  3. RFM gateway and sensors node with range issue
14 Posts 6 Posters 1.4k Views 4 Watching
  • W
    W
    wiredfrank
    Hi all,
    First of all thank you for such great work. i been reading a lot on forum lately for different type of ideas and making my wireless communication work better or should i say reliably and today i plunge to register account and dear to ask question that might be very stupid or basic for all the black belt on this forum. so please go easy on me.
    i have been testing nrf radio with esp8266 (gateway) and battery powered nodes but i can not get them to work through the solid walls so i decided to give try to RFM 433mhz radio but again failure.
    so i m thinking i must be doing something wrong here, i watched tons of video on youtube about lora radio where people have achieved range in kilometres :thinking_face: but i can not get range on these radio more than 20 meters, in example folder all examples are based on nrf radio. so if you can please guide me what i m doing wrong here or i m using wrong radio or wrong radio antenna. is there any sketch for gateway and for node to do some testing? also i have added 10uf and 100nf radio
    Gateway esp8266 with RFM69HCW https://www.aliexpress.com/item/32878809891.html
    Gateway Antena:
    https://www.aliexpress.com/item/32806809309.html
    https://www.aliexpress.com/item/32958576484.html
    https://www.aliexpress.com/item/33036097576.html
    Node with RFM69CW https://www.aliexpress.com/item/32887379895.html
    Node Antena :
    https://www.aliexpress.com/item/32970025687.html
    https://www.aliexpress.com/item/32511929185.html
    Gateway Sketch
    #define MY_BAUD_RATE 9600
    #ifdef ESP8266
    // For RFM69
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RFM69_433MHZ // Set your frequency here
    #define MY_IS_RFM69HW // Omit if your RFM is not "H"
    #define MY_RFM69_IRQ_PIN D1
    #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN
    #define MY_RFM69_CS_PIN D8 // NSS. Use MY_RFM69_SPI_CS for older versions (before 2.2.0)
    // For RFM95
    #define MY_RADIO_RFM95
    #define MY_RFM95_IRQ_PIN D1
    #define MY_RFM95_IRQ_NUM MY_RFM95_IRQ_PIN
    #define MY_RFM95_CS_PIN D8
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "MySSID"
    #define MY_WIFI_PASSWORD "MyVerySecretPassword"
    #define MY_HOSTNAME "ESP8266_GW"
    #define MY_PORT 5003
    Sketch for Temperature Sensor node
    #define MY_RFM69_NEW_DRIVER
    #include <OneWire.h>
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
    void presentation() {
      sendSketchInfo("Temperature Sensor", "1");
         present(i, S_TEMP);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
      sleep(SLEEP_TIME);
    • W wiredfrank
      Hi all,
      Gateway Antena:
      Node Antena :
      Gateway Sketch
      #ifdef ESP8266
      // For RFM69
      // For RFM95
      int numSensors=0;
      bool metric = true;
      void before()
        sensors.begin();
           present(i, S_TEMP);
          #else
        sleep(SLEEP_TIME);
      Welcome to the MySensors community @wiredfrank
      The gateway configuration says that you have a rfm69 and a rfm95 radio connected. Is that really the case?
      The node is co figured to use a rfm69 with the new driver. The new driver is not compatible with the default driver, so the node should not be able to communicate with the gateway at all.
      Note: rfm95 is a LoRa radio, while rfm69 is not.
      What do the debug log on the gateway and on the node say?
      • W
        W
        wiredfrank
        @mfalkvidd thank you for quick reply, that was my copy/paste as my code is mess and i tried to paste as clean as i could hence this mistake, but i m using RFM69 radio. if rfm69 isnt lora radio then it mean range isn't going to be more then 15 to 20metter ? :cry: may be this is the problem? should i switch to rfm 95 for longer range? (i feel stupid now)
        Gateway powered on and this is on serial output
        MCO:BGN:INIT GW,CP=RPNGE---,REL=255,VER=2.3.1
        109 TSF:LRT:OK
        125 TSM:INIT
        139 TSF:WUR:MS=0
        157 TSM:INIT:TSP OK
        scandone
        state: 0 -> 2 (b0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 7
        cnt
        connected with wifinet, channel 7
        dhcp client start...
        ip:192.168.1.5,mask:255.255.255.0,gw:192.168.1.1
        372 TSM:INIT:GW MODE
        394 TSM:READY:ID=0,PAR=0,DIS=0
        427 MCO:REG:NOT NEEDED
        451 MCO:BGN:STP
        545 MCO:BGN:INIT OK,TSP=1
        629 TSM:READY:NWD REQ
        1156 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        sensors powered on and on gateway
        96189 TSF:MSG:READ,30-30-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        96250 TSF:MSG:BC
        96268 TSF:MSG:FPAR REQ,ID=30
        96298 TSF:PNG:SEND,TO=0
        96323 TSF:CKU:OK
        96341 TSF:MSG:GWL OK
        96980 TSF:MSG:SEND,0-0-30-30,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        98261 TSF:MSG:READ,30-30-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        98322 TSF:MSG:PINGED,ID=30,HP=1
        99128 TSF:MSG:SEND,0-0-30-30,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        99256 TSF:MSG:READ,30-30-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        100031 TSF:MSG:SEND,0-0-30-30,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        100662 TSF:MSG:READ,30-30-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.1
        101229 TSF:MSG:READ,30-30-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
        103299 TSF:MSG:READ,30-30-0,s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Sensor
        103867 TSF:MSG:READ,30-30-0,s=255,c=3,t=12,pt=0,l=4,sg=0:0.01
        105334 TSF:MSG:READ,30-30-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
        106400 TSF:MSG:READ,30-30-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
        107440 TSF:MSG:SEND,0-0-30-30,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
        108074 TSF:MSG:READ,30-30-0,s=1,c=1,t=38,pt=7,l=5,sg=0:5.80
        108643 TSF:MSG:READ,30-30-0,s=255,c=3,t=0,pt=1,l=1,sg=0:164
        109530 TSF:MSG:READ,30-30-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.0
        165820 TSF:MSG:READ,30-30-0,s=1,c=1,t=38,pt=7,l=5,sg=0:4.72
        166505 TSF:MSG:READ,30-30-0,s=255,c=3,t=0,pt=1,l=1,sg=0:110
        167395 TSF:MSG:READ,30-30-0,s=0,c=1,t=0,pt=7,l=5,sg=0:20.8
        • S
          Sasquatch
          wrote on last edited by Sasquatch
          Your node sketch is configured as HW model but you said you're using standard radio on it
          comment out line below
          in sketch running radio without 6 legged chip next to ant pin
          Been there done that, but I was getting 10 cm range on coil type aerials ;)
          • W
            W
            wiredfrank
            i tried both radio types but can not get range more than 20m max in open air, tried coil type antenna, and all sorts things including capacitor from 10uf to 100uf, i m sure there is something missing in my setup i just dont know what it is, even nrf with pcb antenna perform better in open air, i wonder if any one even using rfm69 at all or it just me banging my head around.
            S 1 Reply Last reply
            • electrikE
              electrikE
              electrik
              Like @mfalkvidd said, if you use the new driver, you have to use it on all of the nodes and the gateway, as it doesn't work together with the old one.
              You said your code is a mess, maybe it is better to step back and use examples for both the node and the gateway and start from there. If that is working you can add your code. Just to exclude something is overlooked.
              • W wiredfrank
                Sasquatch
                @wiredfrank roll back to old driver, use 17cm(433Mhz)/8.5cm(868 MHz) piece of straight wire as antenna.
                Solder extra 100-470uf capacitor directly to supply pins of the radios too, especially HW versions. Transient current spikes can cause all sorts of problems.
                I'm using rfm69 mixed HW and non HW versions , and 500m meters is easily achieved, even on spider dupont wire connections and 2.4v supply(2x nimh aa cells).
                also, don't rely on controller for connection tests, use debug serial output on both ends to confirm link.
                • W
                  W
                  wiredfrank
                  Thank you for suggestion, is there any sketch for ping pong type communicate to do some testing?
                  scalzS 1 Reply Last reply
                  • W wiredfrank
                    scalzS
                    scalzS
                    wrote on last edited by scalz
                    @wiredfrank
                    in your gw sketch, your defines should be like this:
                    and there is the RFM69_RFM95_ATC_SignalReport.ino sketch for your node, in mysensors examples
                     * Version 1.0 - tekka
                     * ATC mode settings and signal report functions, on RFM69 and RFM95 nodes
                    // Enable debug prints
                    // RFM69
                    #define MY_RFM69_NEW_DRIVER   // ATC on RFM69 works only with the new driver (not compatible with old=default driver)
                    //#define MY_RFM69_ATC_TARGET_RSSI_DBM (-70)  // target RSSI -70dBm
                    //#define MY_RFM69_MAX_POWER_LEVEL_DBM (10)   // max. TX power 10dBm = 10mW
                    // RFM95
                    //#define MY_RADIO_RFM95
                    //#define MY_RFM95_ATC_TARGET_RSSI_DBM (-70)  // target RSSI -70dBm
                    //#define MY_RFM95_MAX_POWER_LEVEL_DBM (10)   // max. TX power 10dBm = 10mW
                    // ID of the sensor child
                    #define CHILD_ID_UPLINK_QUALITY (0)
                    #define CHILD_ID_TX_LEVEL       (1)
                    #define CHILD_ID_TX_PERCENT     (2)
                    #define CHILD_ID_TX_RSSI        (3)
                    #define CHILD_ID_RX_RSSI        (4)
                    #define CHILD_ID_TX_SNR         (5)
                    #define CHILD_ID_RX_SNR         (6)
                    // Initialize general message
                    MyMessage msgTxRSSI(CHILD_ID_TX_RSSI, V_CUSTOM);
                    MyMessage msgRxRSSI(CHILD_ID_RX_RSSI, V_CUSTOM);
                    MyMessage msgTxSNR(CHILD_ID_TX_SNR, V_CUSTOM);
                    MyMessage msgRxSNR(CHILD_ID_RX_SNR, V_CUSTOM);
                    MyMessage msgTxLevel(CHILD_ID_TX_LEVEL, V_CUSTOM);
                    MyMessage msgTxPercent(CHILD_ID_TX_PERCENT, V_CUSTOM);
                    MyMessage msgUplinkQuality(CHILD_ID_UPLINK_QUALITY, V_CUSTOM);
                    	// Send the sketch version information to the gateway and controller
                    	sendSketchInfo("ATC", "1.0");
                    	present(CHILD_ID_UPLINK_QUALITY, S_CUSTOM, "UPLINK QUALITY RSSI");
                    	//present(CHILD_ID_TX_LEVEL, S_CUSTOM, "TX LEVEL DBM");
                    	//present(CHILD_ID_TX_PERCENT, S_CUSTOM, "TX LEVEL PERCENT");
                    	//present(CHILD_ID_TX_RSSI, S_CUSTOM, "TX RSSI");
                    	//present(CHILD_ID_RX_RSSI, S_CUSTOM, "RX RSSI");
                    	//present(CHILD_ID_TX_SNR, S_CUSTOM, "TX SNR");
                    	//present(CHILD_ID_RX_SNR, S_CUSTOM, "RX SNR");
                    	// send messages to GW
                    	send(msgUplinkQuality.set(transportGetSignalReport(SR_UPLINK_QUALITY)));
                    	//send(msgTxLevel.set(transportGetSignalReport(SR_TX_POWER_LEVEL)));
                    	//send(msgTxPercent.set(transportGetSignalReport(SR_TX_POWER_PERCENT)));
                    	// retrieve RSSI / SNR reports from incoming ACK
                    	//send(msgTxRSSI.set(transportGetSignalReport(SR_TX_RSSI)));
                    	//send(msgRxRSSI.set(transportGetSignalReport(SR_RX_RSSI)));
                    	//send(msgTxSNR.set(transportGetSignalReport(SR_TX_SNR)));
                    	//send(msgRxSNR.set(transportGetSignalReport(SR_RX_SNR)));
                        Serial.print("UPLINK QUALITY RSSI=");
                        Serial.println(transportInternalToRSSI(_transportSM.uplinkQualityRSSI)); // UPLINK QUALITY RSSI
                    Serial.print("TX LEVEL DBM=");
                    Serial.println(transportGetTxPowerLevel());  //TX LEVEL DBM
                    Serial.print("TX LEVEL PERCENT=");
                        Serial.println(transportGetTxPowerPercent());  // TX LEVEL PERCENT
                    Serial.print("RX RSSI=");
                        Serial.println(transportGetReceivingRSSI());  //RX RSSI
                    Serial.print("TX RSSI=");
                        Serial.println(transportGetSendingRSSI());    //TX RSSI
                    	// wait a bit
                    	wait(5000);
                    This is in case your modules are 433mhz. Try with a straight wire (one core), with the right length. You can also reduce some length by small bits and see if it improves.
                    Good to know is 433mhz requires longer antenna, and bigger gnd plane for better results, compared to upper freq like 866mhz etc.
                    A last solution if the gnd plane size would be the culprit could be to use a dipole antenna for test. by connecting two opposite wires. one to ant, the other to gnd close to ant
                    You should be able to get more than nrf24 or some nrf52, easily :)
                    I don't think you need rfm95 but that depends on the range you really need. that said some lora modules are maybe a bit more power efficient (more recent tech). but I think it's a detail for your usecase
                    Can't help you on esp8266 pin mapping, I don't use it as gw (I've esp32, nrf52 and samd as gateways for prod and dev)
                    Note: the new rfm driver has compatible communication for rfm69<->rfm95. Like others said, for using new driver, you need to enable it on both ends (gw+nodes) because it uses a different packet format than old driver.
                    • W
                      W
                      wiredfrank
                      Thank you everyone for reply, i been searching around for antenna and how to test them and came across this guy.
                      https://www.youtube.com/watch?v=ZpKoLvqOWyc&t
                      i m thinking to buy one of these VNA as i m shooting in dark with antenna right now and no way of knowing what is going on under the hood, i dont mind spending more to get miniVNA Tiny+ but what you experts think?
                      • W wiredfrank
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @wiredfrank It's a bit of overkill to be honest for hobby purposes, a quarter wave wire works fine when cut to the recommended dimension, or if concerned over the groundplane, a dipole as outlined by @scalz above.
                        A VNA is typically used to determine the exact resonant frequency of an antenna, if it's out by a fraction it won't make much difference in performance.
                        • W
                          W
                          wiredfrank
                          @zboblamont thank you, i think part of my problem might be allowed frequency is 868MHz as compare with mine 433MHz :( (school boy error) i have ordered 898MHz module and i will give them try.
                          • W wiredfrank
                            zboblamontZ
                            zboblamontZ
                            zboblamont
                            @wiredfrank Not sure what you meant by 433MHz not being allowed, so far as I recall that band is permitted worldwide but has transmit duration restrictions as it's a shared band.
                            I started off with the 433MHz RFMs and never had the slightest issue, penetrating walls and floors with plenty of range outside, even at one stage buried in snow.
                            The range and penetration of 868 v 433 will be slightly reduced, but performance should still be better than 2.4GHz.
                            The point about the recommended wire length being close enough remains valid
                            • W
                              W
                              wiredfrank
                              sorry i wasn't clear in my reply, in my country 868MHz is listed allowed frequency.
