  3. Can't get relay to work
9 Posts 3 Posters 3.9k Views 2 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I have used the relay sketch unmodified but cant get it to work. I get a lightswitch in domoticz but nothing happens when I toggle it.
    I tested using the simple blink- sketch and used the relays "in" instead of a led and the relay turns on and of without problem. But it seems like the relay sketch never sets the pin to high.
     * Version 1.0 - Henrik Ekblad
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON HIGH  // GPIO value to write to turn on attached relay
    #define RELAY_OFF LOW // GPIO value to write to turn off attached relay
    //MyTransportRFM69 radio;
    //MySigningNone signer;
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      gw.process();
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    • sundberg84S
      It doesnt set to High unless you get a repons from Domoticz i think. This happens to my device also sometimes (one i have in the far end of the house). Sometimes when its not getting trought the radiomsg it doesnt switch the relay. Do you have a cap on the radio?
      It could also be a power issue - do you have the relay with seperate power or do you power it from the arduino?
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        @sundberg84 said:
        lay. Do y
        I have caps on all radios and I tested with them onli like 1,5m apart. I am powering from arduino and have tried both 5v an VIN. But as I said it works when using a simple blink-sketch. I have also tried tapping the "in" on the relay with a wire from 3.3v and 5v from the arduino and it clicks every time. So there is nothing wrong electricly, I am just not getting any signal from domoticz when turning on/off.
        • sundberg84S
          If you are powering it from Arduino that might be the problem. The relay needs good power source or the radio will fail. Try to take the power directly from the 5v
          • sundberg84S
            This is from my blog (swedish) image where you see tha power wiring,
            It can also be good to take the 5V from source but run the ground through the arduino.
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              I don´t really understand but If I power the relay using 5v from a psu, then I cant get eny response when connecting any pin/power from the arduino to the "in" on the relay. But If I take another 5v from the psu and connect it to the "in " on the relay then it switches.
              If I use 5v and gnd from a nano to power it and a pin for the "in" on the relay then it also works. But I cant turn it on/of from domoticz. If the radio and relay is using to much power would the sktch still show up in domoticz like normal?
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                Ahhhh!!, finally got it! I missed that I had to connect both GND from the arduino and "-" from the psu to the same connector.
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  spoke too soon. Still cant toggle from domoticz. But now I can switch the relay by tapping 5v from the arduino to the "in" terminal. But still domoticz does not actually turn the pin to high when clicking on the lightbulb icon.
                  This is the relay:
                  link text
                  M 1 Reply Last reply
                    This is the relay:
                    link text
                    malarcy
                    @Cliff-Karlsson - I may be way off base here and I am new to this myself - but, does that sketch you quoted actually compile? - I ask because it looks like you have used the relay sample on the mysensors site - but cut out some of the loop.
                    The bit that sets the output pin that the relay is connected to pinMode (pin, OUTPUT) .....
                    From what you have posted, you haven't got pin defined anywhere - in the original example it gets declared in the line
                    for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++)
                    In your sketch i can't see pin or sensor defined - so I can't see how it's compiling....... but I may have missed something
                    If I have general advice would be check what pin the relay is connected to, and make sure thats that one you set as output and the one that you do the digitalWrite to.
                    Hope this helps - but if not - sorry if I am way off base.
