  3. Raspberry as a node (bis)
7 Posts 2 Posters 1.1k Views 2 Watching
  • ben999B
    ben999B
    ben999
    Hi all
    Not posting doesn't that mean i've lost interest :grin:
    My house relies more and more on MySensors and openHab... great team, i'm delighted !
    Time for a new challenge : "smart" door bell.
    What is on my mind : old raspberry with its cam hidden in the front fence pillar. As soon as the doorbell push button is pushed, the bell rings (inside the house) but also a picture is taken and (at the beginning at least) is stored onto my local NAS. Then, if i'm not home i would get a broadcast message from OH.
    That brings me to the following question : can a Raspberry Pi be hooked to a NRF module and behave like a node ?
    That post (https://forum.mysensors.org/topic/6949/raspberry-pi-zero-as-sensor-node) brought me a security issue : smart devices connected to LAN can become a weakness
    Other than that i would connect an Arduino to the RPi but then that looks a bit over-complicated...
    Thanks for your help people ! :+1:
    YveauxY 1 Reply Last reply
    • ben999B ben999
      Hi all
      YveauxY
      YveauxY
      @ben999 said in Raspberry as a node (bis):
      It's been a while indeed. Welcome back :hugging_face:
      I would think so, but to send an image to your NAS the connection is way too slow.
      Just use WiFi/ethernet to connect your pi to your LAN, and use that to transport images.
      ben999B 1 Reply Last reply
      • YveauxY Yveaux
        ben999B
        ben999B
        ben999
        @Yveaux hi
        Thanks a lot for your reply :+1:
        Slight misunderstanding here ;)
        Raspberry will be connected to LAN to transfer picture to NAS, probaly via wifi (or wired if i decide to go down the PoE road...)
        But i also want the RPi to be connected to openHab in order to send notification of "front gate button pushed" via MySensors so i can get the doorbell to ring AND a broadcast message from openHab.
        About security:
        My router offers me an option of NOT giving internet access to any device while still being connected to LAN. Is that safe enough ?
        • ben999B ben999
          @Yveaux hi
          About security:
          YveauxY
          YveauxY
          Ah! Thought you were slightly paranoid ;-)
          I personally would go the MQTT way for this and bypass MySensors completely. Probably there are many more ways supported by OpenHab to trigger something on a remote node or receive some data from it using a (wireless) ethernet connection.
          • YveauxY Yveaux
            ben999B
            ben999B
            ben999
            @Yveaux :+1: thank you
            :D here you are talking once again a weired language :D
            Ok i'll dig what MQTT can do for me. How does the piece of data (someone pushed the doorbell button) gets from RPi to openhab ? Does it stay local within the LAN (and gets directly to my gateway) or does it have to travel through internet up to openhab and down again to my gateway (remember, my bell has to ring) ?
            So last question just to be sure : it is not common practice to use RPi as a node ? And there is no "sketch" ready made that can be tweaked ?
            Thanks a lot for your time, i really appreciate it ;)
            • ben999B ben999
              YveauxY
              YveauxY
              You run an MQTT broker ('server') somewhere in your local network (or even on your pi) that takes care of distributing the data.
              Not saying you need MQTT, only that it works marvellous for me.
              Not to my knowledge, but as all platforms supported by mysensors can be turned into nodes, this should also work for a pi.
              • ben999B
                ben999B
                ben999
                This post is deleted!
