  3. Motion (PIR), actuator and Temp sensor
7 Posts 3 Posters 4.5k Views 1 Watching
  • H
    H
    Hausner
    I'm trying to make and sensor, as subject says. I've got temp (DS18B20) and actuator working, but not the PIR (HC-SR501).
    PINs as follow:
    RADIO IRQ = PIN2
    Temp = PIN3
    PIR data = PIN4
    Actuator = PIN 5,6
    My question is now, does a PIR require an Interrupt PIN on the arduino (PIN 2,3) , or can I use any PIN?
    • A
      A
      andriej
      Thats unfortunate question, as it all depends on the code you write..
        If you want to sleep the node, then using pin-interrrupt is a great way of waking the node when motion is detected.
        You can use use the radio-irq pin for you sensors. It is currently not used by the mysensors library.
        H 1 Reply Last reply
        • H
          H
          Hausner
          Ok, so basicly you are saying, that the PIR DOESN'T require an irq pin on the arduino?
            H
            H
            Hausner
            So, not need to wire the radio IRQ PIN at all?
            hekH 1 Reply Last reply
            • H Hausner
              wrote on last edited by hek
              No
              No, you can poll it yourself if you stay awake.
              • H
                H
                Hausner
                Ok, finally got it to work with this:
                // Example sketch showing how to control physical relays.
                // This example will remember relay state even after power failure.
                #include <OneWire.h>
                OneWire oneWire(ONE_WIRE_BUS);
                int numSensors=0;
                //boolean receivedConfig = false;
                boolean metric = true;
                #define RELAY_1 5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                #define RELAY_2 6
                // Motion sensor defs
                unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds)
                #define DIGITAL_INPUT_SENSOR 4   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                //#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                #define CHILD_ID 3   // Id of the sensor child
                boolean lastTrippedState;
                MyMessage msgTemp(0, V_TEMP);
                MyMessage msgRelay2(2, V_LIGHT);
                MyMessage msgMotion(3, V_TRIPPED);
                  gw.sendSketchInfo("Temp/Relay/Motion Sensor", "1.0");
                  gw.present(1, S_LIGHT);
                  pinMode(RELAY_1, OUTPUT);
                  gw.present(2, S_LIGHT);
                  pinMode(RELAY_2, OUTPUT);
                  digitalWrite(RELAY_1, gw.loadState(1)? RELAY_ON : RELAY_OFF);
                  digitalWrite(RELAY_2, gw.loadState(1)? RELAY_ON : RELAY_OFF);
                  gw.present(CHILD_ID, S_MOTION);
                  //numSensors = sensors.getDeviceCount();
                  //for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
                     gw.present(0, S_TEMP);
                  gw.process();
                  if (tripped != lastTrippedState)
                    Serial.println(tripped? "tripped" : "not tripped");
                    gw.send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw//
                    //digitalWrite(RELAY_1, tripped? 1 : 0);
                  lastTrippedState = tripped;
                    float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(0):sensors.getTempFByIndex(0)) * 10.)) / 10.;
                    // Only send data if temperature has changed more then 1 degC and no error
                    if (int(lastTemperature[0]) != int(temperature) && temperature != -127.00) { //added integer
                      gw.send(msgTemp.setSensor(0).set(temperature,1));
                      lastTemperature[0]=temperature;
                  if (message.type==V_LIGHT && message.sensor == 2)
                    // Change relay state
                    digitalWrite(RELAY_2, message.getBool()?RELAY_ON:RELAY_OFF);
                    // Store state in eeprom
                    // Write some debug info
                    Serial.print(message.sensor);
