  3. Node to Node Communication via Gatreway
19 Posts 5 Posters 6.0k Views 3 Watching
  • J
    J
    jkandasa
    My topology is as follows,
    Node-1 <--> Gateway <--> Node-2.
    When I send message from Node-1 to Node-2 (or) Node-2 to Node-1 is not working,
    Node-1 and Node-2 are repeater nodes.
    Gateway does not route packets to another node in the network?
      That's strange. You probably have to look at the serial output from the nodes and gateway to find the cause.
      • J
        J
        jkandasa
        wrote on last edited by jkandasa
        @hek Thank you I did serial debug, I'm not clear about route (to) address
        https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.cpp#L401
        Node-1:
        send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=6,sg=0,st=ok:1.5 b1
        send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
        repeater started, id=1, parent=0, distance=1
        send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:LevelSensor
        send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
        send: 1-1-0-0 s=1,c=0,t=15,pt=0,l=6,sg=0,st=ok:1.5 b1
        send: 1-1-0-0 s=1,c=1,t=13,pt=2,l=2,sg=0,st=ok:0
        send: 1-1-3-3 s=1,c=1,t=13,pt=2,l=2,sg=0,st=fail:0
        above '3' is 'to' (route) address, I do not understand what is '3' and how it was calculated, I hope here 'to' should be a parent address, which is 0
        Gateway:
        0;0;3;0;9;read: 1-1-0 s=255,c=0,t=18,pt=0,l=6,sg=0:1.5 b1
        1;255;0;0;18;1.5 b1
        0;0;3;0;9;read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        1;255;3;0;6;0
        0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=16,sg=0:LevelSensor
        1;255;3;0;11;LevelSensor
        0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        1;255;3;0;12;1.0
        0;0;3;0;9;read: 1-1-0 s=1,c=0,t=15,pt=0,l=6,sg=0:1.5 b1
        1;1;0;0;15;1.5 b1
        0;0;3;0;9;read: 1-1-0 s=1,c=1,t=13,pt=2,l=2,sg=0:0
        1;1;1;0;13;0
        0;0;3;0;9;read: 3-3-0 s=255,c=0,t=18,pt=0,l=6,sg=0:1.5 b1
        3;255;0;0;18;1.5 b1
        0;0;3;0;9;read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        3;255;3;0;6;0
        0;0;3;0;9;read: 3-3-0 s=255,c=3,t=11,pt=0,l=19,sg=0:LevelIndicator
        3;255;3;0;11;LevelIndicator
        0;0;3;0;9;read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        3;255;3;0;12;1.0
        0;0;3;0;9;read: 3-3-0 s=1,c=0,t=15,pt=0,l=6,sg=0:1.5 b1
        3;1;0;0;15;1.5 b1
        Node-2:
        send: 3-3-0-0 s=255,c=0,t=18,pt=0,l=6,sg=0,st=ok:1.5 b1
        send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
        repeater started, id=3, parent=0, distance=1
        send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=19,sg=0,st=ok:LevelIndicator
        send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
        send: 3-3-0-0 s=1,c=0,t=15,pt=0,l=6,sg=0,st=ok:1.5 b1
        send: 3-3-1-1 s=1,c=1,t=13,pt=2,l=2,sg=0,st=fail:0
          wrote on last edited by hek
          What does your code look like on the sending node (1)?
          • J
            J
            jkandasa
            #define NODE_ID (int8_t) 1
            #define N_LEVEL_DISPLAY_ID (int8_t) 3
            #define S_LEVEL_DISPLAY_ID (int8_t) 1
             gw.begin(incomingMessage, NODE_ID, true);
            MyMessage levelDisplayBoard(S_LEVEL_DISPLAY_ID, V_DISTANCE);
            levelDisplayBoard.setDestination(N_LEVEL_DISPLAY_ID);
            int dist = getDistance();
            gw.send(levelDisplayBoard.set(dist));
              I think node 1 has a corrupt routing table (it thinks node 3 is a child).
              Try clearing eeprom and re-upload your sketch. Or disable repeater-mode on it.
              • J
                J
                jkandasa
                How to print routing table in serial console?
                  You have to read it from eeprom.
                  It starts at position: EEPROM_ROUTES_ADDRESS (defined in MySensors.h)
                  http://www.arduino.cc/en/Tutorial/EEPROMRead
                  • J
                    J
                    jkandasa
                    @hek you are right! There was an entry for Node-2 in Node-1 routing table, As it has direct access to Node-2, was trying to send directly. I removed the entry and now it's going throw gateway. All node works well. Perfect!
                    I thing we have to add code to remove routing table entry dynamically if it face some N number of failures. It will make life easier for those who is shifting node from one location to another location often.
                    • F
                      F
                      FullMetal
                      Sorry to resort to an old topic ...
                      I am currently using mysensors RS485, and I would like to extend my installation with this protocol.
                      and I would like to make the nodes communicate with each other through the gateway.
                      But I can't do what I want ... help!
                      on my node 4, I have an input and 1 output, the input activates and deactivates the output. (here no worries).
                      On my node 5, I have an input to activate the output of node 4, so I can turn it off but not turn it on, and I don't see any frames towards the gateway
                      here is the code for my node 5:
                      // MySensors
                      #define MY_PARENT_NODE_ID 0                   // define if fixed parent
                      #undef MY_REGISTRATION_FEATURE                  // sketch moves on if no registration
                      #define MY_NODE_ID 5                     // fixed node number
                      // Enable RS485 transport layer
                      #define MY_RS485
                      // Define this to enables DE-pin management on defined pin
                      #define MY_RS485_DE_PIN 2
                      // Set RS485 baud rate to use
                      #define MY_RS485_BAUD_RATE 9600
                      // Set blinking period
                      // Flash leds on rx/tx/err
                      //#define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
                      //#define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
                      // Enable this if RS485 is connected to a hardware serial port
                      //#define MY_RS485_HWSERIAL Serial1
                      //#include <MqttClient.h>
                      #include <Bounce2.h>
                      #define CHILD_ID 4
                      #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
                      Bounce debouncer = Bounce();
                      int oldValue=0;
                      bool state;
                      MyMessage msg(CHILD_ID,V_LIGHT);
                        // Setup the button
                        pinMode(BUTTON_PIN,INPUT_PULLUP);
                        // Activate internal pull-up
                        //digitalWrite(BUTTON_PIN,HIGH);
                        debouncer.attach(BUTTON_PIN);
                        debouncer.interval(5);
                      void presentation() {
                        sendSketchInfo("Button", "1.1");
                        present(CHILD_ID, S_LIGHT);
                        debouncer.update();
                        // Get the update value
                        int value = debouncer.read();
                        if (value != oldValue && value==0) {
                            msg.setDestination(4);
                            send(msg.set(state?false:true), false);// Send new state and request ack back
                        oldValue = value;
                      rejoe2R 1 Reply Last reply
                      • F FullMetal
                        // MySensors
                        #define MY_RS485
                        #define CHILD_ID 4
                        int oldValue=0;
                        bool state;
                          // Setup the button
                          debouncer.update();
                          oldValue = value;
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @FullMetal Imo, you have to specify all send-settings in one line, e.g. like this:
                        send(buttonMsg.setDestination(MY_SISTER_NODE_ID).setSensor(CHILD_ID_RESET).set( button[i] ? "1" : "0"));
                        F 1 Reply Last reply
                        • rejoe2R rejoe2
                          F
                          F
                          FullMetal
                          @rejoe2
                          thank you for your return,
                          but I have the same problem, I manage to activate the relay of node 4 from node 5, but I cannot deactivate it. and when I act on node 5 the gateway does not receive frames since it calls node 4.
                          I think that node 4 should send the relay status to node 5 so that it knows whether it is activated or not.
                          tekkaT rejoe2R 2 Replies Last reply
                          • F FullMetal
                            @rejoe2
                            tekkaT
                            tekkaT
                            tekka
                            @FullMetal Please post a full debug log of both nodes showing the observed behaviour.
                            • F FullMetal
                              @rejoe2
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @FullMetal Pls add also code from node 4.
                              In general:
                              • if you want also info from node 5 to be sent to your controller/gateway, you have to add a second (normal) send command.
                              • wrt. to how node 4 reacts on the messages, you may better use sth. like a toggle logic.
                              • tekkaT tekka
                                F
                                F
                                FullMetal
                                @tekka @rejoe2
                                Désolé de revenir si tard ..
                                J'ai modifié mon code sur mes nœuds, mais le résultat n'est toujours pas là!
                                Voici mes codes:
                                node 4:
                                // MySensors
                                #define MY_NODE_ID 4                    // fixed node number
                                #define MY_RS485
                                #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                                #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
                                #define SYSTER_ID 5
                                #define RELAY_ON 1
                                #define RELAY_OFF 0
                                int oldValue=0;
                                bool state;
                                //MyMessage msgconf(CHILD_ID,V_VAR1);
                                  // Setup the button
                                  pinMode(RELAY_PIN, OUTPUT);
                                  state = loadState(CHILD_ID);
                                  sendSketchInfo("Relay & Button", "1.0");
                                  debouncer.update();
                                      send(msg.setDestination(MY_PARENT_NODE_ID).setSensor(CHILD_ID).set(state?false:true), true); // Send new state and request ack back
                                      wait(100);
                                      send(msg.setDestination(SYSTER_ID).setSensor(CHILD_ID).set(state?false:true), true);
                                  oldValue = value;
                                  if (message.isAck()) {
                                     // Change relay state
                                     state = message.getBool();
                                     // Store state in eeprom
                                     saveState(CHILD_ID, state);
                                     // Write some debug info
                                     Serial.print(message.sensor);
                                node 5:
                                // MySensors
                                #define MY_RS485
                                #define CHILD_ID 1
                                #define SYSTER_ID 4
                                int oldValue=0;
                                bool state;
                                  // Setup the button
                                  debouncer.update();
                                      send(msg.setDestination(MY_PARENT_NODE_ID).setSensor(CHILD_ID).set(state?false:true), false);// Send new state and request ack back
                                      Serial.println("wait 1/10sec");
                                      wait(100);
                                      send(msg.setDestination(SYSTER_ID).setSensor(CHILD_ID).set(state?false:true), false);
                                  oldValue = value;
                                     //digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF);
                                     saveState(SYSTER_ID, state);
                                From node 4, my output is activated and deactivated immediately, due to double sending
                                from node 5, I can activate or deactivate if I launch the command from node 4 before otherwise.
                                tekkaT 1 Reply Last reply
                                • F FullMetal
                                  @tekka @rejoe2
                                  Voici mes codes:
                                  node 4:
                                  // MySensors
                                  #define MY_RS485
                                  #define SYSTER_ID 5
                                  #define RELAY_ON 1
                                  #define RELAY_OFF 0
                                  int oldValue=0;
                                  bool state;
                                    // Setup the button
                                    debouncer.update();
                                        wait(100);
                                    oldValue = value;
                                  node 5:
                                  // MySensors
                                  #define MY_RS485
                                  #define CHILD_ID 1
                                  #define SYSTER_ID 4
                                  int oldValue=0;
                                  bool state;
                                    // Setup the button
                                    debouncer.update();
                                        wait(100);
                                    oldValue = value;
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @FullMetal said in Node to Node Communication via Gatreway: Please upload the debug logs for further troubleshooting.
                                  F 2 Replies Last reply
                                  • tekkaT tekka
                                    F
                                    F
                                    FullMetal
                                    @tekka said in Node to Node Communication via Gatreway:
                                    Sorry
                                    Debug logs node 4
                                    Press button node 4
                                    08:16:01.668 -> 13555 TSF:MSG:SEND,4-4-0-0,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    08:16:01.701 -> 13582 TSF:MSG:READ,0-0-4,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                                    08:16:01.701 -> 13586 TSF:MSG:ECHO
                                    08:16:01.701 -> This is an ack from gateway
                                    08:16:01.701 -> Incoming change for sensor:1, New status: 0
                                    08:16:01.800 -> 13678 TSF:MSG:SEND,4-4-5-5,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
                                    08:16:01.800 -> 13684 TSF:RTE:N2N OK
                                    08:16:01.800 -> 13703 TSF:MSG:READ,5-5-4,s=1,c=1,t=2,pt=1,l=1,sg=0:1
                                    08:16:01.833 -> 13708 TSF:MSG:ECHO
                                    08:16:01.833 -> This is an ack from gateway
                                    08:16:01.833 -> Incoming change for sensor:1, New status: 1
                                    Press button node 5
                                    08:21:01.371 -> 313012 TSF:MSG:READ,5-5-4,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                                    08:21:01.371 -> Incoming change for sensor:1, New status: 0
                                    second press node 5
                                    08:21:06.238 -> 317865 TSF:MSG:READ,5-5-4,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                                    08:21:06.238 -> Incoming change for sensor:1, New status: 0
                                    Debug logs node 5
                                    Press button node 4
                                    08:23:59.955 -> 51752 TSF:MSG:READ,4-4-5,s=1,c=1,t=2,pt=1,l=1,sg=0:1
                                    08:23:59.955 -> 51757 TSF:MSG:ECHO REQ
                                    08:23:59.988 -> 51777 TSF:MSG:SEND,5-5-4-4,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
                                    08:23:59.988 -> 51783 TSF:RTE:N2N OK
                                    08:23:59.988 -> Incoming change for sensor:1, New status: 1
                                    Press button node 5
                                    08:24:36.929 -> 88704 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    08:24:36.929 -> wait 1/10sec
                                    08:24:37.062 -> 88827 TSF:MSG:SEND,5-5-4-4,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    08:24:37.062 -> 88834 TSF:RTE:N2N OK
                                    Debug logs gateway
                                    Press button node 4 and node 5
                                    08:26:19.261 -> 0;255;3;0;9;79078 TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                                    08:26:19.261 -> 0;255;3;0;9;79084 TSF:MSG:ACK REQ
                                    08:26:19.294 -> 0;255;3;0;9;79105 TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    08:26:19.294 -> 4;1;1;0;2;0
                                    08:26:20.321 -> 0;255;3;0;9;80116 TSF:MSG:READ,5-5-0,s=1,c=1,t=2,pt=1,l=1,sg=0:0
                                    08:26:20.321 -> 5;1;1;0;2;0
                                    • tekkaT tekka
                                      F
                                      F
                                      FullMetal
                                      wrote on last edited by FullMetal
                                      @tekka @rejoe2
                                      I just found!
                                      ask the gateway not to send back acq
                                      send(msg.setDestination(MY_PARENT_NODE_ID).setSensor(CHILD_ID).set(state?false:true), false); // Send new state and request ack back
                                      wait(100);
                                      • rejoe2R
                                        rejoe2R
                                        rejoe2
                                        Good to her you found that point :smile:.
                                        Imo you'd better change also your receive functions to not react on "ack" messages (via "else" prior to message.type-comparison).
