  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
  • johnecyJ
    johnecyJ
    johnecy
    I have the irrigation controller all setup and working. I have one problem though as soon as I power it up with 5 volts for the pro mini sometimes one sometimes all the relays come on. If I am not home the water runs all day is there a programing change or a wire change I need to make to stop this. I was using the old wire diagram without the pull up on pin 13 of the 74hc I changed to the new version and added the lines off code but it still does not help.
    pndgt0P 1 Reply Last reply
      Are you setting all pins to low during setup?
      • dbemowskD
        dbemowskD
        So I had started this build going on a year ago but never finished it. That was before I found the easy newbie boards which is what I plan on using to resurrect this build. My question is, can this be built using a 3.3V pro mini, or should I be using a 5V one. I am just wondering if I need to set up my newbie board with a 3.3V regulator or not. My other question is on the resistors. I have a bunch of 1/8 watt resistors and was wondering if they would work or if I should go to 1/4 watt. I have all of the parts in my parts bin and with the newbie board it shouldn't take long to put it together, just need direction on those couple things.
          It's hard to answer since you aren't providing many details like is it battery powered? What kind of valves are you using? What are you using those resistors for?
          dbemowskD 1 Reply Last reply
            dbemowskD
            dbemowskD
            @gohan Sorry, I am talking about the schematic for the irrigation controller in the build section of the site. That is why I posted the question here.
            One other thing that I just noticed, and I will post this in the easy newbie board thread also for @sundberg84, I noticed that there is a change in the pins that are broken out on the header on the left side of the board. This is the board that I am using for the build, and I was going to point out here that the schematic below shows to connect D7 and D8 to the shift register, but the REV 8 board that I am using does not break out D8. After looking at the site on the new REV 9 boards, which I have a batch of, he doesn't break out D7 or D8.. The wiring of the pins is completely different between the REV 8 and REV 9 boards. The reason I mention this is that I was going to write something up here explaining the build with a newbie board, but I think I will hold off as it might be confusing to many depending what REV of the board people have.
            Another thing that I just notices is on the schematic. I have a copy of the schematic that I printed last year when I started this build. There has since been a change. In the old schematic that I have it shows the output enable (OE) pin of the shift register grounded, where in the one below, it showsit connected to D6 through a 1K resistor. I can understand that the change is to give arduino control to the output enable line, but because in the other schematic it didn't show D6 connected, and I didn't have D8 broken out, I used D6 in it's place. I may need to rethink some of this. In any case, I will need to make some changes to the sketch prior to uploading it.
            0_1496074195604_upload-c4616651-6dc5-47bb-a4c6-ff77a1936257
            • dbemowskD dbemowsk
              dbemowskD
              dbemowskD
              OK, so I have this built this and have it mostly working with my Vera Plus. Below is a link to a video of a problem I am having.
              http://www.dan.bemowski.info/videos/20170601_004213.mp4
              So my sprinkler system has a pump start relay which gets turned on any time a valve is turned on. Because of this I made a slight hardware modification which thus required a software modification. For the hardware, I ended up using relay number 1 of my 8 channel relay board as my pump start relay control. This I have wired to pin A1. Relays 2 through 8 are connected to the shift register on Qb through Qh (outputs 2-8) skipping output 1. Because of this I had to change how the code defined which valve to start on. To do this, I changed the commented lines removing the (-1) on the bit shift. I made the assumption that in code, the relay numbers start with 0.
              #ifdef ACTIVE_LOW
              //#define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber-1))
              #define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber))
              #define ALL_VALVES_OFF 0xFFFF
              #else
              //#define BITSHIFT_VALVE_NUMBER (1U << (valveNumber-1))
              #define BITSHIFT_VALVE_NUMBER (1U << (valveNumber))
              #define ALL_VALVES_OFF 0U
              Then I needed to define the pump start relay.
              const int pumpStart = A1;
              and then in setup I have this:
                pinMode(pumpStart, OUTPUT);
                digitalWrite (pumpStart, HIGH);
              Lastly, to operate the pump start relay whenever a zone is triggered, this is the updateRelays() function:
              void updateRelays(int value)
                if (value == ALL_VALVES_OFF)
                  digitalWrite(pumpStart, HIGH);
                else
                  digitalWrite(pumpStart, LOW);
                digitalWrite(latchPin, LOW);
                shiftOut(dataPin, clockPin, MSBFIRST, highByte(value));
                shiftOut(dataPin, clockPin, MSBFIRST, lowByte(value));
                digitalWrite(latchPin, HIGH);
              All of this seems to work. When I trigger a zone, I see the pump start relay kick on as well as the triggered zone relay. The only problem I have is that the screen keeps cycling valve data: (1-4) on the screen, as can be seen in the video clip.
              Here is my entire modified sketch that I have uploaded:
              MySprinkler for MySensors
              Arduino Multi-Zone Sprinkler Control
              May 31, 2015
              *** Version 2.0
              *** Upgraded to http://MySensors.org version 1.4.1
              *** Expanded for up to 16 Valves
              *** Setup for active low relay board or comment out #define ACTIVE_LOW to switch to active high
              *** Switch to bitshift method vs byte arrays
              *** Changed RUN_ALL_ZONES Vera device to 0 (was highest valve)
              *** Added optional LCD display featuring remaining time, date last ran & current time
              *** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve data and clock respectively
              *** Added single pushbutton menu to manually select which program to run (All Zones or a Single Zone)
              *** Added option of naming your Zones programmatically or with Vera (V_VAR3 used to store names)
              Utilizing your Vera home automation controller and the MySensors.org gateway you can
              control up to a sixteen zone irrigation system with only three digital pins.  This sketch
              will create NUMBER_OF_VALVES + 1 devices on your Vera controller
              This sketch features the following:
              * Allows you to cycle through All zones (RUN_ALL_ZONES) or individual zone (RUN_SINGLE_ZONE) control.
              * Use the 0th controller to activate RUN_ALL_ZONES (each zone in numeric sequence 1 to n)
                using Variable1 as the "ON" time in minutes in each of the vera devices created.
              * Use the individual zone controller to activate a single zone.  This feature uses
                Variable2 as the "ON" time for each individual device/zone.
              * Connect according to pinout below and uses Shift Registers as to allow the MySensors
                standard radio configuration and still leave available digital pins
              * Turning on any zone will stop the current process and begin that particular process.
              * Turning off any zone will stop the current process and turn off all zones.
              * To push your new time intervals for your zones, simply change the variable on your Vera and
                your arduino will call to Vera once a minute and update accordingly.  Variables will also be
                requested when the device is first powered on.
              * Pushbutton activation to RUN_ALL_ZONES, RUN_SINGLE_ZONE or halt the current program
              * LED status indicator
              PARTS LIST:
              Available from the MySensors store - http://www.mysensors.org/store/
              * Relays (8 channel)
              * Female Pin Header Connector Strip
              * Prototype Universal Printed Circuit Boards (PCB)
              * NRF24L01 Radio
              * Arduino (I used a Pro Mini)
              * FTDI USB to TTL Serial Adapter
              * Capacitors (10uf and .1uf)
              * 3.3v voltage regulator
              * Resistors (270, 1K & 10K)
              * Female Dupont Cables
              * 1602 LCD (with I2C Interface)
              * LED
              * Push button
              * Shift Register (SN74HC595)
              * 2 Pole 5mm Pitch PCB Mount Screw Terminal Block
              * 3 Pole 5mm Pitch PCB Mount Screw Terminal Block
              * 22-24 gauge wire or similar (I used Cat5/Cat6 cable)
              * 18 gauge wire (for relay)
              * Irrigation Power Supply (24-Volt/750 mA Transformer)
              INSTRUCTIONS:
              * A step-by-step setup video is available here: http://youtu.be/l4GPRTsuHkI
              * After assembling your arduino, radio, decoupling capacitors, shift register(s), status LED, pushbutton LCD (I2C connected to
                A4 and A5) and relays, and load the sketch.
              * Following the instructions at https://MySensors.org include the device to your MySensors Gateway.
              * Verify that each new device has a Variable1, Variable2 and Variable3. Populate data accordingly with whole minutes for
                the RUN_ALL_ZONES routine (Variable1) and the RUN_SINGLE_ZONE routines (Variable 2).  The values entered for times may be zero and
                you may use the defaulet zone names by leaving Variable3 blank.
              * Once you have entered values for each zone and each variable, save the settings by pressing the red save button on your Vera.
              * Restart your arduino; verify the settings are loaded into your arduino with the serial monitor; the array will be printed
                on the serial monitor.
              * Your arduino should slow-flash, indicating that it is in ready mode.
              * There are multiple debug serial prints that can be monitored to assure that it is operating properly.
              * ***THIS SHOULD NO LONGER BE NEEDED*** The standard MySensors library now works. https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
              Contributed by Jim (BulldogLowell@gmail.com) with much contribution from Pete (pete.will@mysensors.org) and is released to the public domain
              // Enable debug prints
              //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
              #include <Wire.h>
              #include <TimeLib.h>
              #include <LiquidCrystal.h>
              #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
              #define VALVE_RESET_TIME 7500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
              #define VALVE_TIMES_RELOAD 300000UL  // Change this (in milliseconds) for how often to update all valves data from the controller (Loops at value/number valves)
                                                   // ie: 300000 for 8 valves produces requests 37.5seconds with all valves updated every 5mins
              #define SKETCH_NAME "MySprinkler"
              #define SKETCH_VERSION "2.2"
              #define CHILD_ID_SPRINKLER 0
              #define ACTIVE_LOW // comment out this line if your relays are active high
              #define DEBUG_ON   // comment out to supress serial monitor output
              #ifdef ACTIVE_LOW
              #else
              #ifdef DEBUG_ON
              #define DEBUG_PRINT(x)   Serial.print(x)
              #else
              #define SERIAL_START(x)
              typedef enum {
                STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE, ZONE_SELECT_MENU
              SprinklerStates;
              SprinklerStates state = STAND_BY_ALL_OFF;
              SprinklerStates lastState;
              byte menuState = 0;
              unsigned long menuTimer;
              byte countDownTime = 10;
              int allZoneTime [NUMBER_OF_VALVES + 1];
              int valveSoloTime [NUMBER_OF_VALVES + 1];
              int valveNumber;
              int lastValve;
              unsigned long startMillis;
              const int ledPin = 5;
              const int waterButtonPin = 3;
              bool buttonPushed = false;
              bool showTime = true;
              bool clockUpdating = false;
              bool recentUpdate = true;
              int allVars[] = {V_VAR1, V_VAR2, V_VAR3};
              const char *dayOfWeek[] = {
                "Null", "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
              // Name your Zones here or use Vera to edit them by adding a name in Variable3...
              String valveNickName[17] = {
                "All Zones", "Zone 1", "Zone 2", "Zone 3", "Zone 4", "Zone 5", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
              time_t lastTimeRun = 0;
              //Setup Shift Register...
              const int latchPin = 6;
              const int clockPin = 4;
              const int dataPin  = 7;
              const int outputEnablePin = A0;
              byte clock[8] = {0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0}; // fetching time indicator
              byte raindrop[8] = {0x4, 0x4, 0xA, 0xA, 0x11, 0xE, 0x0,}; // fetching Valve Data indicator
              // Set the pins on the I2C chip used for LCD connections:
              //                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
              LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27. Mine was actually 0x3F
              MyMessage msg1valve(CHILD_ID_SPRINKLER, V_LIGHT);
              MyMessage var1valve(CHILD_ID_SPRINKLER, V_VAR1);
              MyMessage var2valve(CHILD_ID_SPRINKLER, V_VAR2);
              bool receivedInitialValue = false;
              bool inSetup = true;
                DEBUG_PRINTLN(F("Initialising..."));
                pinMode(latchPin, OUTPUT);
                pinMode(clockPin, OUTPUT);
                pinMode(dataPin, OUTPUT);
                pinMode(ledPin, OUTPUT);
                pinMode(outputEnablePin, OUTPUT);
                digitalWrite (outputEnablePin, LOW);
                pinMode(waterButtonPin, INPUT_PULLUP);
                //pinMode(waterButtonPin, INPUT);
                attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
                digitalWrite (ledPin, HIGH);
                DEBUG_PRINTLN(F("Turning All Valves Off..."));
                updateRelays(ALL_VALVES_OFF);
                //delay(5000);
                lcd.begin(16, 2); //(16 characters and 2 line display)
                lcd.clear();
                lcd.backlight();
                lcd.createChar(0, clock);
                lcd.createChar(1, raindrop);
                //check for saved date in EEPROM
                DEBUG_PRINTLN(F("Checking EEPROM for stored date:"));
                delay(500);
                if (loadState(0) == 0xFF) // EEPROM flag
                  DEBUG_PRINTLN(F("Retreiving last run time from EEPROM..."));
                  for (int i = 0; i < 4 ; i++)
                    lastTimeRun = lastTimeRun << 8;
                    lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                DEBUG_PRINTLN(F("Sensor Presentation Complete"));
                digitalWrite (ledPin, LOW);
                DEBUG_PRINTLN(F("Ready..."));
                lcd.setCursor(0, 0);
                lcd.print(F(" Syncing Time  "));
                lcd.setCursor(15, 0);
                lcd.write(byte(0));
                lcd.setCursor(0, 1);
                int clockCounter = 0;
                while (timeStatus() == timeNotSet && clockCounter < 21)
                  requestTime();
                  DEBUG_PRINTLN(F("Requesting time from Gateway:"));
                  wait(1000);
                  lcd.print(".");
                  clockCounter++;
                  if (clockCounter > 16)
                    DEBUG_PRINTLN(F("Failed initial clock synchronization!"));
                    lcd.clear();
                    lcd.print(F("  Failed Clock  "));
                    lcd.print(F(" Syncronization "));
                    wait(2000);
                    break;
                //Update valve data when first powered on
                for (byte i = 1; i <= NUMBER_OF_VALVES; i++)
                  lcd.clear();
                  goGetValveTimes();
                lcd.clear();
                for (byte i = 0; i <= NUMBER_OF_VALVES; i++)
                  present(i, S_LIGHT);
                updateClock();
                updateDisplay();
                goGetValveTimes();
                if (buttonPushed)
                  menuTimer = millis();
                  DEBUG_PRINTLN(F("Button Pressed"));
                  if (state == STAND_BY_ALL_OFF)
                    state = ZONE_SELECT_MENU;
                    menuState = 0;
                  else if (state == ZONE_SELECT_MENU)
                    menuState++;
                    if (menuState > NUMBER_OF_VALVES)
                      menuState = 0;
                  else
                  slowToggleLED ();
                  if (state != lastState)
                    DEBUG_PRINTLN(F("State Changed... all Zones off"));
                      wait(50);
                      send(msg1valve.setSensor(i).set(false), false);
                    lcd.clear();
                    lcd.setCursor(0,0);
                    lcd.print(F("** Irrigation **"));
                    lcd.setCursor(0,1);
                    lcd.print(F("**   Halted   **"));
                    wait(2000);
                    lastValve = -1;
                else if (state == RUN_ALL_ZONES)
                  if (lastValve != valveNumber)
                      if (i == 0 || i == valveNumber)
                        send(msg1valve.setSensor(i).set(true), false);
                      else
                      wait(50);
                  lastValve = valveNumber;
                  fastToggleLed();
                    valveNumber = 1;
                    DEBUG_PRINTLN(F("State Changed, Running All Zones..."));
                  unsigned long nowMillis = millis();
                  if (nowMillis - startMillis < VALVE_RESET_TIME)
                  else if (nowMillis - startMillis < (allZoneTime[valveNumber] * 60000UL))
                    updateRelays(BITSHIFT_VALVE_NUMBER);
                  else
                    DEBUG_PRINTLN(F("Changing Valves..."));
                    startMillis = millis();
                    valveNumber++;
                    if (valveNumber > NUMBER_OF_VALVES)
                      state = CYCLE_COMPLETE;
                      lastValve = -1;
                      lastTimeRun = now();
                      saveDateToEEPROM(lastTimeRun);
                        wait(50);
                      DEBUG_PRINT(F("State = "));
                      DEBUG_PRINTLN(state);
                else if (state == RUN_SINGLE_ZONE)
                  fastToggleLed();
                      else
                      wait(50);
                    DEBUG_PRINTLN(F("State Changed, Single Zone Running..."));
                    DEBUG_PRINT(F("Zone: "));
                    DEBUG_PRINTLN(valveNumber);
                  else if (nowMillis - startMillis < (valveSoloTime [valveNumber] * 60000UL))
                  else
                else if (state == CYCLE_COMPLETE)
                  if (millis() - startMillis < 30000UL)
                    fastToggleLed();
                  else
                  displayMenu();
                else
                  lastState = state;
              void displayMenu(void)
                static byte lastMenuState = -1;
                static int lastSecond;
                if (menuState != lastMenuState)
                  lcd.clear();
                  lcd.print(valveNickName[menuState]);
                  lcd.print(F("Starting"));
                  DEBUG_PRINT(valveNickName[menuState]);
                  Serial.print(F(" Starting Shortly"));
                int thisSecond = (millis() - menuTimer) / 1000UL;
                if (thisSecond != lastSecond && thisSecond < 8)
                  lcd.print(F("."));
                  Serial.print(".");
                lastSecond = thisSecond;
                if (millis() - menuTimer > 10000UL)
                  if (menuState == 0)
                    valveNumber = 1;
                    state = RUN_ALL_ZONES;
                  else
                    valveNumber = menuState;
                    state = RUN_SINGLE_ZONE;
                else
                lastMenuState = menuState;
                else
              void PushButton() //interrupt with debounce
                static unsigned long last_interrupt_time = 0;
                unsigned long interrupt_time = millis();
                if (interrupt_time - last_interrupt_time > 200)
                  buttonPushed = true;
                last_interrupt_time = interrupt_time;
              void fastToggleLed()
                static unsigned long fastLedTimer;
                if (millis() - fastLedTimer >= 100UL)
                  digitalWrite(ledPin, !digitalRead(ledPin));
                  fastLedTimer = millis ();
              void slowToggleLED ()
                static unsigned long slowLedTimer;
                if (millis() - slowLedTimer >= 1250UL)
                  slowLedTimer = millis ();
                bool zoneTimeUpdate = false;
                if (message.isAck())
                  DEBUG_PRINTLN(F("This is an ack from gateway"));
                  if (message.sensor == i)
                    if (message.type == V_LIGHT)
                      int switchState = atoi(message.data);
                      if (switchState == 0)
                        DEBUG_PRINTLN(F("Recieved Instruction to Cancel..."));
                      else
                        if (i == 0)
                          valveNumber = 1;
                          DEBUG_PRINTLN(F("Recieved Instruction to Run All Zones..."));
                        else
                          valveNumber = i;
                          DEBUG_PRINT(F("Recieved Instruction to Activate Zone: "));
                          DEBUG_PRINTLN(i);
                    else if (message.type == V_VAR1)
                      int variable1 = atoi(message.data);// RUN_ALL_ZONES time
                      DEBUG_PRINT(F("Recieved variable1 valve:"));
                      DEBUG_PRINT(i);
                      DEBUG_PRINT(F(" = "));
                      DEBUG_PRINTLN(variable1);
                      if (variable1 != allZoneTime[i])
                        allZoneTime[i] = variable1;
                        zoneTimeUpdate = true;
                      receivedInitialValue = true;
                    else if (message.type == V_VAR2)
                      int variable2 = atoi(message.data);// RUN_SINGLE_ZONE time
                      DEBUG_PRINT(F("Recieved variable2 valve:"));
                      DEBUG_PRINT(i);
                      DEBUG_PRINTLN(variable2);
                      if (variable2 != valveSoloTime[i])
                        valveSoloTime[i] = variable2;
                    else if (message.type == V_VAR3)
                      String newMessage = String(message.data);
                      if (newMessage.length() == 0)
                        DEBUG_PRINT(F("No Name Recieved for zone "));
                        DEBUG_PRINTLN(i);
                        break;
                      if (newMessage.length() > 16)
                        newMessage.substring(0, 16);
                      valveNickName[i] = "";
                      valveNickName[i] += newMessage;
                      DEBUG_PRINT(F("Recieved variable3 valve: "));
                      DEBUG_PRINT(i);
                      DEBUG_PRINTLN(valveNickName[i]);
                if (zoneTimeUpdate)
                  DEBUG_PRINTLN(F("New Zone Times Recieved..."));
                    if (i != 0)
                      DEBUG_PRINT(F("Zone "));
                      DEBUG_PRINT(i);
                      DEBUG_PRINT(F(" individual time: "));
                      DEBUG_PRINT(valveSoloTime[i]);
                      DEBUG_PRINT(F(" group time: "));
                      DEBUG_PRINT(allZoneTime[i]);
                      DEBUG_PRINT(F(" name: "));
                else
                  recentUpdate = false;
              void updateDisplay()
                static unsigned long lastUpdateTime;
                static bool displayToggle = false;
                //static byte toggleCounter = 0;
                static SprinklerStates lastDisplayState;
                if (state != lastDisplayState || millis() - lastUpdateTime >= 3000UL)
                  displayToggle = !displayToggle;
                  switch (state) {
                    case STAND_BY_ALL_OFF:
                      fastClear();
                      if (displayToggle)
                        lcd.print(F("  System Ready "));
                        if (clockUpdating)
                          lcd.write(byte(0));
                        lcd.print(hourFormat12() < 10 ? F(" ") : F(""));
                        lcd.print(hourFormat12());
                        lcd.print(minute() < 10 ? F(":0") : F(":"));
                        lcd.print(minute());
                        lcd.print(isAM() ? F("am") : F("pm"));
                        lcd.print(month() < 10 ? F(" 0") : F(" "));
                        lcd.print(month());
                        lcd.print(day() < 10 ? F("/0") : F("/"));
                        lcd.print(day());
                        lcd.print(F("/"));
                        lcd.print(year() % 100);
                      else
                        lcd.print(F("  Last Watered "));
                        if (clockUpdating)
                          lcd.write(byte(0));
                        lcd.print(dayOfWeek[weekday(lastTimeRun)]);
                        lcd.setCursor(11, 1);
                        lcd.print(month(lastTimeRun) < 10 ? F(" ") : F(""));
                        lcd.print(month(lastTimeRun));
                        lcd.print(day(lastTimeRun) < 10 ? F("/0") : F("/"));
                        lcd.print(day(lastTimeRun));
                      break;
                    case RUN_SINGLE_ZONE:
                      fastClear();
                      if (displayToggle)
                        lcd.print(F("Single Zone Mode"));
                        lcd.print(F(" Zone:"));
                        if (valveNumber < 10) lcd.print(F("0"));
                        lcd.print(valveNumber);
                        lcd.print(F(" Active"));
                      else
                        lcd.print(F(" Time Remaining "));
                        if (valveSoloTime[valveNumber] == 0)
                          lcd.print(F(" No Valve Time "));
                        else
                          unsigned long timeRemaining = (valveSoloTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                          lcd.print(timeRemaining / 60 < 10 ? "   0" : "   ");
                          lcd.print(timeRemaining / 60);
                          lcd.print("min");
                          lcd.print(timeRemaining % 60 < 10 ? " 0" : " ");
                          lcd.print(timeRemaining % 60);
                          lcd.print("sec  ");
                      break;
                    case RUN_ALL_ZONES:
                      fastClear();
                      if (displayToggle)
                        lcd.print(F(" All-Zone  Mode "));
                        lcd.print(F(" Active "));
                      else
                        int timeRemaining = (allZoneTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                        lcd.print((timeRemaining / 60) < 10 ? "   0" : "   ");
                        lcd.print("min");
                        lcd.print("sec  ");
                      break;
                    case CYCLE_COMPLETE:
                      if (displayToggle)
                        lcd.print(F(" Watering Cycle "));
                        lcd.print(F("    Complete    "));
                      else
                        int totalTimeRan = 0;
                        for (int i = 1; i < NUMBER_OF_VALVES + 1; i++)
                          totalTimeRan += allZoneTime[i];
                        lcd.print(F(" Total Time Run "));
                        lcd.print(totalTimeRan < 10 ? "   0" : "   ");
                        lcd.print(totalTimeRan);
                        lcd.print(" Minutes   ");
                    default:
                      // what of ZONE_SELECT_MENU?
                      break;
                  lastUpdateTime = millis();
                lastDisplayState = state;
              void receiveTime(time_t newTime)
                DEBUG_PRINTLN(F("Time value received and updated..."));
                int lastSecond = second();
                int lastMinute = minute();
                int lastHour = hour();
                setTime(newTime);
                if (((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour)) || showTime)
                  DEBUG_PRINTLN(F("Clock updated...."));
                  DEBUG_PRINT(F("Sensor's time currently set to:"));
                  DEBUG_PRINT(hourFormat12() < 10 ? F(" 0") : F(" "));
                  DEBUG_PRINT(hourFormat12());
                  DEBUG_PRINT(minute() < 10 ? F(":0") : F(":"));
                  DEBUG_PRINT(minute());
                  DEBUG_PRINTLN(isAM() ? F("am") : F("pm"));
                  DEBUG_PRINT(month());
                  DEBUG_PRINT(F("/"));
                  DEBUG_PRINT(day());
                  DEBUG_PRINTLN(year());
                  DEBUG_PRINTLN(dayOfWeek[weekday()]);
                  showTime = false;
                else
                  DEBUG_PRINTLN(F("Sensor's time did NOT need adjustment greater than 1 second."));
              void fastClear()
                lcd.print(F("                "));
                lcd.print(F("                "));
              void updateClock()
                static unsigned long lastVeraGetTime;
                if (millis() - lastVeraGetTime >= 3600000UL) // updates clock time and gets zone times from vera once every hour
                  DEBUG_PRINTLN(F("Requesting time and valve data from Gateway..."));
                  lcd.write(byte(0));
                  clockUpdating = true;
                  requestTime();
                  lastVeraGetTime = millis();
              void saveDateToEEPROM(unsigned long theDate)
                DEBUG_PRINTLN(F("Saving Last Run date"));
                if (loadState(0) != 0xFF)
                  saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                for (int i = 1; i < 5; i++)
                  saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
              void goGetValveTimes()
                static unsigned long valveUpdateTime;
                static byte valveIndex = 1;
                if (inSetup || millis() - valveUpdateTime >= VALVE_TIMES_RELOAD / NUMBER_OF_VALVES) // update each valve once every 5 mins (distributes the traffic)
                  if (inSetup) {
                    lcd.print(F(" Updating  "));
                    lcd.print(F(" Valve Data: "));
                    lcd.print(valveIndex);
                  bool flashIcon = false;
                  DEBUG_PRINT(F("Calling for Valve "));
                  DEBUG_PRINT(valveIndex);
                  DEBUG_PRINTLN(F(" Data..."));
                  for (int a = 0; a < (sizeof(allVars)/sizeof(int)); a++) {
                    byte timeout = 10;
                    while (!receivedInitialValue && timeout > 0)
                      flashIcon = !flashIcon;
                      flashIcon ? lcd.write(byte(1)) : lcd.print(F(" "));
                      request(valveIndex, allVars[a]);
                      wait(50);
                      timeout--;
                  valveUpdateTime = millis();
                  valveIndex++;
                  if (valveIndex > NUMBER_OF_VALVES)
                    valveIndex = 1;
              As always, any help is appreciated.
              BulldogLowellB T 2 Replies Last reply
                #ifdef ACTIVE_LOW
                #else
                  else
                May 31, 2015
                *** Version 2.0
                PARTS LIST:
                * NRF24L01 Radio
                * LED
                * Push button
                INSTRUCTIONS:
                #include <Wire.h>
                #ifdef ACTIVE_LOW
                #else
                #ifdef DEBUG_ON
                #else
                typedef enum {
                SprinklerStates;
                byte menuState = 0;
                int valveNumber;
                int lastValve;
                  //delay(5000);
                  lcd.clear();
                  lcd.backlight();
                  delay(500);
                  lcd.write(byte(0));
                    requestTime();
                    wait(1000);
                    lcd.print(".");
                    clockCounter++;
                      lcd.clear();
                      wait(2000);
                      break;
                    lcd.clear();
                    goGetValveTimes();
                  lcd.clear();
                  updateClock();
                  updateDisplay();
                  goGetValveTimes();
                  if (buttonPushed)
                      menuState = 0;
                      menuState++;
                        menuState = 0;
                    else
                    slowToggleLED ();
                        wait(50);
                      lcd.clear();
                      lcd.setCursor(0,0);
                      lcd.setCursor(0,1);
                      wait(2000);
                      lastValve = -1;
                        else
                        wait(50);
                    fastToggleLed();
                      valveNumber = 1;
                    else
                      valveNumber++;
                        lastValve = -1;
                          wait(50);
                    fastToggleLed();
                        else
                        wait(50);
                    else
                      fastToggleLed();
                    else
                    displayMenu();
                  else
                    lastState = state;
                    lcd.clear();
                    lcd.print(F("."));
                    Serial.print(".");
                    if (menuState == 0)
                      valveNumber = 1;
                    else
                  else
                  else
                        else
                          if (i == 0)
                            valveNumber = 1;
                          else
                            valveNumber = i;
                            DEBUG_PRINTLN(i);
                        DEBUG_PRINT(i);
                        DEBUG_PRINT(i);
                          DEBUG_PRINTLN(i);
                          break;
                        DEBUG_PRINT(i);
                  if (zoneTimeUpdate)
                      if (i != 0)
                        DEBUG_PRINT(i);
                  else
                    switch (state) {
                        fastClear();
                        if (displayToggle)
                          if (clockUpdating)
                            lcd.write(byte(0));
                          lcd.print(month());
                          lcd.print(day());
                          lcd.print(F("/"));
                        else
                          if (clockUpdating)
                            lcd.write(byte(0));
                        break;
                        fastClear();
                        if (displayToggle)
                        else
                          else
                            lcd.print("min");
                            lcd.print("sec  ");
                        break;
                      case RUN_ALL_ZONES:
                        fastClear();
                        if (displayToggle)
                        else
                          lcd.print("min");
                          lcd.print("sec  ");
                        break;
                        if (displayToggle)
                        else
                      default:
                        break;
                  setTime(newTime);
                    DEBUG_PRINT(day());
                    showTime = false;
                  else
                void fastClear()
                  lcd.print(F("                "));
                  lcd.print(F("                "));
                void updateClock()
                    lcd.write(byte(0));
                    requestTime();
                    if (inSetup) {
                      byte timeout = 10;
                        wait(50);
                        timeout--;
                    valveIndex++;
                      valveIndex = 1;
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @dbemowsk
                what's happening in the Serial debug?
                • dbemowskD
                  dbemowskD
                  I'll look later and report. Got company at the moment. The odd thing is that I can turn my zones on and they seem to run for the specified time just fine. It's only what I see on the display that is messed up.
                  • Black CatB
                    Black CatB
                    Black Cat
                    I've just started playing with a Z-Uno and was looking at ways to use for a project like this.
                    I'm a believer in not re-inventing the wheel and it seem that all I would need to do is to delete the radio and re-code the sketch for the extra relays ( I have already built a 4 channel relay, it's just getting over the hurdle of learning about Shift Registers).
                    Do you think this is possible or would I be better just starting from scratch?
                    • Black CatB Black Cat
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @Black-Cat said in Irrigation Controller (up to 16 valves with Shift Registers):
                      Z-Uno
                      wicked cool...
                      I'm in North America, so I have to stand by!
                      You you should be able to easily port this for use with Z-Uno...
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @dbemowsk
                        yes, weird...
                          #ifdef ACTIVE_LOW
                          #else
                            else
                          May 31, 2015
                          *** Version 2.0
                          PARTS LIST:
                          * NRF24L01 Radio
                          * LED
                          * Push button
                          INSTRUCTIONS:
                          #include <Wire.h>
                          #ifdef ACTIVE_LOW
                          #else
                          #ifdef DEBUG_ON
                          #else
                          typedef enum {
                          SprinklerStates;
                          byte menuState = 0;
                          int valveNumber;
                          int lastValve;
                            //delay(5000);
                            lcd.clear();
                            lcd.backlight();
                            delay(500);
                            lcd.write(byte(0));
                              requestTime();
                              wait(1000);
                              lcd.print(".");
                              clockCounter++;
                                lcd.clear();
                                wait(2000);
                                break;
                              lcd.clear();
                              goGetValveTimes();
                            lcd.clear();
                            updateClock();
                            updateDisplay();
                            goGetValveTimes();
                            if (buttonPushed)
                                menuState = 0;
                                menuState++;
                                  menuState = 0;
                              else
                              slowToggleLED ();
                                  wait(50);
                                lcd.clear();
                                lcd.setCursor(0,0);
                                lcd.setCursor(0,1);
                                wait(2000);
                                lastValve = -1;
                                  else
                                  wait(50);
                              fastToggleLed();
                                valveNumber = 1;
                              else
                                valveNumber++;
                                  lastValve = -1;
                                    wait(50);
                              fastToggleLed();
                                  else
                                  wait(50);
                              else
                                fastToggleLed();
                              else
                              displayMenu();
                            else
                              lastState = state;
                              lcd.clear();
                              lcd.print(F("."));
                              Serial.print(".");
                              if (menuState == 0)
                                valveNumber = 1;
                              else
                            else
                            else
                                  else
                                    if (i == 0)
                                      valveNumber = 1;
                                    else
                                      valveNumber = i;
                                      DEBUG_PRINTLN(i);
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(i);
                                    DEBUG_PRINTLN(i);
                                    break;
                                  DEBUG_PRINT(i);
                            if (zoneTimeUpdate)
                                if (i != 0)
                                  DEBUG_PRINT(i);
                            else
                              switch (state) {
                                  fastClear();
                                  if (displayToggle)
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.print(month());
                                    lcd.print(day());
                                    lcd.print(F("/"));
                                  else
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                  break;
                                  fastClear();
                                  if (displayToggle)
                                  else
                                    else
                                      lcd.print("min");
                                      lcd.print("sec  ");
                                  break;
                                case RUN_ALL_ZONES:
                                  fastClear();
                                  if (displayToggle)
                                  else
                                    lcd.print("min");
                                    lcd.print("sec  ");
                                  break;
                                  if (displayToggle)
                                  else
                                default:
                                  break;
                            setTime(newTime);
                              DEBUG_PRINT(day());
                              showTime = false;
                            else
                          void fastClear()
                            lcd.print(F("                "));
                            lcd.print(F("                "));
                          void updateClock()
                              lcd.write(byte(0));
                              requestTime();
                              if (inSetup) {
                                byte timeout = 10;
                                  wait(50);
                                  timeout--;
                              valveIndex++;
                                valveIndex = 1;
                          Topdawg2881
                          @dbemowsk
                          I had this same issue. What I did to fix the issue was I commented out in the void loop the line to goGetValveTimes. I then added the timeAlarms library and set a timer to get valve times once every five minutes. The section of code looks like this. Alarm.timerRepeat (300,goGetValveTimes);
                          I inserted that line as the last line of cade in the void setup
                          • dbemowskD
                            dbemowskD
                            Okay, so I was just looking over the code. I first did a search for "Valve Data:" as that was what was showing on the screen. I found that in the goGetValveTimes() method. According to the code, that is only supposed to show if the inSetup variable evaluates to true. I then searched on that variable, and in the code just before the setup() method, I see this:
                            But I don't see anywhere in the code where it sets that value to false. So every time the main loop() calls goGetValveTimes();, it is going to display that since inSetup never gets changed to false. At the very end of the setup routine I see this bit of code:
                                lcd.clear();
                                goGetValveTimes();
                              lcd.clear();
                            I think that it is just after that for loop, or after the lcd.clear(); that it is supposed to set inSetup to false. I have not tested this theory yet as I need to unmount my controller and open it up to push the new code to it, but I am pretty sure that this is the issue. That would explain why everything else with it appears to work normally.
                            I double checked with the example code on the build page to see if possibly I may have deleted something when doing my edits. Looking it over, I found the same thing. If you ask me, this looks to be a bug in the code and it should be fixed and updated.
                            T 1 Reply Last reply
                                  lcd.clear();
                                  goGetValveTimes();
                                lcd.clear();
                              Topdawg2881
                              @dbemowsk
                              I am in front of my computer and I have my controller in front of me and hooked up. Give me a couple minutes and I will run it. See what happens.
                              • dbemowskD
                                dbemowskD
                                #295
                                I just made the change and tested it. That was definitely the problem. Works perfect now.
                                Not sure who can change the example code, but all that needs to be added is this:
                                    lcd.clear();
                                    goGetValveTimes();
                                  lcd.clear();
                                  //Add this line
                                  inSetup = false;
                                      lcd.clear();
                                      goGetValveTimes();
                                    lcd.clear();
                                    //Add this line
                                    inSetup = false;
                                  Topdawg2881
                                  @dbemowsk
                                  You beat me too it. I added the same line in same location and it works perfect. Every so often I see the raindrop icon to show that it is pulling data to update the valve times.
                                  • dbemowskD
                                    dbemowskD
                                    So it is definitely a confirmed bug. I ended up finding some old sample code from when I started this last year and this bit of code was actually in the setup method and not in goGetValveTimes:
                                    So some time in the past year the sample code had been changed.
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @dbemowsk
                                      good to see you found it. I haven't looked at the code for two years, and mine is still working. (@petewill 's demo worked well too). there must have been some change that managed its way into the source
                                      maybe look on GitHub and do a pull request if you the problem is there...
                                      • tombstoneT
                                        tombstoneT
                                        tombstone
                                        Hi I just order all the parts that was listed. Do I need to read the 230 post or it's ok just watched the video.
                                        • tombstoneT tombstone
                                          dbemowskD
                                          dbemowskD
                                          @tombstone You shouldn't need to read all the posts. Maybe just search the thread if you run into any snags. What kind of setup are you dropping this into? Do you currently have valves installed? Does your setup have a master valve or pump relay? Is it a standard 24V AC system?
