  3. Serial GW to Raspberry USB connection, which tty ?
2 Posts 2 Posters 1.1k Views 1 Watching
  • S
    Splinteer
    Hi everyone,
    I build a serial gateway (based on an Arduino nano v3) that I'll plug to a Raspberry that will house a NodeJS controller.
    I would like to have my Arduino to communicate with the rpi over usb.
    So my questions are :
    How can I tell the gateway to use the usb to send the data ? (I'm using the default serialgateway code)
    And on the RPI which tty should I connect to ?
    Thanks !
    • YveauxY
      YveauxY
      Login to the RPi, plugin your USB serial device and type in a console:
      dmesg | grep tty
      which will return something like
      [145.376756] usb 5-1: pl2303 converter now attached to ttyUSB0
      The serial device is now available at /dev/ttyUSB0
