  3. gw to node: isalive ?
17 Posts 3 Posters 7.1k Views 1 Watching
  • epierreE
    epierreE
    epierre
    is there a way to have the controller ask a node and see if it is alive ?
    z-wave - Vera -> Domoticz
    hekH 1 Reply Last reply
    • epierreE epierre
      @epierre
      Yea, but it must be awake and answer replies (of your choice).
      • epierreE
        epierreE
        epierre
        hello, the warersensor is always awake but sending a 2;5:2;35 ; doesn't bring back value.... that is why I'm asking for help
        • marceltrapmanM
          marceltrapmanM
          marceltrapman
          I also have this with the repeater ("ARDIUNO_RELAY").
          I want to make sure that this and all sensors are available by asking them for their version and sketch but they do not always reply so it seems...
          Fulltime Servoy Developer
          epierreE 1 Reply Last reply
          • epierreE epierre
            What exactly are you trying to send here? 35? How does your code look like? Are you handling the incoming message in the sensor and create a reply back to controller?
              epierreE
              epierreE
              epierre
              @hek hi, I've added nothing yet but your answer make me realize there is no query logic by default in tbe sensor.
              • marceltrapmanM marceltrapman
                epierreE
                epierreE
                epierre
                @marceltrapman what kind of message do you send ? I don't see in the API you can request internal values...
                @hek would the ack be aplicable to all sensors ?
                • epierreE epierre
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  @epierre I am working on my plugin for Indigo.
                  This is what these messages look like:
                  2014-07-16 21:59:18.267	MySensors Debug	Sending command 2;0;3;0;2;Get Version
                  2014-07-16 21:59:18.267	MySensors Debug	Sending command 2;0;3;0;11;Get Sketch Name
                    epierreE
                    epierreE
                    epierre
                    @marceltrapman it did not work for me... but tje sensor is back again to my higjer satisfaction...
                    @hek it is importantbfor an alarm ti ping its node to know if there is signal jamming...
                    • epierreE epierre
                      marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      @epierre said:
                      @marceltrapman tje sensor is back again to my higjer satisfaction...
                      Nice.
                      Looking at Indigo and Z-wave there is the same issue. A node that is asleep can not be awoken from Indigo (or any other controller).
                      The reason I would like this to be different is so that I know that a sensor has fallen out (battery dead or otherwise).
                      The problem is that waking a sensor up means that the sensor has to listen.
                      When a sensor listens it has to be awake (I believe).
                      Vicious Circle...
                        Nice.
                        Vicious Circle...
                        epierreE
                        epierreE
                        epierre
                        @marceltrapman yes...in my case some are not asleep... not to say all... in z-wave the hysteresis management is good, controller ofter fairly manage device that always send something every 2h...
                          A better approach is probably to send in something every time sensor wakes up.
                          epierreE marceltrapmanM 2 Replies Last reply
                            epierreE
                            epierreE
                            epierre
                            @hek well if sensor sends something I know it is awoken ;-) I'll try implement something on my water sensor on this !
                              marceltrapmanM
                              marceltrapmanM
                              marceltrapman
                              wrote on last edited by marceltrapman
                              @hek @epierre
                              While thinking about this I think I want to add a 'wake-interval' like implemented in z-wave (and exposed in Indigo).
                              I want to be able to set a wake interval to every 5, 10, 15, 20, 30, 45 minutes, 1, 2, 4 hours, twice per day, once per day or once per week.
                              Not sure if this is something for me to do or that this belongs in the libraries...
                                @hek @epierre
                                @marceltrapman
                                This could very well be implemented with the current libraries.
                                You could for instance request VAR_1 every time the sensor wakes up which contains the sleep time used when putting Arduino to sleep..
                                This would make sleep time configurable from controller-side.
                                  @marceltrapman
                                  marceltrapmanM
                                  marceltrapmanM
                                  marceltrapman
                                  Hah, gonna use that!!!!!!
                                    epierreE
                                    epierreE
                                    epierre
                                    @marceltrapman @hek that would mean sketched upgrade, but I plus it !
