  3. Domoticz
  4. Can't see any sensors in Domoticz
6 Posts 3 Posters 4.1k Views 2 Watching
  • ErrKE
    ErrKE
    ErrK
    Hi.
    I have just started to build my sensors and now i got a problem that i hope you can help me with.
    I am using version 1.5.1 of the API.
    Have a ESP8266 Gateway that i only change ssid and password from the example sketch.
    In Domoticz (version 2.3799) i have added the gateway as an "MySensors Gateway with LAN interface" with the right ip and port 5003.
    I can see in the log in Domoticz
    2015-12-12 22:03:52.065 MySensors: connected to: 10.0.1.6:5003
    2015-12-12 22:03:52.066 MySensors: Gateway Ready...
    I have also created a MotionSensor and the logg when i start it is looks like this.
    sensor started, id=255, parent=255, distance=255
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    find parent
    find parent
    find parent
    find parent
    The log for my gateway when i trigger a motion infront of my MotionSensor is this.
    0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
    So i think it looks like the gateway can see what the MotionSensor send.
    But i can't find the MotionSensor in Domoticz.
    I am also using the Domoticz for my z-wave components.
    Any one that can give me some tips on what i do wrong?
    • sundberg84S
      id=255 means it has not got any ID yet, strange.
      What does the gw log looks like when you power on the node?
      • ErrKE
        ErrKE
        ErrK
        Thanks for your quick response.
        When i start the gateway it looks like this.
        rlx00l��|x00�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��l��bn�|l����b��nn�x00l��l`�nnl`nr���n��l`r��n��l`��n�
        ESP8266 MySensors Gateway
        Connecting to XXX
        ...Connected!
        IP: 10.0.1.6
        And when i start the motionSensor it looks like this in the gateway.
        0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
        255;255;3;0;3;
        255;255;3;0;3;
        255;255;3;0;3;
        255;255;3;0;3;
        In the motionsensor it looks like this.
        sensor started, id=255, parent=0, distance=1
        req id
        send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
        req id
        req id
        req id
        req id
        I have now connect them to two seperate usb ports on my Mac to use the serial monitor.
        • ErrKE
          ErrKE
          ErrK
          I have now tried to reuplode the sketch to both the gateway and the sensor.
          I think the problem is with the gateway.
          Look here at the log.
          tail 0
          chksum 0x42
          csum 0x42
          Connecting to XXX
          ...Connected!
          IP: 10.0.1.6
          Client 0 connected
          255;255;3;0;3;
          Client 0: 0;0;3;0;2;
          Exception (28):
          epc1=0x4000bf80 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
          ctx: cont
          sp: 3ffeac40 end: 3ffeaec0 offset: 01a0
          >>>stack>>>
          3ffeade0:  00000080 3fffc6fc 3ffe977f 40203ac0
          3ffeadf0:  3ffeaf20 00000001 3ffe8f8f 4020b794
          3ffeae00:  3ffeaf20 00000009 3ffe9872 00000000
          3ffeae10:  00000003 00000000 3ffe9860 4020ae11
          3ffeae20:  00000001 3ffe9869 3ffeaf20 4020ae11
          3ffeae30:  3ffe9869 3ffe9869 3ffeaf20 3ffeaf20
          3ffeae40:  3ffe9869 3ffe9778 3ffe977f 402024b4
          3ffeae50:  3ffe9a68 3ffe9869 00000000 40202784
          3ffeae60:  3ffe8e18 00000000 000003e8 3ffe9bf8
          3ffeae70:  00000000 3fff4c28 3fff4bb8 3ffeaeec
          3ffeae80:  00000000 0000000a 00000000 00000000
          3ffeae90:  40201c35 0601000a 00000000 3ffeaeec
          3ffeaea0:  3fffdc20 00000000 3ffeaee4 40201c92
          3ffeaeb0:  00000000 00000000 3ffe9ea0 40100378
          <<<stack<<<
           ets Jan  8 2013,rst cause:2, boot mode:(1,7)
           ets Jan  8 2013,rst cause:4, boot mode:(1,7)
          wdt reset
          It craches when i connect the sensor.
          mppM 1 Reply Last reply
          • ErrKE
            ErrKE
            ErrK
            Now this is working.
            I use Arduino 1.6.5 and develop version of mysensors API (1.6.0-beta) .
            Here is how it looks in Domoticz
            • ErrKE ErrK
              tail 0
              chksum 0x42
              csum 0x42
              Connecting to XXX
              ...Connected!
              IP: 10.0.1.6
              Client 0 connected
              255;255;3;0;3;
              Exception (28):
              ctx: cont
              >>>stack>>>
              <<<stack<<<
              wdt reset
              mppM
              mppM
              mpp
              @ErrK, see this topic http://www.esp8266.com/viewtopic.php?f=6&t=10901
              I had the same issue, pressing reset didn't work but reconnecting the USB cable did the trick.
              MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
