  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 581.7k Views 69 Watching
  • rvendrameR rvendrame
    More from the 'guru'
    "There is no input fuse, that is the reason I recommend one and it has to be a real fuse that blows, not a fuse that will automatic recover. The only time it is supposed to blow is if the converter blows and then you want the mains permanently disconnected. Probably a 0.2A slow fuse will work."
    mvdarend
    @rvendrame Thanks for the clarification.
    • Z
      Z
      Zeph
      And a 250VAC fuse is fine to use on 120VAC (and in fact quite common).
      • petewillP
        petewillP
        petewill
        Ok, how does this look for parts?
        70 degree (Celsius) fuses - http://www.ebay.com/itm/10pcs-Thermal-Cutoffs-SEFUSE-Microtemp-Thermal-TF-Cutoff-NEC-Fuses-73-C-240-C-/221560426284?var=&hash=item339607cf2c
        .75A fuse - They are fast blow not slow like specified above. Does that matter?? http://www.ebay.com/itm/40Pcs-ELECTRIC-FUSE-FAST-BLOW-0-75A-250VAC-35A-IR-THROUGH-HOLE-/271902224922?hash=item3f4ea2b21a
        Same MOVs http://www.ebay.com/itm/LOT-of-10-MAIDA-METAL-OXIDE-VARISTOR-RADIAL-MOV-8mm-Disk-150V-D68ZOV151RA03-/390095815756?hash=item5ad385c44c
        Is there anything else I'm missing? The goal with all this is to make another "how to" video so I want to make sure I'm not giving people bad advice.
        So, it would look something like this (ignore power to radio, didn't have time to wire it):
        • rvendrameR
          rvendrameR
          rvendrame
          @petewill . the MOV goes in parallel with HLK input (and not in series like you did).
          It was suggested to use .2A fuses (instead the .75A). And the Thermal fuse should be glued on HLK top (my guess).
          ESP8266 GW + mySensors 2.3.2
          Alexa / Google Home
          • petewillP
            petewillP
            petewill
            Dang, totally forgot about all that in my rush to finish the diagram before lunch ended... That's why you guys design the electronics and I make the videos ;)
            How necessary are the .2A fuses? I couldn't find any on ebay at a reasonable price. Is the goal of this fuse to prevent large surges (like lightning) from hitting the MOV, or something else? If it's to prevent large surges would the .75A work ok?
            Also, I was able to find cheaper varistors. I'm thinking 150VAC should work ok because the HLK is designed to handle 240VAC but maybe I'm off on that?
            http://www.ebay.com/itm/5-x-Zinc-Oxide-Varistor-150VAC-15J-1200A-7mm-FREE-SHIPPING-/321024816822?hash=item4abe91f6b6
            How does this look?
            SparkmanS 2 Replies Last reply
            • petewillP petewill
              How does this look?
              SparkmanS
              SparkmanS
              Sparkman
              wrote on last edited by Sparkman
              #226
              As long as you only feed it with 120VAC, there's no issue with that. For those that will feed it with 240VAC, they need to use it with a MOV rated above that.
              Cheers
              Al
              PS Here's an option from Digikey: http://www.digikey.com/product-detail/en/MOV-10D241K/MOV-10D241K-ND/2407562
                How does this look?
                SparkmanS
                SparkmanS
                Sparkman
                #227
                The fuse serves two purposes, one to protect if the current draw of the power supply exceeds its rated capacity and the other to blow if the varistor starts conducting a large amount of current in a spike situation. A .75A will still provide protection, but will take a longer time to blow. You want to make sure the fuse doesn't blow because of the in-rush current at start-up, which a fast-blow fuse may do. Typically you want the fuse to be sized at about 150% max of the rated capacity so I would not exceed .3A.
                Cheers
                Al
                petewillP 1 Reply Last reply
                • SparkmanS Sparkman
                  Cheers
                  Al
                  petewillP
                  petewillP
                  petewill
                  @Sparkman
                  I am in the USA so I will only be feeding it with 120VAC, but I will make sure to note that anyone using 240VAC will need a different value varistor.
                  the fuse should be after the varistor in the circuit
                  Ok, I'm still a little confused. Are you saying it should be 120VAC -> Varistor -> Fuse -> HLK? Or, 120VAC -> Fuse -> Varistor -> HLK? I thought it was the second one but maybe I misunderstood.
                  Also, I found some fuses that are rated at 300mA! Not a bad price either!
                  http://www.ebay.com/itm/Ceramic-Slow-Blow-Fuse-3-6-x-10mm-Axial-Leads-125V-250V-0-1A-6-3A-10-30pcs-/111433875797?var=&hash=item19f1fa0155
                  I think I am almost ready to start ordering parts. I am excited for this build! If anyone else has any feedback please let me know. Thanks!
                  SparkmanS 1 Reply Last reply
                    @Sparkman
                    SparkmanS
                    SparkmanS
                    Sparkman
                    @petewill said:
                    @Sparkman
                    Sorry, the wording I used was unclear and was based on the 120VAC being on the right in your diagram :-). Yes, it is 120VAC -> Fuse -> Varistor -> HLK.
                    Cheers
                    Al
                      @petewill said:
                      @Sparkman
                      Cheers
                      Al
                      petewillP
                      petewillP
                      petewill
                      @Sparkman Great, thanks! The parts have been ordered. Can't wait!
                      • C ceech
                        This one is not "safe", but it is an In-Wall AC to DC converter. Transformerless. With a 3A Solid state relay:
                        The converter output is 3.3V at 100mA and the solid state relay is a Triac.
                        F
                        F
                        Fabien
                        Do you have some shcematic of this board ? I'd like to adapt it for 2 relays
                        C 1 Reply Last reply
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          Can anyone give me ebay-links to the parts I need to order to use the HLK with 230V.
                          I am getting a little confused about all the links.
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            wrote on last edited by rvendrame
                            #233
                            This is the one I sent to be reviewed:
                            http://www.aliexpress.com/item/Free-Shipping-1pcs-lot-HLK-PM01-AC-DC-220V-to-5V-mini-power-supply-module-intelligent/32408565688.html
                            Alexa / Google Home
                            • Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              Ok thanks, but I meant the fuses, varistors and stuff.
                                petewillP
                                petewillP
                                petewill
                                @Cliff-Karlsson
                                I haven't tested any of these parts yet but this is what I ordered. I am in the USA so this is spec'd for 120 VAC. If you're using 240 you will need to change the size of the Varistor but everything else should be fine for 240.
                                Varistor for 120VAC - http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                73°C Thermal Fuse - http://www.ebay.com/itm/221560426284?_trksid=p2057872.m2749.l2649&var=520415979885&ssPageName=STRK%3AMEBIDX%3AIT
                                250V 300mA Slow Blow Fuse - http://www.ebay.com/itm/111433875797?_trksid=p2057872.m2749.l2649&var=410420838583&ssPageName=STRK%3AMEBIDX%3AIT
                                HLK-PM01 - http://www.ebay.com/itm/351418782712?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                • F Fabien
                                  C
                                  C
                                  ceech
                                  @Fabien @DrJeff Here is a link to board and schematic files for the transformerless AC-DC converter:
                                  https://github.com/ceech/AC_SR087
                                  DrJeffD 1 Reply Last reply
                                    MartinP
                                    Would this varistor work with 240v?
                                    http://www.ebay.com/itm/10-x-Zinc-Oxide-Varistor-250VAC-60J-2500A-10mm-/260848704608?hash=item3cbbcb5c60
                                    • C ceech
                                      DrJeffD
                                      DrJeffD
                                      DrJeff
                                      @ceech can't look at the files right now is this a dimmer switch that is transformerless?
                                      • DrJeffD DrJeff
                                        C
                                        C
                                        ceech
                                        @DrJeff Yes
                                        • C ceech
                                          @DrJeff Yes
                                          DrJeffD
                                          DrJeffD
                                          DrJeff
                                          @ceech Thanks yet again!
