  3. Sketch for powerconsumption
2 Posts 2 Posters 1.1k Views 2 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    I want to use one of the sensors from the mysensors.org ebay links. The blue power consuption clamp. But are there any premade sketches? Does it work in the same way where you connect it to vcc/gnd/sensor pin?
    S 1 Reply Last reply
      Sparkman
      wrote on last edited by Sparkman
      @Cliff-Karlsson Here's a good example as to how to use them: http://openenergymonitor.org/emon/node/58. You'd have to combine their sketch with a MS sketch, but that shouldn't be too difficult. Note that a clamp on current transformer can produce high voltages without a burden resistor and should never be used without being connected. See the Safety section on this page for more info: http://openenergymonitor.org/emon/buildingblocks/ct-sensors-introduction.
      Cheers
      Al
      12.0k
