  3. Domoticz
  4. How do I send a REST command?
4 Posts 3 Posters 4.3k Views 1 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    Hi I just managed to integrate my first mysensors.org switch into domoticz. If I flick the switch it gets updated correctly in domotiz, and now I want to send a REST command witch look like this whenever the switch is switched:
    "PUT 192.168.0.22:4455/devices/{udn} The body should be "application/json" as {"STATE": true } "
    How do I do this? I guess i need to write a script somehow and place it in the right folder and then specifying it under the switch options.
    But I have no idea of how to write a script for this.
    • Q Offline
      Q Offline
      Qu3Uk
      An example of using the Domoticz api over http would be http://192.168.0.22:4455/json.htm?type=command&param=switchlight&idx=99&switchcmd=On
      Not sure where you got your info from but the API is detailed here.
      Domoticz API
        Cliff Karlsson
        But will that send a PUT command? And where do I enter the body info:{"STATE": true }
        • P Offline
          P Offline
          pjr
          wrote on last edited by pjr
          What are you trying to archieve with this? What is the receiving end?
          I think you can send your "ajax call" from lua script with os.execute method using curl if you are in linux enviroment.
          commandArray = {}
          if (devicechanged['NameOfYourSwitch'] == 'On') then
            os.execute('/usr/bin/curl -X PUT -d STATE=true 192.168.0.22:4455/devices/{udn}')
          else if(devicechanged['NameOfYourSwitch'] == 'Off') then
            os.execute('/usr/bin/curl -X PUT -d STATE=false 192.168.0.22:4455/devices/{udn}')
          end
          return commandArray
          And give it a name with prefix: script_device_xxxxxxx.lua where xxxxxxx is name for your script. Then domoticz will launch it everytime some device state changes. Location for it is script/lua under your domoticz folder.
          12.2k
