  3. [Solved] ESP8266 Wifi Gateway problem to connect a sensor
2 Posts 1 Posters 1.6k Views
  • ErrKE
    ErrKE
    ErrK
    Hi.
    I started with a thred yesterday in the Domoticz but i think that the problem is not with Domoticz.
    I am using a Mac and have connect both the Gateway and the Sensor to it just to be able to use Serial Monitor.
    Running now on develop version (1.6.0-beta as it says when the sensor starts)
    I use a ESP8266 Wifi Gateway.
    The sensor i have built is a motion sensor on a Arduino mini pro 5v.
    It looks like this in the logs after i uploaded the sketch
    Starting sensor (RNNNA-, 1.6.0-beta)
    Radio init successful.
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    find parent
    find parent
    find parent
    Init complete, id=255, parent=255, distance=255
    I can see that it triggers something in the serial monitor when i move the sensor.
    It looks like this
    find parent
    find parent
    find parent
    find parent
    In the gateway the it looks like this
    0;0;3;0;9;Client 0: 0;0;3;0;18;PING
    0;0;3;0;9;read and forward: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0
    0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
    The PING is from Domoticz.
    When i reconnect the sensor to the usb port.
    It looks like this in the Gateway
    I have tried to reconnect the sensor but i got the same problem.
    Any one know what i can do next?
    • ErrKE
      ErrKE
      ErrK
      After a few hours of trying this i now working.
      I reconnect all the wiring and then it start to work.
      It must have been som problem with the wiring.
      Now i use Arduino 1.6.5 and develop version of mysensors API.
