  3. Mysensored Garageport
23 Posts 6 Posters 16.1k Views 2 Watching
  • T Offline
    T Offline
    tbowmo
    I've been working on adding mysensor support for my automatic garage ports.
    I started out with this port opener : http://www.jemogfix.dk/fotoweb/dk/pdf/3213_9034002_001.pdf
    popping the cover off, and started measuring in it, I found out that it has a PWM controlled motor, and two relays which reverses the power supply to the motor. Also there is an activate input, so you can have a switch on the wall to open the ports without a remote.
    Everything runs on 5V inside.
    So I created a quick sensor with one of my leftover boards for the sensebender micro, this one only got an atmega328 on it, since I am running on 5V, and sensor / eeprom is 3V only.
    D3 is input from the relay driver activated when OPENING the port
    D4 is input from the relay driver activated when CLOSING the port
    D5 is output controlling light in the controller
    D6 is output activate port pin (driving this to GND will start the motor)
    D7 is input from the original controller, that controls the light.
    With this setup, I can control the light from mysensor network, and can start / stop the motor. I can also detect if motor is opening or closing the port.
    And a "rough" sketch for the port controller firmware :)
    MyMessage msgPort(1, V_STOP);
    MyMessage msgLight(2, V_LIGHT);
    int direction = V_TEMP;
    #define CLOSE_PIN 3
    #define OPEN_PIN  4
    #define LIGHT_PIN    5
    #define ACTIVATE_PIN 6
    #define LIGHT_IN_PIN 7
    #define TIME_TO_ACTIVATE_PORT 30000
    bool last_light_state = false;
      Serial.begin(115200);
      Serial.println("Hello!");
      gw.begin(incomingMessage, 8, true);
      gw.sendSketchInfo("Garage", "1.0");
      // Fetch relay status
      pinMode(CLOSE_PIN, INPUT);
      pinMode(OPEN_PIN, INPUT);
      pinMode(LIGHT_PIN, OUTPUT);
      pinMode(ACTIVATE_PIN, INPUT);
      pinMode(LIGHT_IN_PIN, INPUT);
      gw.present(1, S_COVER); // GaragePort
      gw.present(2, S_LIGHT); // Light
      activatePort();
      digitalWrite(LIGHT_PIN, LOW);
      int incomming = 0;
      if (digitalRead(OPEN_PIN)) {
        sendPortState(V_UP);
      if (digitalRead(CLOSE_PIN)) {
        sendPortState(V_DOWN);
      if (!digitalRead(OPEN_PIN) & !digitalRead(CLOSE_PIN)) {
        sendPortState(V_STOP);
      if (digitalRead(LIGHT_IN_PIN) != last_light_state) {
        Serial.print("Turning light ");
        Serial.println(digitalRead(LIGHT_IN_PIN)?"ON":"OFF");
        digitalWrite(LIGHT_PIN, digitalRead(LIGHT_IN_PIN));
        gw.send(msgLight.set(digitalRead(LIGHT_IN_PIN)));
        last_light_state = digitalRead(LIGHT_IN_PIN);
      gw.process();
    void sendPortState(int pState) {
      if (direction != pState) {
        switch (pState) {
          case V_UP:
            Serial.println(F("opening"));
            break;
          case V_DOWN:
            Serial.println(F("closing"));
            break;
          case V_STOP:
            Serial.println(F("stopped"));
            break;
        gw.send(msgPort.setType(pState));
        direction = pState;
      if (message.sensor == 1 & (message.type == V_UP | message.type == V_DOWN | message.type == V_STOP)) {
        activatePort();
        direction = V_TEMP;
        Serial.println(F("Activate port!"));
      if (message.sensor == 2 & message.type == V_LIGHT ) {
        digitalWrite(LIGHT_PIN, message.getBool()?1:0);
        Serial.print (F("Lights "));
        Serial.println(message.getBool()?"ON":"OFF");
    void activatePort() {
      pinMode(ACTIVATE_PIN, OUTPUT);
      digitalWrite(ACTIVATE_PIN, LOW);
      delay(500);
      digitalWrite(ACTIVATE_PIN, HIGH);
    *Updated sourcecode
    • hekH Offline
      hekH Offline
      Pictures please :)
      • A Offline
        A Offline
        Anticimex
        Pictures or it didn't happen :)
        • T Offline
          T Offline
          tbowmo
          @hek @Anticimex
          Keep calm, and don't panic :) Something happened when I made the initial post, so I couldn't add pictures.. :)
          • hekH Offline
            hekH Offline
            Looks great!
            Hmm.. I don't have a garage door opener... This is a good reason to get one ;)
            • A Offline
              A Offline
              Anticimex
              And the datasheet is predictably veeery vague on the security aspects of that machinery...well, you got everything you need to fix that ;)
              Defining "locked" as when the door is closed and offer a completly unspecified remote dongle leaves some to be desired after all...but at least you should only need to secure the actuation of the motor to secure the garage.
              • T Offline
                T Offline
                tbowmo
                Only one problem left now, domoticz doesn't seem to support mysensored blinds (which I have set it up to mimick, as it has V_UP/V_DOWN/V_STOP as informed by @hek in another thread)
                Domoticz also spews out errors about unknown ID's when it received V_UP/V_DOWN/V_STOP. So I'll have to dig into the code of domoticz as well, to see if I can fix things. On that note, I decided to fetch the latest domoticz, but that is broken, and can't be build :(
                Oh well, the fun life of being a hardware/software "hacker" :)
                @hek I have two ports.. Only one of them with a port opener at the moment, the one I have modified is for the second port, which had been put away since I bought it last year.
                @Anticimex
                Yes, it's a china remote keyfob thing. Also wondering about security. But since I can't lock down the garage fully (It's an old barn, that has a lot of other entries which can't be locked). It's not that big a concern right now.
                A 1 Reply Last reply
                • T tbowmo
                  @Anticimex
                  A Offline
                  A Offline
                  Anticimex
                  @tbowmo well, that makes you the perfect guinea pig for practical security application for MySensors then :D you got nothing to loose if bugs are found ;)
                  • T Offline
                    T Offline
                    tbowmo
                    @Anticimex
                    The normal remotes is still working as well (I have to make this as seamless as possible, as to not confuse the wife, and kids :))
                    • T tbowmo
                      @Anticimex
                      A Offline
                      A Offline
                      Anticimex
                      @tbowmo perhaps we should design a MySensors keyfob :) The sensebender board is a good base for that (although we probably want to offer RF69 variants as well in that case).
                      • T Offline
                        T Offline
                        tbowmo
                        now with Video, for @hek and @Anticimex, so they can see it in "motion"
                        https://www.youtube.com/watch?v=GRaK19IdCCc
                        • T tbowmo
                          A Offline
                          A Offline
                          Anticimex
                          @tbowmo Awesome! What approach did you take? Reverse-engineered the keyfob to route it through the MySensors network or do you use a separate keyfob for the "MySensor path" and retain the original?
                          Or maybe I am reading it the wrong way; you detect the door action and send the status to your controller (Domoticz)?
                          Anyway, it is hacking done properly :D
                          The light is an addition? Relay-actuator for that?
                          • T Offline
                            T Offline
                            tbowmo
                            @Anticimex
                            It's integrated into the opener control box itself. By poking around with a multimeter, I figured out which signals I could use.
                            For Open / Close / Stop status, I just look at the relay drivers, used for reversing the supply to the motor. It has two relays in it, one for each direction.
                            When it opens, it turns on relay 1, start ramping up the PWM to the motor, and when stopping, it ramps down the PWM, and finally turning off relay 1.
                            When it then closes again, it starts by turning on relay 2, ramping up / down PWM signals, and turn of relay 2 again.
                            So it's a "simple" hack :)
                            The unit has inputs for a wall switch, so you can operate it without a remote. This input happens to be 5V as well, that just needs to be grounded. So I have 1 pin for that.
                            The light is a bit more "trickier" :), as it's a built in light (which I will replace with a LED floodlight when I get around to put it up). It's also a relay driver like the motor control. I have put the mysensors module in between the original controller (connected to an input pin on the mysensor module), and then an output to the relay driver. This way I can detect when light is turned on by the original controller, and also switch it on / off from remote.
                            So you won't notice that it's there, until you activate it from domoticz (which I can't at the moment, as it is missing the V_UP/V_DOWN/V_STOP messages that I'm using)
                            • T tbowmo
                              @Anticimex
                              A Offline
                              A Offline
                              Anticimex
                              @tbowmo Yes WAF is an important factor. Changes are usually accepted if they are not noticed :D
                              Good work!
                              • M Offline
                                M Offline
                                Mickey
                                Very nice work.
                                I notice that there are a lot of parts missing in the sensbender I understand you took out sensor and eeprom but I notice some caps and resistors also not attach.
                                can you specify what did you populate the board with only the atmega?
                                T 1 Reply Last reply
                                • M Mickey
                                  Very nice work.
                                  T Offline
                                  T Offline
                                  tbowmo
                                  @Mickey
                                  On this one I only populated the atmega on the board. I removed the vcc pin on the radio module, before I soldered it back to back with the minimal sensebender module, and then put a le33 between vcc on sensebender board, and vcc on the radio (and added a capacitor on the radio, for good measures)
                                  M 1 Reply Last reply
                                  • T tbowmo
                                    @Mickey
                                    M Offline
                                    M Offline
                                    Mickey
                                    @tbowmo said:
                                    @Mickey
                                    and did you flash the the "official" sensebender bootloader ?
                                    • T Offline
                                      T Offline
                                      tbowmo
                                      @Mickey
                                      For this particular one, I haven't used a bootloader at all, as I'm using jtagice3 to download my sketches.
                                      I have a serial terminal attached all the time for debugging, and I find it a bit irritating having to start up the terminal every time I have uploaded a new sketch (using normal arduino serial upload).
                                      So I have this setup when fiddling with stuff :) one window for serial terminal, one for shell where I upload using avrdude, and then the arduino env.
                                      • T Offline
                                        T Offline
                                        tbowmo
                                        Finally got around to mount the motor unit, after heavy modifications. Which also cut the standby power to under a 10th of the original unit.
                                        I ended up implementing my own 5v supply, that powers the logic in the original unit and my mysensor node, I then have a solid state relay, enabling / disabling the 38v rail for the engine part. This drops the standby from 7W to under 0.5W.
                                        I had to go a couple of loopholes to get it working, as the motor unit wouldn't respond to the remote when the 38v rail was missing. I then tapped into the remote signal, so when the remote is detected I power up the thing, I then need to press the button one more time to activate the opener. When the original unit switches of the light, I also power down the 38v rail.
                                        I can activate the port from domoticz, also the lights can be activated by domoticz. There are some small quirks, as the port is reported as open when the port actually is closed. I will have a look at the software for the next port that I have to modify
                                        And last a small demo video.
                                        From the outside with both ports in action (only the right port is mysensored for now)
                                        http://youtu.be/s9UuEDtNf5s
                                        R 1 Reply Last reply
                                        • T tbowmo
                                          R Offline
                                          R Offline
                                          RJ_Make
                                          @tbowmo Was the door on the left added after the building was built? Little strange for the garage door to "block" the smaller door.. :grinning:
                                          RJ_Make
