  3. Requesting a sensor value from a different node?
15 Posts 10 Posters 11.4k Views 4 Watching
  • S
    sansespere
    I'm trying to put together a "status" type LCD screen on a separate node which can display values from other sensor nodes in the network but am running into some problems reading the data from the other nodes.
    the setup is like this:
    Node A - temp, humidity, pressure
    Node B - Distance
    Node C- LCD screeen
    I'm using a Vera as my controller, and all devices are in there and reporting correctly. I've used the "TimeAndVariable" example as the base of the LCD node, and can get it to read custom variables without any problems. But looking at the API reference I should be able to get the last value from any sensor using:
    void requestStatus(uint8_t radioId, int8_t childId, uint8_t variableType);
    But I cant for get this to work! Just trying to play with the code here is a section with the problem:
    gw.getStatus(1,11,0); //altID of temp sensor 1;11, 0 is for V_TEMP
    Status(gw.getMessage()); //function is below
    lcd.print(value);
    void Status(message_s message) {
    value = atoi(message.data);
    I'm obviously doing something wrong - any advice would be appreciated!
      I would recommend pushing data from your sensors to the LCD node instead of trying to poll it with requestStatus.
      The requestStatus function was mainly implemented for fetching data from controller and I'm not sure how well it has been tested for the tasks you are planning on 1.3.
      Your sensors must do a lot of "manual" work to pick up the request-message and reply to the LCD-node. This means they must be awake all the time. And are basically pushing data in the end anyway.
      • S
        sansespere
        wrote on last edited by sansespere
        Awesome - pushing from the sensor at the same time it sends to the gateway has got it working. Will have to create what will almost be a stripped down version of a gateway to process all incoming messages and assign the contents to the correct variables for the screen : )
        Thanks for the advice!
        • andyunoA
          andyunoA
          andyuno
          Hey Great idea been trying something similar myself sometime but getting nowhere any chance of you sharing some of your code, that might help me get started. What size LCD are you thinking of of using, or are you just going to use a small LCD menu driven with a couple buttons.
          :) Any Help is Appreciated Thank You.
          S 1 Reply Last reply
          • andyunoA andyuno
            sansespere
            @andyuno
            Hey, no problem - the LCD I'm using is this one in a 16x2 format.
            Haven't had much of a chance to work on it yet since first getting it working with Hek's advice above but this is what I have so far. Standard disclaimer though, I'm new to this whole coding and electronics stuff so there may be a better way of doing it.
            To start with, in the sketch of the sensor that has the information you want to display, find where it's sending the data to the gateway, and get it to send to the node that has the LCD at the same time. EG:
            gw.sendVariable(CHILD_ID_TEMP, V_TEMP, temperatureB, 1); //standard line sending data to the gateway
            gw.sendVariable(MONITOR_STATION,CHILD_ID_TEMP, V_TEMP, temperatureB, 1); //new line that needs to be created, where MONITOR_STATION is defined as the radioID of the node with the LCD
            and below is the testing sketch I wrote to receive and display the messages:
             #include <EEPROM.h>
             #include <RF24.h>
             #include <Sensor.h>
             #include <Time.h>
             #include <Wire.h>
             Sensor gw;
             #define CHILD_ID 10
             LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
             float temp = 0; //for storing temperature values
             float hum = 0; //for storing humidity values
               gw.begin();
               gw.sendSketchInfo("LCD", "1.0");
               // Register any sensortype. This example we just create a motion sensor.
               gw.sendSensorPresentation(CHILD_ID, S_MOTION);
               lcd.begin(16,2);   //Specify LCD size
               lcd.backlight();
               int LoopCount = 0; // LoopCount is there to make sure that we dont get stuck in a never ending loop of processing messages - not sure if this could ever even happen, but just to be safe
               while(gw.messageAvailable()==true && LoopCount < 10){ //while there are messages in the queue and we havent processed more than 10 since entering the loop
                   message_s  message = gw.getMessage(); //get the message
                   if (message.header.type == 0){  //check the type of message it is - temperature, humidity, etc. as per Variable Types defined in http://www.mysensors.org/build/sensor_api
                   temp = atof(message.data); //if it's a temp type, get the data and convert it to float
                   if (message.header.type == 1){
                   hum =  atof(message.data); //if it's a humidity type, get the data and convert it to float
                   LoopCount++;  //increment the loop counter
               if (LoopCount >= 1){ //Check if we need to update the LCD
                UpdateLCD();
               //serial prints for troubleshooting
               Serial.print("Temp: ");
               Serial.println(temp);
               Serial.print("Hum: ");
               Serial.println(hum);
               Serial.println("Waiting");
               delay(10000);   //take a short break
             void UpdateLCD() { //LCD output
               lcd.clear();
               lcd.print("Temp:");
               lcd.print(temp,1);
               lcd.print("C");
               lcd.setCursor(0,1);
               lcd.print("Humi:");
               lcd.print(hum,1);
               lcd.print("%");
            and you end up with something like this.....
            upload-782a7eaa-f12e-4e50-aeb8-d2c106de80aa
            showing data for a sensor I have sitting outside.
            Still a lot of work to do to get it right - there are other things I want to display, using scrolling messages to cycling messages, etc, but this is just a basic proof of concept.
            • S sansespere
              @andyuno
               #include <EEPROM.h>
               #include <RF24.h>
               #include <Sensor.h>
               #include <Time.h>
               #include <Wire.h>
               Sensor gw;
               #define CHILD_ID 10
                 gw.begin();
                 lcd.backlight();
                  UpdateLCD();
                 lcd.clear();
                 lcd.print("Temp:");
                 lcd.print(temp,1);
                 lcd.print("C");
                 lcd.setCursor(0,1);
                 lcd.print("Humi:");
                 lcd.print(hum,1);
                 lcd.print("%");
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @sansespere said:
              @andyuno
               #include <EEPROM.h>
               #include <RF24.h>
               #include <Sensor.h>
               #include <Time.h>
               #include <Wire.h>
               Sensor gw;
               #define CHILD_ID 10
                 gw.begin();
                 lcd.backlight();
                  UpdateLCD();
                 lcd.clear();
                 lcd.print("Temp:");
                 lcd.print(temp,1);
                 lcd.print("C");
                 lcd.setCursor(0,1);
                 lcd.print("Humi:");
                 lcd.print(hum,1);
                 lcd.print("%");
              nice work.
              for your next revision we can show you how to do this without holding in the while loop or using delays.
              terrific!!!!! :) I like LCD's :)
                @sansespere said:
                @andyuno
                 #include <EEPROM.h>
                 #include <RF24.h>
                 #include <Sensor.h>
                 #include <Time.h>
                 #include <Wire.h>
                 Sensor gw;
                 #define CHILD_ID 10
                   gw.begin();
                   lcd.backlight();
                    UpdateLCD();
                   lcd.clear();
                   lcd.print("Temp:");
                   lcd.print(temp,1);
                   lcd.print("C");
                   lcd.setCursor(0,1);
                   lcd.print("Humi:");
                   lcd.print(hum,1);
                   lcd.print("%");
                nice work.
                sansespere
                Ahhh ok - so something more like this:
                #include <EEPROM.h>
                #include <RF24.h>
                #include <Sensor.h>
                #include <Time.h>
                #include <Wire.h>
                Sensor gw;
                #define CHILD_ID 1
                  gw.begin();
                  lcd.backlight();
                    message_s  message = gw.waitForMessage(); //wait for a message to process
                    else if (message.header.type == 1){
                    else {
                      Serial.print("Unknow Message Type");
                  UpdateLCD();
                  lcd.clear();
                  lcd.print("Temp:");
                  lcd.print(temp,1);
                  lcd.print("C");
                  lcd.setCursor(0,1);
                  lcd.print("Humi:");
                  lcd.print(hum,1);
                  lcd.print("%");
                andyunoA 1 Reply Last reply
                • S sansespere
                  #include <EEPROM.h>
                  #include <RF24.h>
                  #include <Sensor.h>
                  #include <Time.h>
                  #include <Wire.h>
                  Sensor gw;
                  #define CHILD_ID 1
                    gw.begin();
                    lcd.backlight();
                      else {
                    UpdateLCD();
                    lcd.clear();
                    lcd.print("Temp:");
                    lcd.print(temp,1);
                    lcd.print("C");
                    lcd.setCursor(0,1);
                    lcd.print("Humi:");
                    lcd.print(hum,1);
                    lcd.print("%");
                  andyunoA
                  andyunoA
                  andyuno
                  @sansespere.. Nice work, I don't think I would've got most of that, now that should give me something to work from thanks.
                  • jendrushJ
                    jendrushJ
                    jendrush
                    If someone have this converted to 1.4 version of library please post it.
                    • K
                      K
                      kwest
                      wrote on last edited by kwest
                      Have node №2 child 1 - temp sensor.
                      For example: how to ask the node 2 child 1 value from node №10?
                      • K
                        K
                        kwest
                        This post is deleted!
                        • A
                          A
                          andriej
                          Anyone?
                          @sansespere
                          • F
                            F
                            franklin216
                            wrote on last edited by franklin216
                            I've just found this thread, which describes the Convertion from 1.3 to 1.4:
                            http://forum.mysensors.org/topic/172/convert-sketch-from-1-3-to-1-4
                            I think, the following would do the trick, i will try it, when i am home this evenening:
                            // process incoming messages (like config from server) <-- insert line
                            gw.process(); <-- insert line
                            gw.sendVariable(MONITOR_STATION, CHILD_ID, V_TEMP, temperature, 1); change to --> gw.send(msg.setSensor(CHILD).set(temperature,1).setDestination(MONITOR_STATION)); // send float with one decimal point
                            • AWIA
                              AWIA
                              AWI
                              I would imagine the "royal" way of getting sensor values is requesting them from the controller. In this case the sensor to be read does not need to bother about sending the values to all of the nodes and waking up is not an issue.
                              • Lawrence HelmL
                                Lawrence HelmL
                                Lawrence Helm
                                did anyone convert this succesfully? I'm having some problems, this would make a great example build :) I looked at other ones like "node to node " but something simple like this would be great to start building from..
