  3. Domoticz
  4. help please
help please
4 Posts 2 Posters 1.4k Views 2 Watching
  • clivecC
    clivecC
    clivec
    Re: 💬 MP3 player with RGB-signal LED (optionally battery powered)
    I want to use this for some space 1999 unit around the house it would be great if the
    circuit diagram please
    was available please , just o clarify the battery side of things .
    How do we send asci text to the unit as well please ?? want to pop some sound effect on the sd card ,, yes yes space1999 sound effects
    • E
      E
      evb
      @mutantx follow the other link in your link : https://www.openhardware.io/view/373/MP3-player-with-RGB-signal-LED-optionally-battery-powered and you will find the schematic.
      • clivecC
        clivecC
        clivec
        Hi ,, yes I see that but you have too very closely to see were the green lines go on the breadboard . hoping I get it right ,
        May I ask one last question please
        Commands must be sent as V_VAR1 ? not too sure how to do this , I can see the child
        options I think here
        0 S_UNKNOWN true 1200 -
        1 S_RGBW_LIGHT RGBW test light true 1200 -
        69 S_UNKNOWN true 1200 -
        255 S_ARDUINO_NODE 1.5.4 false 1200 -
        just not sure who start it play a mp3 ? any help much appreciated
        The DFPlayerBat node implements two children
        interface to DFPlayer
        This child is of type S_CUSTOM. Commands must be sent as V_VAR1. Answers from the DFPlayer are sent to the controller as V_VAR2. V_VAR3 is the sleep time in milli seconds. 2. RGB-LED
        The three color pins are connected to PWM outputs of the Arduino, i.e. each color intensity can be set in 256 steps. This child is of type S_RGB_LIGHT and expects a value as V_RGB.
        • E
          E
          evb
          @mutantx, sorry for the late reply, but I was on holidays :-)
          I've no experience with this sketch code, nor the hardware build of this mp3 player.
          Try to contact the author of this player or you can check the general documentation about the use of V_VARx / S_CUSTOM : https://www.mysensors.org/download/serial_api_20
          Try to break up things in little pieces when accumulating knowledge about mysensors.
          Big complicated sketches can be overwhelming.
          I start always, when troubleshouting, with the cleanest version of the script, with minimum code required for operation. And then I build it up.
