  3. 💬 Sensebender Micro
💬 Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 52.3k Views 38 Watching
  • D Dominic Amann
    I assume there is no exposure to the SPI bus on this board?
    @Dominic-Amann from the hardware site:
    MYSx 2.6 with
    Dedicated UART
    Dedicated SPI
    Dedicated Interrupts
    I2C bus (shared with onboard eeprom)
    • D
      D
      Dominic Amann
      Ah - right, the radio connector uses SPI.
      • tbowmoT
        tbowmoT
        tbowmo
        @Dominic-Amann
        There are multiple SPI ports in use, one of them is dedicated to the expansion header (which follows MYSx 2.6 standard)
        • R
          R
          RWoerz
          Can somebody please post what this boards current draw is at 8Mz w/wo a radio. Because it will live in a crawl space It's going to be plugged in. I've also added a very simple water detector.
          • tbowmoT
            tbowmoT
            tbowmo
            @RWoerz
            normal operating frequency is 48Mhz (if I remember right).. If I remember right, then there is no options in arduino to switch the frequency to 8Mhz..
            • sburlotS
              sburlotS
              sburlot
              Beware that the Si7021 can return a RH value < 0 or > 100, and Domoticz will not store it. Clamp the humidity to a valid range to avoid losing values.
              Lately, my Sensebender reported values of 101-104 during the night. Took me some time to understand why Domoticz complained it didnt receive any values.
              It received these values, but didnt like them.
              See section 5.1.1 of the Si7021 datasheet says:
              Due to normal variations in RH accuracy of the device as described in Table 4, it is possible for the measured value of %RH to be slightly less than 0 when the actual RH level is close to or equal to 0. Similarly, the measured value of %RH may be slightly greater than 100 when the actual RH level is close to or equal to 100. This is expected behavior, and it is acceptable to limit the range of RH results to 0 to 100%RH in the host software by truncating values that are slightly outside of this range.
              • D
                D
                dklinkman
                So cool that the micro as a node reports its battery level to the UI (I'm still on the FTDI power, hence > 100%)
                -d
                • stefaanvS
                  stefaanvS
                  stefaanv
                  Is there a board definition for sensebender micro for PlatformIO available ?
                  • stefaanvS stefaanv
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @stefaanv
                    https://forum.mysensors.org/topic/2725/sensebender-micro/29
                      mvader
                      wrote on last edited by mvader
                      #70
                      Am I able to remote reboot the sensebender micro? I can send an OTA firmware if i manually press the reset button.
                      but can i use the reboot command in MYScontroller? it doesn't seem to do anything when issued.
                      tbowmoT 1 Reply Last reply
                      • M mvader
                        tbowmoT
                        tbowmoT
                        tbowmo
                        @mvader
                        Is it the default dualoptiboot bootloader? Then the bootloader itself does not support OTA FW. You need to put a sketch on it, that supports OTA. (Default sensebender micro sketches doesn't)
                        • tbowmoT tbowmo
                          @mvader
                          mvader
                          #72
                          @tbowmo said in 💬 Sensebender Micro:
                          @mvader
                          yes it's the default bootloader. yes i have OTA added to the sketch. it works if i reset the device via manual reset. but what i'd like to do is send the reboot command from myscontroller. but it seems to do nothing ever. does the bootloader support reboot? or is that something i also have to add to the sketch?
                          situation: i have about 15 sensors all over the house. if i update, i'd like to be able to assign the firmware, and then issue the reboot command. so upon reboot, they take the assigned firmware. what i don't want to do is have to go to each one and manually press the reset button to get it to take the firmware. i'm sure it's healthier to run up and down 3 flights of stairs. but i'm lazy :)
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @mvader
                            The sketch should support reboot, try sending I_REBOOT to one of your nodes (info can be found here, look under internal messages)
                            I haven't tried it myself yet, as I haven't touched my sensebender micros for ages..
                            • joaoabsJ
                              joaoabsJ
                              joaoabs
                              Three questions regarding SenseBender Micro:
                              • What board should I configure in Arduino IDE in order to upload sketches? Would it be equivalent to Arduino mini pro, or is there any "board library" to load ?(Didn't find it, Woudn't it make sense to be included in the examples/Libraries pack?)...
                                (Found it: https://github.com/mysensors/ArduinoBoards . If you look between the photos above there is a simple link lost in the between)
                                MySensors Admins: Just a small suggestion: As it is now, - a simple link between photos is easily overlooked. Can't you place it near the specs where it should be more visible?
                              • It has an I2C bus for the SI7021, but it seems the ATSHA204A (which I believe its I2C also) is connected to another pin (a3). Does this mean it has two I2C buses?
                              • Can anyone confirm that the port that measures the battery voltage is A0?
                              Thanks,
                              Joaoabs
                              AnticimexA 1 Reply Last reply
                              • joaoabsJ joaoabs
                                Thanks,
                                Joaoabs
                                AnticimexA
                                AnticimexA
                                Anticimex
                                #75
                                @joaoabs we do not support I2C variant of atsha204a. Only single wire variant.
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @joaoabs
                                  It uses the internal vref to measure the battery voltage. Some of the theory is described here https://www.sciencetronics.com/greenphotons/?p=1521
                                  • joaoabsJ
                                    joaoabsJ
                                    joaoabs
                                    For the battery powering voltage measuring do you mean that this is not needed after all? (https://www.mysensors.org/build/battery#measuring-and-reporting-battery-level)
                                    It would be just a matter of enabling the flag "#define BATT_SENSOR 199 " and no resistors needed?
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @joaoabs
                                      Yes, when you power it directly of f.ex. two AA batteries, then you can use the secret trick mentioned in that article that I linked to, for measuring battery voltage without external resistors.
                                      • joaoabsJ
                                        joaoabsJ
                                        joaoabs
                                        Sorry for the dummy question, but my SenseBender Micros came with a small white sticker on top of the Si7021 sensor (like in the pictures above). Is it supposed to be removed or to stay like that?
                                        • joaoabsJ joaoabs
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @joaoabs the datasheet for the device clarifies that I believe
