  3. req node id again
req node id again
4 Posts 2 Posters 2.0k Views 1 Watching
  • D
    D
    Daemon D
    wrote on last edited by Daemon D
    1. IDE 1.6.1
    2. Lib 1.4.1
    3. Vera Lite + usb hub (ext. power D-Link) + Arduino nano serial + NRF24L01 + PA + capacitor
    4. NEW repeater (or node) Arduino nano (New but have never been used) + NRF24L01 + PA + capacitor 47 mf <- trable
    5. Arduino nano + NRF24L01 + PA + capacitor <- repeater altid 3;255
    6. More ardiuno nano nodes, working fine
    When I try to teach the base of the new node, get the error (Any loaded standard program for node):
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    read: 3-3-255 s=255,c=3,t=7,pt=0,l=0:
    req node id
    send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
    repeater started, id 255
    req node id
    req node id
    req node id
    req node id
    EEPROM clear did
    This NRF24L01 + PA worked before on another node
    When I load the program to work with radio module - it works :code
    What is the can be a problem?
    D 1 Reply Last reply
    • D Daemon D
      1. IDE 1.6.1
      2. Lib 1.4.1
      req node id
      req node id
      req node id
      req node id
      req node id
      EEPROM clear did
      D
      D
      Daemon D
      @Daemon-D solved the problem by cleaning the routing table in 3 repeater
      M 1 Reply Last reply
      • D Daemon D
        Mouridsen
        @Daemon-D: Do you mean using the "Clear" button for the child nodes in Vera?? I have the same issue.
        • M Mouridsen
          D
          D
          Daemon D
          Yes
