  3. Unsolved problem with RFM95
1 Posts 1 Posters 553 Views 1 Watching
  • Diego Andrade 0D
    Diego Andrade 0D
    Diego Andrade 0
    I have a problem with my Gateway and my Node.
    I'm using RFM95 module (915Mhz), as I'm in Brazil.
    It worked for a while in the afternoon, but then at night it stopped working.
    Node is sending something, but my Gateway is not recognizing anyone sent to it.
    Code Gateway:
     * Version 1.0 - Henrik Ekblad
     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
     * See https://www.mysensors.org/build/connect_radio for wiring instructions.
     * If you are using a "barebone" ESP8266, see
     * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
     * Inclusion mode button:
     * - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
    #define MY_BAUD_RATE 115200
    //#define MY_RADIO_RF24
    #define MY_RADIO_RFM95
    #define MY_RFM95_IRQ_PIN D1
    #define MY_RFM95_IRQ_NUM digitalPinToInterrupt(MY_RFM95_IRQ_PIN)
    #define MY_RFM95_CS_PIN D8
    #define MY_RFM95_FREQUENCY (RFM95_915MHZ)
    #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128
    #define MY_TRANSPORT_STATE_TIMEOUT_MS (3*1000ul)
    #define RFM95_RETRY_TIMEOUT_MS (5000ul)
    #define MY_DEBUG_VERBOSE_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "/ragnarok.skyline@gmail.com/Rfm95/mygateway1-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "/ragnarok.skyline@gmail.com/Rfm95/mygateway1-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "RFM95_MQTT_GW"
    // Enable these if your MQTT broker requires username/password
    #define MY_MQTT_USER "ragnarok.skyline@gmail.com"
    #define MY_MQTT_PASSWORD "dec919a9"
    // Set WIFI SSID and password
    #define MY_WIFI_SSID "Carlos AP2.4ghz"
    #define MY_WIFI_PASSWORD "EAEi2t7k3c4"
    //#define MY_WIFI_SSID "Quartinho"
    //#define MY_WIFI_PASSWORD "i2t7k3c4.."
    // passed to the DHCP server if not static.
    #define MY_HOSTNAME "RFM95_MQTT_GW"
    // MQTT broker ip address.
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 103
    //MQTT broker if using URL instead of ip address.
    #define MY_CONTROLLER_URL_ADDRESS "mqtt.dioty.co"
    #define MY_PORT 1883
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    Code Node:
     * Version 1.0 - tekka
     * Passive node example: This is a passive & independent reporting node
    // Enable debug prints
    // Enable passive mode
    #define MY_PASSIVE_NODE
    // Passive mode requires static node ID
    #define MY_NODE_ID 100
    //#define MY_RADIO_NRF5_ESB
    #define CHILD_ID 0   // Id of the sensor child
    // Initialize general message
    MyMessage msg(CHILD_ID, V_TEMP);
    	// Send the sketch version information to the gateway and controller
    	sendSketchInfo("Passive node", "1.0");
    	present(CHILD_ID, S_TEMP);
    	// generate some random data
    	send(msg.set(25.0+random(0,30)/10.0,2));
    	delay(500);
    Gateway using NodeMcu1.0
    Node: using Uno PCb
