  3. 1.5.1 to 2.3.2 issues
5 Posts 2 Posters 1.4k Views 2 Watching
  • epierreE
    epierreE
    epierre
    Today I migrated my gateway from 1.5.1 to 2.3.2, tested it fine.
    Then I started trying to reprogram my sensors to 2.3.2 and none works. No wiring changed, previously fine working (CO2, DSM dust sensor)
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSF:SID:OK,ID=20
    38 TSM:FPAR
    41 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2050 !TSM:FPAR:NO REPLY
    2052 TSM:FPAR
    2056 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    3899 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    3904 TSF:MSG:BC
    4063 !TSM:FPAR:NO REPLY
    4065 TSM:FPAR
    4069 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    5923 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    5928 TSF:MSG:BC
    6076 !TSM:FPAR:NO REPLY
    6078 TSM:FPAR
    6082 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    7947 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    7952 TSF:MSG:BC
    8089 !TSM:FPAR:FAIL
    8090 TSM:FAIL:CNT=1
    8092 TSM:FAIL:DIS
    8094 TSF:TDI:TSL
    z-wave - Vera -> Domoticz
    • epierreE epierre
      26 TSM:INIT
      28 TSF:WUR:MS=0
      34 TSM:INIT:TSP OK
      36 TSF:SID:OK,ID=20
      38 TSM:FPAR
      2052 TSM:FPAR
      3904 TSF:MSG:BC
      4065 TSM:FPAR
      5928 TSF:MSG:BC
      6078 TSM:FPAR
      7952 TSF:MSG:BC
      8089 !TSM:FPAR:FAIL
      8090 TSM:FAIL:CNT=1
      8092 TSM:FAIL:DIS
      8094 TSF:TDI:TSL
      @epierre what does the log from the gateway say? Preferably for the same time, so the node side and the gateway side can be compared.
      • epierreE
        epierreE
        epierre
        will try to put it in debug mode. now I've added a 1u and 100u with no result
        • epierreE
          epierreE
          epierre
          wrote on last edited by epierre
          intermediary result: I have started a second gateway and now the nodes do communicate... puzzled...
          I remove the extra gateway... same situation...
          so reprogram gateway with:
          so it seems this was the responsible for this !
          thanks !
          • epierreE
            epierreE
            epierre
            I am reviving this as I upgraded my kernel to 7.0 and now have communications issues.
            I discovered that I had to force port speed when opening it up to the right speed, then it communicates a bit then nothing...
            driver is ch341
            any idea ?
