  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
  • tombstoneT
    tombstoneT
    tombstone
    Ok I read it all. Just want to start with the basic then change to pH reader soil reader water reader rain detector.
    • tombstoneT
      tombstoneT
      tombstone
      It's really hard to work out what's good post over bad post. Lol
      • tombstoneT
        tombstoneT
        tombstone
        Its my 1st project and I have learnt alot but have got myself a snag and I am getting this....
        Arduino: 1.8.3 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
        C:\Users\HTPC\Documents\Arduino\Irrigation_Controller_1\Irrigation_Controller_1..ino:82:21: fatal error: TimeLib.h: No such file or directory
        #include <TimeLib.h>
        compilation terminated.
        exit status 1
        Error compiling for board Arduino Pro or Pro Mini.
          go to library manager and install Time library
          tombstoneT 1 Reply Last reply
          • tombstoneT
            tombstoneT
            tombstone
            This post is deleted!
            • tombstoneT
              tombstoneT
              tombstone
              • tombstoneT
                tombstoneT
                tombstone
                  tombstoneT
                  tombstoneT
                  tombstone
                  • tombstoneT
                    tombstoneT
                    tombstone
                    ok I almost there :-D but my pro mini has just Analog 1 to 3. I say I have to change the coda were abouts...
                    I also have not setup up my Vera Controller as I see you have to pay...
                    Is there another one that is eazy as I have try some but can not get it to work. eg HomeGenie is download and on my pc but don't think its not to good. don't know how to find my pro mini. happy to chagaen to someing eazer to get me started thanks guys....
                    • tombstoneT
                      tombstoneT
                      tombstone
                      Domoticz LOOKS :-D GOOD
                      BUT new to all this :-D
                      • Black CatB
                        Black CatB
                        Black Cat
                        If you are looking for Software, try openhab.
                        You need to buy Vera, but the software is free.
                        • Black CatB Black Cat
                          tombstoneT
                          tombstoneT
                          tombstone
                          @Black-Cat thanks 😁
                          • tombstoneT
                            tombstoneT
                            tombstone
                            ok so when adding to Domoticz..
                            I go to hardware...
                            I name is..... test...
                            then choose.. MySensors Gateway with LAN interface....
                            Data Timeout: .... Disabled.....
                            Remote Address.... (I have tryed)....
                            IP Address, Subnet Mask, Default Gateway, Primary DNS, Secondary DNS.
                            (i try everythinbg I can think of and still not work)
                            Port: ... 5003
                            My pro min has the red light on and blink blue occassionally.
                            what I get from the Domoticz log is
                            2017-07-30 18:00:00.627 Error: MySensors: Can not connect to: 61.9.211.33:5003
                            2017-07-30 18:00:00.627 TCP: Connection problem (Unable to connect to specified IP/Port)
                            2017-07-30 18:00:00.627 TCP: Reconnecting in 30 seconds...
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @tombstone
                              What hardware are you using for the gateway? Arduino, Sensebender GW, ESP8266, is it wired or wireless?
                              Does it get an IP address from your router?
                              Can you successfully telnet to the above IP address on port 5003? (And what is the output)
                              Does the gateway send any logs to the serial port? If yes, then post them on the forum.
                              • tbowmoT tbowmo
                                @tombstone
                                tombstoneT
                                tombstoneT
                                tombstone
                                @tbowmo
                                The hardware I'am using for the gateway is the Arduino pro mini and its wireless from the NRF24L01+ 2.4GHz Wireless Transceiver
                                I don't know if it is getting IP address from my router.
                                have not use telnet before (I have just youtube it and enabled it... all what i got from youtube was that you can send email lol cool)
                                Does the gateway send any logs to the serial port? If yes, then post them on the forum. (were do I get them logs the ones from Domoticz and below but not much info to go on)
                                Thanks :-D
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @tombstone
                                  How is the promini connected to the device runnning domoticz?
                                  To me it sounds like that you have the promini connected directly to your computer where domoticz is running, then you should add it as a serial gateway, and not ethernet gateway
                                  If you haven't already done this, I suggest that you read about the mysensors network so you have a basic understanding on how mysensors works.
                                  • tbowmoT tbowmo
                                    @tombstone
                                    tombstoneT
                                    tombstoneT
                                    tombstone
                                    wrote on last edited by tombstone
                                    #317
                                    @tbowmo
                                    I have it runing both ways but with serial gateway there no errors but when going to setup there is no NODES.
                                    2017-07-30 19:20:55.764 TCP: Connection problem (Unable to connect to specified IP/Port)
                                    2017-07-30 19:20:55.766 TCP: Reconnecting in 30 seconds...
                                    2017-07-30 19:21:26.035 TCP: Reconnecting...
                                    2017-07-30 19:21:37.093 MySensors: TCP/IP Worker stopped...
                                    2017-07-30 19:27:03.150 MySensors: Using serial port: COM4
                                    • tombstoneT tombstone
                                      @tbowmo
                                      tombstoneT
                                      tombstoneT
                                      tombstone
                                      #318
                                      @tombstone
                                      //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
                                      IS there someing I have missed with adding NODES???
                                      gohanG 1 Reply Last reply
                                      • tombstoneT
                                        tombstoneT
                                        tombstone
                                        3 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        11 TSM:INIT:TSP OK
                                        13 TSM:FPAR
                                        15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        2022 !TSM:FPAR:NO REPLY
                                        2024 TSM:FPAR
                                        2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        4034 !TSM:FPAR:NO REPLY
                                        4036 TSM:FPAR
                                        4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        6046 !TSM:FPAR:NO REPLY
                                        6048 TSM:FPAR
                                        6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        8058 !TSM:FPAR:FAIL
                                        8059 TSM:FAIL:CNT=1
                                        8061 TSM:FAIL:PDT
                                        18065 TSM:FAIL:RE-INIT
                                        18067 TSM:INIT
                                        18074 TSM:INIT:TSP OK
                                        18076 TSM:FPAR
                                        18078 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        20086 !TSM:FPAR:NO REPLY
                                        20088 TSM:FPAR
                                        20090 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        22099 !TSM:FPAR:NO REPLY
                                        22102 TSM:FPAR
                                        22104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        24112 !TSM:FPAR:NO REPLY
                                        24114 TSM:FPAR
                                        24116 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        26124 !TSM:FPAR:FAIL
                                        26125 TSM:FAIL:CNT=2
                                        26127 TSM:FAIL:PDT
                                        36130 TSM:FAIL:RE-INIT
                                        36132 TSM:INIT
                                        36140 TSM:INIT:TSP OK
                                        36142 TSM:FPAR
                                        36144 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        38152 !TSM:FPAR:NO REPLY
                                        38154 TSM:FPAR
                                        38156 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        40164 !TSM:FPAR:NO REPLY
                                        40166 TSM:FPAR
                                        40168 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        42176 !TSM:FPAR:NO REPLY
                                        42178 TSM:FPAR
                                        42180 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        44188 !TSM:FPAR:FAIL
                                        44189 TSM:FAIL:CNT=3
                                        44191 TSM:FAIL:PDT
                                        54194 TSM:FAIL:RE-INIT
                                        54196 TSM:INIT
                                        54203 TSM:INIT:TSP OK
                                        54205 TSM:FPAR
                                        54207 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        56215 !TSM:FPAR:NO REPLY
                                        56217 TSM:FPAR
                                        56219 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        58227 !TSM:FPAR:NO REPLY
                                        58229 TSM:FPAR
                                        58231 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        60239 !TSM:FPAR:NO REPLY
                                        60241 TSM:FPAR
                                        60243 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        62252 !TSM:FPAR:FAIL
                                        62254 TSM:FAIL:CNT=4
                                        62255 TSM:FAIL:PDT
                                        72258 TSM:FAIL:RE-INIT
                                        72260 TSM:INIT
                                        72267 TSM:INIT:TSP OK
                                        72269 TSM:FPAR
                                        72271 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        74280 !TSM:FPAR:NO REPLY
                                        74283 TSM:FPAR
                                        74285 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        76293 !TSM:FPAR:NO REPLY
                                        76295 TSM:FPAR
                                        76297 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        78305 !TSM:FPAR:NO REPLY
                                        78307 TSM:FPAR
                                        78309 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        80317 !TSM:FPAR:FAIL
                                        80318 TSM:FAIL:CNT=5
                                        80320 TSM:FAIL:PDT
                                        90323 TSM:FAIL:RE-INIT
                                        90326 TSM:INIT
                                        90333 TSM:INIT:TSP OK
                                        90335 TSM:FPAR
                                        90337 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        92345 !TSM:FPAR:NO REPLY
                                        92347 TSM:FPAR
                                        92349 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        94357 !TSM:FPAR:NO REPLY
                                        94359 TSM:FPAR
                                        94361 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        96369 !TSM:FPAR:NO REPLY
                                        96371 TSM:FPAR
                                        96373 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        98381 !TSM:FPAR:FAIL
                                        98383 TSM:FAIL:CNT=6
                                        98384 TSM:FAIL:PDT
                                        108387 TSM:FAIL:RE-INIT
                                        108389 TSM:INIT
                                        108396 TSM:INIT:TSP OK
                                        108398 TSM:FPAR
                                        108401 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        110408 !TSM:FPAR:NO REPLY
                                        110410 TSM:FPAR
                                        110413 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        112420 !TSM:FPAR:NO REPLY
                                        112422 TSM:FPAR
                                        112425 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        114433 !TSM:FPAR:NO REPLY
                                        114435 TSM:FPAR
                                        114438 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        116445 !TSM:FPAR:FAIL
                                        116447 TSM:FAIL:CNT=7
                                        116449 TSM:FAIL:PDT
                                        This is my debug log. will like to know if there some thing I missed as I learning thanks :+1:
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @tombstone
                                          Just to be sure, you have one pro mini with NRF24 working as a gateway, connected to your computer?
                                          And then you have one (or more) pro minis also with NRF24, acting as nodes?
