottomLED_ID, V_DIMMER);
                MyMessage BotLightMsg(BottomLED_ID, V_LIGHT);
                MyMessage TopSwitchMsg(TopSwitch_ID, V_STATUS);
                MyMessage BotSwitchMsg(BottomSwitch_ID, V_STATUS);
                MyMessage TopSwitchLevMsg(TopSwitchLev_ID, V_VAR1);
                MyMessage BotSwitchLevMsg(BotSwitchLev_ID, V_VAR1);
                elapsedMillis heartBeatTimer;
                byte heartBeatReturn;
                Bounce debouncer1 = Bounce();
                Bounce debouncer2 = Bounce();
                void(* resetFunc) (void) = 0; //declare reset function @ address 0
                #ifdef MY_DEBUG
                  Serial.begin(115200);
                  Serial.println("Setup Started.");
                  pinMode(TopSwitch_PIN, INPUT_PULLUP);
                  pinMode(BottomSwitch_PIN, INPUT_PULLUP);
                  LastState[TopLED_ID] = digitalRead(TopSwitch_PIN);
                  LastState[BottomLED_ID] =  digitalRead(BottomSwitch_PIN);
                  // switch off lights
                  analogWrite(TopLED_PIN, 0); CurrentLevel[TopLED_ID] = 0;
                  analogWrite(BottomLED_PIN, 0); CurrentLevel[BottomLED_ID] = 0;
                  send(TopSwitchMsg.set(LastState[TopLED_ID])); wait(100);
                  send(BotSwitchMsg.set(LastState[BottomLED_ID])); wait(100);
                  byte b = loadState(TopSwitchLev_ID);
                #ifdef MY_DEBUG
                  Serial.print("Top Switch level: ");
                  Serial.println(b);
                  if (b == Light_Off) {b = Light_On; saveState(TopSwitchLev_ID, Light_On);}
                  send(TopSwitchLevMsg.set(b)); wait(100);
                  b = loadState(BotSwitchLev_ID);
                #ifdef MY_DEBUG
                  Serial.print("Bottom Switch level: ");
                  Serial.println(b);
                  if (b == Light_Off) {b = Light_On; saveState(BotSwitchLev_ID, b);}
                  send(BotSwitchLevMsg.set(b)); wait(100);
                  debouncer1.attach(TopSwitch_PIN);
                  debouncer1.interval(5);
                  debouncer2.attach(BottomSwitch_PIN);
                  debouncer2.interval(5);
                  heartBeatTimer = 0;
                  heartBeatReturn = 0;
                  updateSensor = 255;
                  request(TopLED_ID, V_DIMMER); wait(100);
                  request(BottomLED_ID, V_DIMMER); wait(100);
                #ifdef MY_DEBUG
                  Serial.println("Setup Colplete.");
                  sendSketchInfo(SN, SV);
                  present(TopLED_ID, S_DIMMER, "Top_Lights"); wait(100);
                  present(BottomLED_ID, S_DIMMER, "Bottom_Lights"); wait(100);
                  present(TopSwitch_ID, S_BINARY, "Top_Lights_Switch");  wait(100);
                  present(BottomSwitch_ID, S_BINARY, "Bottom_Lights_Switch");  wait(100);
                  present(TopSwitchLev_ID, S_CUSTOM, "Top_Lights_Switch_Level");  wait(100);
                  present(BotSwitchLev_ID, S_CUSTOM, "Bottom_Lights_Switch_Level");  wait(100);
                  debouncer1.update();
                  bool CurrentState = debouncer1.read();
                  if (CurrentState != LastState[TopLED_ID]) {
                    #ifdef MY_DEBUG
                      Serial.println("Switch 1 pressed.");
                    send(TopSwitchMsg.set(CurrentState));
                    LastState[TopLED_ID] = CurrentState;
                    if (CurrentLevel[TopLED_ID] > Light_Off) {
                      fadeToLevel(Light_Off, TopLED_ID);
                    else {
                      fadeToLevel(b, TopLED_ID);
                  debouncer2.update();
                  CurrentState = debouncer2.read();
                  if (CurrentState != LastState[BottomLED_ID]) {
                    #ifdef MY_DEBUG
                      Serial.println("Switch 2 pressed.");
                    send(BotSwitchMsg.set(CurrentState));
                    LastState[BottomLED_ID] = CurrentState;
                    if (CurrentLevel[BottomLED_ID] > 0) {
                      fadeToLevel(Light_Off, BottomLED_ID);
                    else {
                      byte b = loadState(BotSwitchLev_ID);
                      fadeToLevel(b, BottomLED_ID);
                  if (heartBeatTimer > HEARTBEAT_TIME) {
                    heartBeatTimer = 0;
                    if (!sendHeartbeat()) {
                        #ifdef MY_DEBUG
                          Serial.println("Hearbeat echo NOT received.");
                      heartBeatReturn++;
                      if (heartBeatReturn == HEARTBEAT_NO_RETURN) resetFunc();
                    } else {
                        #ifdef MY_DEBUG
                          Serial.println("Hearbeat echo received.");
                        request(TopLED_ID, V_DIMMER); wait(200);
                        request(BottomLED_ID, V_DIMMER); wait(200);
                  if (updateSensor != 255) {
                    #ifdef MY_DEBUG
                      Serial.print("Sensor Update received: ");
                      Serial.println(updateSensor);
                    if (updateSensor == TopLED_ID) {
                      send(TopLightMsg.set(CurrentLevel[updateSensor] > 0));wait(100);
                      send(TopDimmerMsg.set(CurrentLevel[updateSensor]));
                    else if (updateSensor == BottomLED_ID){
                      send(BotLightMsg.set(CurrentLevel[updateSensor] > 0));wait(100);
                      send(BotDimmerMsg.set(CurrentLevel[updateSensor]));
                    updateSensor = 255;
                    bool requestedLevel = message.getBool();
                    #ifdef MY_DEBUG
                      Serial.print("V_Light received: ");
                      Serial.println(message.sensor);
                    int lvl;
                    if (requestedLevel == LOW) lvl = Light_Off; else lvl = Light_On;
                		fadeToLevel(lvl, message.sensor);
                  else if (message.type == V_DIMMER) {
                    #ifdef MY_DEBUG
                      Serial.print("V_Dimmer received: ");
                    int requestedLevel = message.getInt();
                    fadeToLevel(requestedLevel, message.sensor);
                  else if (message.type == V_VAR1) {
                    #ifdef MY_DEBUG
                      Serial.print("V_VAR1 received: ");
                    byte b = message.getByte();
                    if (b > Light_On) b = Light_On;
                    if (message.sensor == TopSwitchLev_ID) {
                      saveState(TopSwitchLev_ID, b);
                    else if (message.sensor == BotSwitchLev_ID) {
                void fadeToLevel(int toLevel, byte SensorID)
                  #ifdef MY_DEBUG
                    Serial.print("Fade to Level: ");
                    Serial.print(SensorID);
                    Serial.print(":");
                    Serial.print(CurrentLevel[SensorID]);
                    Serial.print("-->");
                    Serial.println(toLevel);
                  byte SensorPIN;
                  if (SensorID == TopLED_ID) SensorPIN = TopLED_PIN;
                  else if (SensorID == BottomLED_ID) SensorPIN = BottomLED_PIN;
                  int delta = (toLevel - CurrentLevel[SensorID]) < 0 ? -1 : 1;
                  if (CurrentLevel[SensorID] != toLevel) {
                    updateSensor = SensorID;
                      wait(FADE_DELAY);
                There is no send() inside receive().
                Any ideas?
                • R Radi-M
                  Hi mfalkvidd,
                  //#define MY_DEBUG
                  #define SV "1.2"
                  #define TopLED_ID 0
                  #define Light_Off 0
                  bool LastState[2];
                  byte updateSensor;
                  #ifdef MY_DEBUG
                  #ifdef MY_DEBUG
                    Serial.println(b);
                  #ifdef MY_DEBUG
                    Serial.println(b);
                    heartBeatTimer = 0;
                    updateSensor = 255;
                  #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      else {
                      #ifdef MY_DEBUG
                      else {
                      heartBeatTimer = 0;
                          #ifdef MY_DEBUG
                        heartBeatReturn++;
                      } else {
                          #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      updateSensor = 255;
                      #ifdef MY_DEBUG
                      int lvl;
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                    #ifdef MY_DEBUG
                      Serial.print(":");
                    byte SensorPIN;
                        wait(FADE_DELAY);
                  Any ideas?
                  Thanks for sharing the sketch @Radi-M
                  My guess would be that the node receives new messages while it is still fading. If you enable MY_DEBUG your excellent debug prints will give more of informaion on whating.
                  • R
                    R
                    Radi-M
                    The strange behavior is no longer present and I can't replicate the problem. I suspect there was a general communication problem with the gateway.
                    Anyway, please see the following debug prints.
                     __  __       ____
                            |___/                      2.3.2
                    16 MCO:BGN:INIT NODE,CP=RNNNA-Q-,FQ=16,REL=255,VER=2.3.2
                    26 TSM:INIT
                    28 TSF:WUR:MS=0
                    34 TSM:INIT:TSP OK
                    36 TSF:SID:OK,ID=1
                    38 TSM:FPAR
                    41 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    247 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    252 TSF:MSG:FPAR OK,ID=0,D=1
                    2050 TSM:FPAR:OK
                    2051 TSM:ID
                    2052 TSM:ID:OK
                    2054 TSM:UPL
                    2057 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    2068 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    2073 TSF:MSG:PONG RECV,HP=1
                    2075 TSM:UPL:OK
                    2077 TSM:READY:ID=1,PAR=0,DIS=1
                    2081 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    2100 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    2110 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
                    2118 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    2179 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    2186 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Stairs Wall Lights
                    2198 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                    2209 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=4,pt=0,l=10,sg=0,ft=0,st=OK:Top_Lights
                    2318 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=4,pt=0,l=13,sg=0,ft=0,st=OK:Bottom_Lights
                    2427 TSF:MSG:SEND,1-1-0-0,s=2,c=0,t=3,pt=0,l=17,sg=0,ft=0,st=OK:Top_Lights_Switch
                    2537 TSF:MSG:SEND,1-1-0-0,s=3,c=0,t=3,pt=0,l=20,sg=0,ft=0,st=OK:Bottom_Lights_Switch
                    2648 TSF:MSG:SEND,1-1-0-0,s=4,c=0,t=23,pt=0,l=23,sg=0,ft=0,st=OK:Top_Lights_Switch_Level
                    2758 TSF:MSG:SEND,1-1-0-0,s=5,c=0,t=23,pt=0,l=25,sg=0,ft=0,st=OK:Bottom_Lights_Switch_Leve
                    2866 MCO:REG:REQ
                    2871 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    2877 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    2882 MCO:PIM:NODE REG=1
                    2884 MCO:BGN:STP
                    Setup Started.
                    2888 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                    2995 TSF:MSG:SEND,1-1-0-0,s=3,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                    Top Switch level: 100
                    3103 TSF:MSG:SEND,1-1-0-0,s=4,c=1,t=24,pt=1,l=1,sg=0,ft=0,st=OK:100
                    Bottom Switch level: 100
                    3211 TSF:MSG:SEND,1-1-0-0,s=5,c=1,t=24,pt=1,l=1,sg=0,ft=0,st=OK:100
                    3318 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    3364 TSF:MSG:READ,0-0-1,s=0,c=1,t=3,pt=0,l=1,sg=0:0
                    V_Dimmer received: 0
                    Fade to Level: 0:0-->0
                    3425 TSF:MSG:SEND,1-1-0-0,s=1,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    3469 TSF:MSG:READ,0-0-1,s=1,c=1,t=3,pt=0,l=1,sg=0:0
                    V_Dimmer received: 1
                    Fade to Level: 1:0-->0
                    Setup Colplete.
                    3531 MCO:BGN:INIT OK,TSP=1
                    Switch 1 pressed.
                    11350 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
                    Fade to Level: 0:0-->100
                    Sensor Update received: 0
                    12360 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
                    12466 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=3,pt=1,l=1,sg=0,ft=0,st=OK:100
                    Switch 1 pressed.
                    14713 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                    Fade to Level: 0:100-->0
                    15726 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                    15832 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=3,pt=1,l=1,sg=0,ft=0,st=OK:0
