  3. eedomus as controller
12 Posts 2 Posters 5.5k Views 2 Watching
  • godestalbinG Offline
    godestalbin
    I just discover MySensors. It seems eedomus is not currently supported. Is there a chance I could integrate my eedomus controller with MySensors ?
    Any hint/advice on how to proceed would be warmly welcomed.
    • hekH Offline
      hekH Offline
      wrote on last edited by hek
      Most documentation on eedomus seems to be in french so I'm having a hard time understanding what integration possibilities there are.
      Sorry.. Looked at the wrong site...
      But basically if eedomus have some sort of plugin architecture allowing you to open a ethernet socket connection or have access to serial USB you should be able to write a plugin for the controller.
      MySensors serial protocol is described here:
      http://www.mysensors.org/download/serial_api_14
      Do you plan to write the plugin yourself?
        godestalbin
        I asked for support eedomus team and in eedomus forum but got no reply at all.
        eedomus box has an USB port. I wonder, if I build a serial gateway (http://www.mysensors.org/build/serial_gateway) and connect the USB port to my eedomus box, is there any chance my box will recognize it ?
        I think I have no possibility to build a plug-in for eedomus as Connected Objects does not provide any kind of API to extend the features of their box.
          godestalbin
          Here is the status on my project to connect my eedomus controller to MySensors:
          I am limited to make HTTP request to update some virtual state on my eedomus box.
          I build an Arduino (mega) with an Ethernet shield to validate I can update a virtual state on eedomus.
          I built a MySensor serial gateway with a temp/humidity sensor. Using hard-coded sensor's ID, I managed to get temp/humidity on the gateway.
          I am now stuck to make both working together.
          I have my sketch gateway: MySensorsGateway (http://www.mysensors.org/build/serial_gateway) using the library MyGateway and I have the library Ethernet.
          In MySensorsGateway, I can use Ethernet library but I cannot access the message received.
          In MyGateway library, I can view/display the message received but I cannot use Ethernet library.
          I would like to access received message in MySensorsGateway in order to forward them by HTTP requests to my eedomus controller.
          Can you point me in the right direction ? Some sample code would be great.
          • hekH Offline
            hekH Offline
            You'll have to define a callback-function when calling gw.begin(). This function will receive all incoming messages. You can have a look at RelayActuator as an example of defining a callback.
            The SerialGateway already uses this callback and should be possible to update.
              godestalbin
              Thank you, that seems to perfectly answer my need.
              However I have one question: I will use the MyGateway::begin which takes void (*inDataCallback)(char ) parameter which seems less convenient to use than the void (_msgCallback)(const MyMessage &) parameter of the MySensor::begin.
              Why is it like this ? Would it be not more convenient to have a callback with a MyMessage ?
              • hekH Offline
                hekH Offline
                You don't need the gateway class. Just initialise the MySensors with static id 0.
                (A suggestion is to have a look at the development branch instead.)
                  godestalbin
                  Thanx to your help, it is now a few months I have a temp/humidity MySensor with the data updated in my eedomus domotic box.
                  Now the next challenge is to make a relay actuator. I did not buy the hardware yet, thus I wish to validate the transfer of the message from the box->gateway->sensor.
                  • I have made the first step getting the command (O=Off, 1=On) from my eedomux box to my gateway node.
                  • Now I am trying to send the message from gateway (ID=0) to my existing temp/humidity sensor node (ID=10). I have written the following code:
                    gw.process(); //Read radio message, and display in serial window
                   //Create a test messge to send to node
                    MyMessage msg;
                    boolean ok = false;
                    msg.sender = 0; //0=gateway ID
                    msg.destination = 10; //node ID
                    msg.sensor = 2; //To be set later: CHILD_ID_HUM 0/CHILD_ID_TEMP 1
                    msg.type = 1; //set=This message is sent from or to a sensor when a sensor value should be updated
                    mSetRequestAck(msg,0); //What is the difference with the one after ?
                    mSetAck(msg,false); //For now no ack, later it would be better to get one
                    mSetCommand(msg,S_LIGHT);
                    msg.set(1);
                    ok = gw.send(msg);
                      if (!ok) {
                  //      //errBlink(1);
                        Serial.println("Error sending message");
                  For now the gw.send returns not OK.
                  Am I doing right by creating the message manually or is there a better way to do ?
                  What is wrong that the message is not sent ?
                  • hekH Offline
                    hekH Offline
                    Shouldn't msg.type be S_LIGHT and command be 1?
                    gw.send() actually sets command to C_SET for you
                    https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.cpp#L483-L487
                    Not sure why send returns false.. indicates that no ack was received from the other radio.
                      godestalbin
                      I am still trying to make it work. I uploaded on my temp/humidity sensor the code of the relay actuator (sketch:47534). I just updated this line to set the ID=10:
                      gw.begin(incomingMessage, 10, true); //Set ID=10 instead of AUTO
                      On the serial window of the temp/humidity everything looks fine:
                      read: 0-0-10 s=0,c=1,t=3,pt=2,l=2:18
                      send: 10-10-0-0 s=0,c=1,t=3,pt=2,l=2,st=ok:18
                      But on my node (gateway) I still have error
                      send: 0-0-255-10 s=0,c=1,t=3,pt=2,l=2,st=fail:18
                      The code is now as below:
                        MyMessage msg;
                        boolean ok = false;
                        msg.sender = 0;
                        msg.sensor = 0; //To be set later
                        msg.type = S_LIGHT;
                        //mSetRequestAck(msg,0); //No ack
                        //mSetAck(msg,false);
                        //mSetCommand(msg,S_LIGHT);
                        msg.set(18);
                        ok = gw.send(msg, true);
                          if (!ok) {
                            //errBlink(1);
                          else
                            Serial.println("Success !!!!");
                        delay(5000);
                      • hekH Offline
                        hekH Offline
                        Message seem to reach node... Did you add a capacitor to the node? It seems to have some problem sending ack back to gateway. Usually indicates a powering issue.
                          godestalbin
                          Yes, I have capacitor on both radio.
