  3. Request sent to unavailable sensor
3 Posts 2 Posters 1.4k Views 1 Watching
  • M Offline
    M Offline
    marceltrapman
    wrote on last edited by marceltrapman
    I am trying to receive the version of 2 sensors.
    The first sensor is in the network, the second sensor is not available.
    While doing so I seem to have 3 issues:
    1. It looks like the last request is executed first.
    2. In this case the request fails but other than through the debug output I don't know that it fails.
    3. It looks like the fail also makes that the other outgoing requests stop.
    The problem is that I am not entirely sure because I am debugging my plugin but I have tried several things without succes.
    Below is the debugging output.
    MySensors Debug    received '0:0' Arduino startup complete.
    MySensors Debug    receive raw 0;0;3;2;1.4b1 (18848a2)
    MySensors Debug    received '0:0' Arduino library version update to 1.4b1 (18848a2)
    MySensors Debug    receive raw 0;0;3;9;send: 0-0-1-2 s=0,c=3,t=11,pt=0,l=15,st=fail:Get Sketch Nam
    MySensors Debug    receive raw 0;0;3;9;send: 0-0-1-2 s=255,c=3,t=2,pt=0,l=11,st=ok:Get VersionName
    Fulltime Servoy Developer
    Y 1 Reply Last reply
    • M marceltrapman
      Y Offline
      Y Offline
      @marceltrapman build the wireless sniffer ;-) . It will probably give you the answer!
      M 1 Reply Last reply
      • Y Yveaux
        M Offline
        M Offline
        marceltrapman
        @Yveaux Only for the 3rd issue.
        I know why it fails, the sensor is not installed.
        But what I want, I am building my own Indigo plugin (in case you missed that part), is for the plugin to see that it goes wrong so that I can show that in the ui.
