  3. ethernet gateway compile problem
5 Posts 2 Posters 2.3k Views 1 Watching
  • ferpandoF
    ferpandoF
    ferpando
    wrote on last edited by ferpando
    I just started to put together this type of gateway just to do some testing and I'm getting this error when compiling:
    In file included from /Volumes/Macintosh HD/Users/fernandocheca/Documents/Arduino/libraries/MySensors/MySensor.h:28,
                     from EthernetGateway.ino:52:
    /Volumes/Macintosh HD/Users/fernandocheca/Documents/Arduino/libraries/MySensors/utility/RF24.h:51: error: ISO C++ forbids declaration of 'SoftSPI' with no type
    /Volumes/Macintosh HD/Users/fernandocheca/Documents/Arduino/libraries/MySensors/utility/RF24.h:51: error: expected ';' before '<' token
    What could be the problem?
    I just uncommented the softSPI line and compile.
      Did you include SoftSPI from the sketch?
      ferpandoF 1 Reply Last reply
        ferpandoF
        ferpandoF
        ferpando
        @hek
        all I did was remove the comment from last line
          /*** USER DEFINES:  ***/
          //#define FAILURE_HANDLING
          //#define SERIAL_DEBUG
          #define MINIMAL
          //#define SPI_UART  // Requires library from https://github.com/TMRh20/Sketches/tree/master/SPI_UART
          #define SOFTSPI   // Requires library from https://github.com/greiman/DigitalIO
          Yes, and because Arduino IDE has a broken build system you also have to include DigitalIO in your sketch.
          https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/EthernetGateway/EthernetGateway.ino#L41
          Which Arduino IDE version are you running?
            ferpandoF
            ferpandoF
            ferpando
            @hek
            version 1.0.6
            ok, I added the include and compiled correctly.
            Thank you
