  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 581.7k Views 69 Watching
  • M MartinP
    Would this varistor work with 240v?
    http://www.ebay.com/itm/10-x-Zinc-Oxide-Varistor-250VAC-60J-2500A-10mm-/260848704608?hash=item3cbbcb5c60
    petewillP
    petewillP
    petewill
    @MartinP Based on my limited knowledge, yes, that should work. Maybe someone else can chime in to confirm?
    SparkmanS 1 Reply Last reply
    • F
      F
      Fabien
      thank you @ceech
      • petewillP petewill
        SparkmanS
        SparkmanS
        Sparkman
        I would personally go with a higher voltage rating. Something like 15-20% higher than your normal voltage otherwise you may get regular nuisance trips. So for a 240 VAC system, I would use something close to 290V.
        Cheers
        Al
        petewillP 1 Reply Last reply
        • SparkmanS Sparkman
          Cheers
          Al
          petewillP
          petewillP
          petewill
          @Sparkman Thanks!
          • RJ_MakeR
            RJ_MakeR
            RJ_Make
            20150929_193752.jpg :stuck_out_tongue:
            RJ_Make
            YveauxY petewillP 2 Replies Last reply
            • RJ_MakeR RJ_Make
              YveauxY
              YveauxY
              @ServiceXp :+1: long evening ahead :satisfied:
              • Steve CasterS
                Steve CasterS
                Steve Caster
                Hi all,
                I was wondering, I want to be able to adress my blinds using mysensors. Using the relay, radio etc works fine, yet I am still wondering on this power supply. So using the above component I basically prevent fire by using the thermal fuse and an overload by using a regular fuse, the varistor and the HLK.
                Now, I am using a Nano (I have still 15 of those) which appear to be using 230mA, the radio itself and a relay. The relay (from the spec sheet) uses 180mA. This should be ok to be used with the HLK shown above. Now, my main concern is, how do you make a all sit together nicely? Is there a PCB type of board you are using? Any pointers welcome :)
                Kind regards
                Steve
                • F
                  F
                  filipq
                  Hi Steve
                  this may be useful http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board
                  Regrads
                  Filip
                  • RJ_MakeR RJ_Make
                    petewillP
                    petewillP
                    petewill
                    @ServiceXp Nice! Let us know how it goes.
                    • F
                      F
                      filipq
                      Another one http://forum.mysensors.org/topic/1586/roller-shutter
                      • C
                        C
                        cygnus
                        I'm planning on using the HLK-PM01 with the extra precautions discussed here; gluing a thermal fuse on top of the HLK-PM01 and adding a fuse and varistor.
                        My only problem right now is that I'm unable to find a good source for 0.3A slow blow fuses with axial leads on eBay. The only variants I can find are without leads and it feels a bit unnecessary to add a fuse holder to the circuit since the fuse is meant to be non-replaceable. The ones that petewill posted a link to are out-of-stock. Does anyone have any good suggestion where to find good fuses to use?
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          @cygnus said:
                          HLK-PM01
                          +1
                          • C cygnus
                            SparkmanS
                            SparkmanS
                            Sparkman
                            Looks like the .4A ones are in stock. I would just go with those.
                            Cheers
                            Al
                            • GertSandersG
                              GertSandersG
                              GertSanders
                              found these:
                              http://www.aliexpress.com/item/Free-Shipping-25pcs-0-25A-250mA-250V-3-6x10mm-Fuse-Slow-Blow-Glass-Axial-Leaded/32452469177.html?spm=2114.01020208.3.138.0Cb2oJ&ws_ab_test=201556_3,201527_3_71_72_73_74_75,0_0
                              • Cliff KarlssonC
                                Cliff KarlssonC
                                Cliff Karlsson
                                #255
                                If I want to use a relay for in-wall use. Could I use the same Slow Blow fuse, thermal fuse and varistor to get it to be more safe?
                                • N
                                  N
                                  novicit
                                  This has been an excellent thread! I am left with one practical question though. How does one safely mount the thermal fuse on the HLK-PM01? Even if the thermal fuse thru hole on the PCB was exactly next to the middle of the HLK-PM01, the lead will still need to run 2+cm to the top of the HLP-PM01, then another 2+cm back down to the PCB. Only the thermal glue holds it in place. It seems it could easily come loose with minimal pressure - and remember it is 110 or 220V! Of course the leads would be protected by electrical tape or shrink tube, but it is still not firmly secured. Plus it is more likely that the leads on both sides would be closer to 3cm, plus the 1 cm for the fuse for a total of ~7cm of high voltage 'leads' not securely tied down to the PCB. I am only a hobbyist, so I am curious to hear others thoughts on this. Also, note that this board (http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board) has great protection, even fuse & varistor on the low voltage side. How would one mount a thermal fuse on the HLK-PM01 without having a 'loose' lead running to the top of the HLK? Or am I over concerned.
                                  • GertSandersG
                                    GertSandersG
                                    GertSanders
                                    I would suggest that the PCB have a cutout UNDER the HLK-PM01, so that you could stick the termal fuse under the powermodule against the bottom.
                                    If you look at the images of an opened powermodule, then you will see that the internal PCB is on top. I would expect the heat from any problem to be noticable on the bottom as well.
                                    Could be a safer option (less long wires) ?
                                    • TD22057T
                                      TD22057T
                                      TD22057
                                      This has been a great thread with a lot of good information. I'm still a little worried about putting something like this in my wall though. What are peoples thoughts on benefits of this approach versus using something like a Samsung cube charger which is about a 28 mm cube (without the prongs), handles 120/240 V, and is probably very safe?
                                      • GertSandersG
                                        GertSandersG
                                        GertSanders
                                        My guess is that the HLK-PM01 is of the same quality, but it only gives 700mA @ 5V. On my repeater it never feels warm at all (and this is in a completely closed box).
                                        You could add a temp sensor to monitor and set an alarm in your home control system, maybe a solution to feel more secure.
                                        • lrtsenarL
                                          lrtsenarL
                                          lrtsenar
                                          What do you think about this ? 1.79$ 5V @ 700mA dim: 3cm x 2cm x 1.8cm :
                                          http://www.ebay.fr/itm/321846469504?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                          alexsh1A 1 Reply Last reply
