  3. PIR with no interrupt - doubts.
5 Posts 3 Posters 481 Views 3 Watching
  • pw44P Offline
    pw44P Offline
    pw44
    Hi All,
    i'm trying to make my motion sensor work, without using interrupt.
    / Enable debug prints to serial monitor
    // Enable debug prints
    #define MY_BAUD_RATE 9600
    #define MY_RADIO_RF24
    #define MY_RF24_PA_LEVEL   RF24_PA_HIGH                                 // RF24_PA_MIN = -18dBm  RF24_PA_LOW = -12dBm RF24_PA_HIGH = -6dBm RF24_PA_MAX = 0dBm
    //#define MY_RF24_CHANNEL   (76)  // RF channel for the sensor net, 0-125.  //  0 => 2400 Mhz (RF24 channel 1)
        //  1 => 2401 Mhz (RF24 channel 2)
        // 76 => 2476 Mhz (RF24 channel 77)
        // 83 => 2483 Mhz (RF24 channel 84)
        // 124 => 2524 Mhz (RF24 channel 125)
        // 125 => 2525 Mhz (RF24 channel 126)
    //#define MY_RF24_BASE_RADIO_ID   0x00,0xFC,0xE1,0xA8,0xA8
    //#define MY_RF24_DATARATE   (RF24_250KBPS)                                 // RF24_250KBPS for 250kbs  RF24_1MBPS for 1Mbps  RF24_2MBPS for 2Mbps.
    //#define MY_RF24_SPI_SPEED   (2*1000000ul)                                 // Define this if you need to run the SPI clock at a different frequency than the default. Default nRF24L01+ SPI speed, 2MHz should be safe for nRF24L01+ clones.
    //#define MY_DEBUG_VERBOSE_RF24
    // Node and sketch information
    #define SKETCH_VER            "1.0"				        // Sketch version
    #define SKETCH_NAME           "Motion Sensor NoINterrupt"		// Optional child sensor name
    #define CHILD_ID              1				           	// Id of the sensor child
    #define CHILD_NAME            "Motion Sensor NI"		// Optional child sensor name
    #define NODE_REPEATER         false		        	  	// Set true if a repeater node (i.e. always turned on)
    int PIRpin   = 3;   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    int LEDpin   = 13;
    int PIRstate = LOW;             // we start, assuming no motion detected
    int value    = 0;                    // variable for reading the pin status
    // Initialize motion message
        pinMode(LEDpin, OUTPUT);      // declare LED as output
        pinMode(PIRpin, INPUT);     // declare sensor as input
      sendSketchInfo(SKETCH_NAME, SKETCH_VER);
      present(CHILD_ID, S_MOTION);
    void loop(){
      value = digitalRead(PIRpin);   // read input value
      if (value == HIGH) {           // check if the input is HIGH
        digitalWrite(LEDpin, HIGH);  // turn LED ON
        if (PIRstate == LOW) {
          // we have just turned on
          Serial.println("Motion detected!");
          send(msg.set(PIRstate==LOW ? 1 : 0));
          // We only want to print on the output change, not state
          PIRstate = HIGH;
      } else {
        digitalWrite(LEDpin, LOW); // turn LED OFF
        if (PIRstate == HIGH){
          // we have just turned of
          Serial.println("Motion ended!");
          send(msg.set(PIRstate==HIGH ? 1 : 0));
          PIRstate = LOW;
    but what worked before (without mysensor) is not working anymore. and the Serial.println shows nothing.
    Any hint in how to debug with the Serial.println?
    It compiles with no error, but does not work.
    Thx in advance
    • S Offline
      Sasquatch
      wrote on last edited by Sasquatch
      If it stopped working after adding mysensors then it must be at fault.
      Do you see normal mysensors debug messages?
      Does it connect to gateway?
      Try adding :
      #define MY_TRANSPORT_WAIT_READY_MS 5000
      before
      that will allow to execute your loop(); even without radio link working.
      pw44P 1 Reply Last reply
      • S Sasquatch
        Try adding :
        before
        pw44P Offline
        pw44P Offline
        pw44
        wrote on last edited by pw44
        @Sasquatch
        got it working like, but there is problem: every time it's triggered, motion detected - motion ended and a second time motion detected - motion ended. not finding out why it's triggered a second time.
        //#define MY_BAUD_RATE 9600
        int LEDpin   = 13;
        int PIRsold  = 0;
        MyMessage msgPIR(CHILD_ID, V_TRIPPED);
        void loop(){
              send(msgPIR.set(1));
              PIRstate = HIGH;
          } else {
              send(msgPIR.set(0));
              PIRstate = LOW;
        Thx for the help.
        Y 1 Reply Last reply
        • pw44P pw44
          @Sasquatch
          int LEDpin   = 13;
          int PIRsold  = 0;
          void loop(){
                PIRstate = HIGH;
            } else {
                PIRstate = LOW;
          Thx for the help.
          Y Offline
          Y Offline
          @pw44 Why is your loop so complex? You only need to detect changes in PIRpin value...
          int prevValue = LOW
            int value = digitalRead(PIRpin);   // read input value
            digitalWrite(LEDpin, value);       // LED mirrors PIRpin value
            if (value != prevValue)
                Serial.println(value ? F("Motion detected!") : F("Motion ended!"));
                send(msgPIR.set(value));       // send PIRpin value
                prevValue = value;             // remember last value, to be able to detect changes
          If you still see double triggers with this code this will be because there are indeed double triggers coming from your PIR...
          • Y Yveaux
            int prevValue = LOW
            pw44P Offline
            pw44P Offline
            pw44
            @Yveaux Thx for the hint! BR
