  3. Low Power shutdown mode?
13 Posts 3 Posters 5.7k Views 1 Watching
  • B
    B
    brolly759
    I am using the BinarySwitchSleepSensor sketch. It uses a pin interrupt on pin 2/3 connected GND to switch. When the switch is not engaged I am getting 23-24uA. When the switch is engaged I am drawing 117uA.
    How can I reduce these numbers even further? I know there is a powerdown/shutdown mode(Cant find how to do it) and maybe adding external resistors to lower the current draw but what does everyone else recommend?
    • NeverDieN
      NeverDieN
      Also, what's the lowest current draw for each mode that anyone is currently getting? That would help establish a target as to what's achievable.
      • B
        B
        brolly759
        Okay, some more news on my front. I downgraded from the latest build of Arduino to 1.0.6 and now here are my numbers for BinarySwitchSleepSensor sketch:
        Sleep mode w/o switch engaged: 2.5uA !!!!!!
        Sleep mode w switch engaged: 98-100uA.
        Now I need to find a way to have the switch engaged use very little current. Any idea's?
        • NeverDieN
          NeverDieN
          Maybe I'm getting confused with the LPC810 MCU, but doesn't Arduino also support both falling and rising edge triggered interrupts? If so, couldn't you set one of those and then go back to sleep?
          c.f. http://jeelabs.org/book/1517e/
          • B
            B
            brolly759
            Here is information pertaining to interrupts and Arduino:
            http://playground.arduino.cc/Code/Interrupts
            Here is the code from the library:
            #define SKETCH_NAME "Binary Sensor"
            #define SKETCH_MAJOR_VER "1"
            #define SKETCH_MINOR_VER "0"
            #define PRIMARY_CHILD_ID 3
            #define SECONDARY_CHILD_ID 4
            #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
            #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
            #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
            #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
            #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
            #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
            #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
            #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
            #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
            #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
            MySensor sensor_node;
            MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
            MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
              sensor_node.begin();
              // Setup the buttons
              pinMode(PRIMARY_BUTTON_PIN, INPUT);
              pinMode(SECONDARY_BUTTON_PIN, INPUT);
              // Activate internal pull-ups
              digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
              digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
              sensor_node.sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER"."SKETCH_MINOR_VER);
              // Register binary input sensor to sensor_node (they will be created as child devices)
              sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
              sensor_node.present(SECONDARY_CHILD_ID, S_DOOR);
              uint8_t value;
              static uint8_t sentValue=2;
              static uint8_t sentValue2=2;
              sensor_node.sleep(5);
              value = digitalRead(PRIMARY_BUTTON_PIN);
              if (value != sentValue) {
                 // Value has changed from last transmission, send the updated value
                 sensor_node.send(msg.set(value==HIGH ? 1 : 0));
                 sentValue = value;
              value = digitalRead(SECONDARY_BUTTON_PIN);
              if (value != sentValue2) {
                 sensor_node.send(msg2.set(value==HIGH ? 1 : 0));
                 sentValue2 = value;
              // Sleep until something happens with the sensor
              sensor_node.sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
            • NeverDieN
              NeverDieN
              Yup, "They are triggered equally on RISING or FALLING signal edges..." So, it should work. :smile:
              • B
                B
                brolly759
                Hate to act like the idiot here but can you explain what I should do? lol
                • AWIA
                  AWIA
                  AWI
                  wrote on last edited by AWI
                  The higher power with the engaged switch probably comes from the pull-up. There is a current through the switch when closed. You can increase the value to reduce consumption. If you use internally pull-up the value is between 20k and 50k which gives you around (ohms law I=U/R) I=3.3/20.000=165uA
                  • B
                    B
                    brolly759
                    I did increase the value of the resistance by 60K and 100K externally, both those values dropped the current consumption but my problem was that there was not enough to power to have the Arduino read that the switch was working. So I was getting nothing basically. I put the resistor in line between the switch. Even when I had that amount of Resistance used I was still drawing 34uA or greater, still above what I am trying to get.
                    AWIA 1 Reply Last reply
                    • B brolly759
                      AWIA
                      AWIA
                      AWI
                      @brolly759 you should remove /switch of the internal pull-up (digitalWrite). And conmect the external resistor from the Arduino pin to Vcc. 1 Mohm should be sufficient to drop current to the uA range.
                      • B
                        B
                        brolly759
                        @AWI
                        So Pin 2 -> 1Mohm Resistor -> VCC
                        and GND is the switch to Pin 2 ?
                        Is that a minimum current the Arduino needs to read a state change?
                        • AWIA
                          AWIA
                          AWI
                          Yes it is. The same configuration like with the internal pull-up. digital pins
                          • B
                            B
                            brolly759
                            SO an update, I connected a 10Mohm Resistor and my current draw is only 3.1-3.2uA when the switch is engaged and 2.7-2.8uA when the switch is removed. I think that is really livable numbers. So far not getting any false positives which is great. :)
