  3. πŸ’¬ Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 52.3k Views 38 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @joaoabs
    Just leave it on..
    • N
      N
      NailMan
      Hello!
      Help me understand why the sketches are not loaded in Sensebender Micro - there is a synchronization error:
      avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x82
      avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x82
      avrdude: stk500_recv(): programmer is not responding
      • FTDI connected via 3.3V jumper
      • Another device built on the SB Micro with SB bootloader is also not flashed with the same error, but on the PC of my friend, sketches successfully loaded into the device and on my PC are given the correct data when working sketch
      • device and serial port are selected correctly
      • mySensors Lib and device packs(AVR, SAMD) installed with standard lib and device managers(and also added path https://raw.githubusercontent.com/mysensors/ArduinoBoards/master/package_mysensors.org_index.json in the settings menu)
      • at the same time if I take a pure Pro Mini and load into it any sample sketch of mySensors package - it will successfully do it and will work.
      What am I doing wrong and how do I get the Sensebender Micro to take sketches?
      tbowmoT 1 Reply Last reply
      • N NailMan
        Hello!
        tbowmoT
        tbowmoT
        tbowmo
        @nailman
        Did you select the sensebender micro as target in Arduino? Is it the same FTDI device that is used on both computers?
        N 1 Reply Last reply
        • tbowmoT tbowmo
          @nailman
          N
          N
          NailMan
          @tbowmo
          Yes, of course, I chose the target device "Sensebender Micro -> "Atmega328p, 1mhz" and "Atmega328p, 8mhz"(for device (RGBW controller) based on SB Micro with 8Mhz quartz resonator).
          I tried three different FTDIs.
          With any other Arduino (with native loaders) there are no problems with these FTDI adapters.
          alexsh1A 1 Reply Last reply
          • N NailMan
            @tbowmo
            alexsh1A
            alexsh1A
            alexsh1
            @nailman At what Mhz does your RGBW Controller is running now?
            It seems to be the problem is in identifying the correct board.
            If I have a board running at 1Mhz and try to program it at 8Mhz, similar to your error would come up, i.e. not in sync
            • tbowmoT
              tbowmoT
              tbowmo
              Unless the bootloader is reprogrammed, then it defaults to 8mhz, and you have to actively set registers to run at 1mhz in your sketch.
              Do you have a ISP programmer? If yes, could you make a memory dump, and send it to me?
              • joaoabsJ
                joaoabsJ
                joaoabs
                Coming back to the battery powering topic: I was checking some SlimNode code and it uses #include <Vcc.h> library to report battery level. I can see in that the example code above doesn't use it. Does anyone know what is the difference? Which is better?
                Thanks,
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @joaoabs
                  Could you post a link to the code from slimnode?
                  • joaoabsJ
                    joaoabsJ
                    joaoabs
                    wrote on last edited by joaoabs
                    #89
                    The slimnode original thread has a few (not sure anymore which example I'm using now because the thread is huge and I've lost track of it)
                    Here is one example:
                    https://forum.mysensors.org/topic/2067/my-slim-2aa-battery-node/306
                    and other:
                    https://forum.mysensors.org/topic/2067/my-slim-2aa-battery-node/116
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      #90
                      @joaoabs
                      The library use the exact same method to read VCC, as the Sensebender Micro example. It's just the functions that is extracted into a library (which I think have been done by @Yveaux )
                      • tbowmoT tbowmo
                        N
                        N
                        NailMan
                        @tbowmo
                        I apologize for the delay in replying, I was very busy with work.
                        It turned out to be some mystical incompatibility of the FTDI and Sensbender Micro or a device based on its loader. Three versions of my FTDI refused to work with Sensbender Micro, but they worked with regular Arduino, and the fourth one, bought on AliExpress, works perfectly normal. Externally, all the same, only those that do not work with Sensbender Micro, the labeling of the chip differs slightly in the quality of engraving on the plastic.
                        Maybe it's fake or some kind of non-standard chips.
                        • N NailMan
                          @tbowmo
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @nailman There are a lot of fake FTDI modules. Some are labelled FTDI other claim to be FTDI but are CH340. Some have DTR others RST and good ones like Adafruit Friend it is selectable.
                          My recommendation is do not try to save a few bucks here. Spend money on a good quality FTDI adapter like Adafruit Friend.
                          • F
                            F
                            flybysun
                            I'm using the mysensor lib for a while but I recently run into problems. I've some arduino pro minis running with dht22 sensors which send their data over nrf24 to an mqtt ethernet gateway.
                            But maybe someone can help me with this one: I have build my own sensebender-micro modules. First of all I programmed the fuses of the mega328p as follows: lfuse: 0xE2, hfuse: 0xD2, efuse: 0xFE. Then I've programmed the DualOptiBoot Bootloader to them, everything worked fine so far, I can upoload sketches from the Arduino IDE via FTDI Programmer. The Problem: When I upload the official example sketch and watch the serial monitor I just see the MySensors splash screen. It seems, that the sketch does not even run into the setup routine. This starts to make me crazy, since I do not even know where to search. If I upload other sketches (basic blinking led, serial port examples or the passive node example from mysensors) it shows that my hardware in general seems to work. When I enable debug this is the output:
                             __  __       ____
                                    |___/                      2.3.0
                            16 MCO:BGN:INIT NODE,CP=RNONA---,VER=2.3.0
                            26 TSM:INIT
                            28 TSF:WUR:MS=0
                            36 TSM:INIT:TSP OK
                            38 TSF:SID:OK,ID=100
                            40 TSM:FPAR
                            75 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            2084 !TSM:FPAR:NO REPLY
                            2086 TSM:FPAR
                            2121 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            4130 !TSM:FPAR:NO REPLY
                            4132 TSM:FPAR
                            4167 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            6176 !TSM:FPAR:NO REPLY
                            6178 TSM:FPAR
                            6213 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            8222 !TSM:FPAR:FAIL
                            8224 TSM:FAIL:CNT=1
                            8226 TSM:FAIL:DIS
                            8228 TSF:TDI:TSL
                            18229 TSM:FAIL:RE-INIT
                            18231 TSM:INIT
                            18239 TSM:INIT:TSP OK
                            18241 TSF:SID:OK,ID=100
                            18243 TSM:FPAR
                            18280 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            20289 !TSM:FPAR:NO REPLY
                            Even the NRF24 connection seems to work. This is the output of my mosquitto broker when running the passive node example:
                            home/OpenMQTTGateway/LWT Online
                            home/OpenMQTTGateway/version 0.7
                            mygateway1-out/100/255/0/0/17 2.3.0
                            mygateway1-out/100/255/3/0/6 255
                            mygateway1-out/100/255/3/0/11 Passive node
                            mygateway1-out/100/255/3/0/12 1.0
                            mygateway1-out/100/0/0/0/6 (null)
                            mygateway1-out/100/0/1/0/0 25.70
                            mygateway1-out/100/0/1/0/0 26.90
                            mygateway1-out/100/0/1/0/0 27.30
                            mygateway1-out/100/0/1/0/0 25.80
                            mygateway1-out/100/0/1/0/0 26.00
                            I appreciate any help, thanks in advance!
                            Cheers
                            • F flybysun
                               __  __       ____
                                      |___/                      2.3.0
                              26 TSM:INIT
                              28 TSF:WUR:MS=0
                              36 TSM:INIT:TSP OK
                              40 TSM:FPAR
                              2086 TSM:FPAR
                              4132 TSM:FPAR
                              6178 TSM:FPAR
                              8222 !TSM:FPAR:FAIL
                              8224 TSM:FAIL:CNT=1
                              8226 TSM:FAIL:DIS
                              8228 TSF:TDI:TSL
                              18231 TSM:INIT
                              18243 TSM:FPAR
                              Cheers
                              Hi @flybysun, welcome to the forum!
                              !TSM:FPAR:NO REPLY
                              means that the sensor node does not get a response from the gateway. What type of gateway are you using? Could you post the debug log from it?
                              If you haven't already, check https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to troubleshoot them. (Hint: Power supply is the most common problem, the nrf24 is extremely picky)
                              • F
                                F
                                flybysun
                                Hi @mfalkvidd, thanks for the warm welcome!
                                So, tonight I'll give it another try. I soldered 1000uF above VCC and GND on both the sender and the gateway RF Links (that's all I could find here for now). Still got issues. Here are the logs from my gateway, when it starts up and receives values from my working sensor I had before:
                                0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.3.0
                                3 TSM:INIT
                                4 TSF:WUR:MS=0
                                11 TSM:INIT:TSP OK
                                12 TSM:INIT:GW MODE
                                14 TSM:READY:ID=0,PAR=0,DIS=0
                                17 MCO:REG:NOT NEEDED
                                580 GWT:TPC:IP=192.168.0.222
                                1583 MCO:BGN:STP
                                1584 MCO:BGN:INIT OK,TSP=1
                                1587 GWT:TPC:IP=192.168.0.222
                                2589 GWT:RMQ:MQTT RECONNECT
                                2797 GWT:RMQ:MQTT CONNECTED
                                2800 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
                                20587 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:32.5
                                20592 GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/1,MSG SENT
                                55353 TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:27.3
                                55358 GWT:TPS:TOPIC=mygateway1-out/1/1/1/0/0,MSG SENT
                                55364 TSF:MSG:READ,1-1-0,s=0,c=1,t=1,pt=7,l=5,sg=0:32.6
                                55369 GWT:TPS:TOPIC=mygateway1-out/1/0/1/0/1,MSG SENT
                                This looks okay I guess, now this happens when I activate my SenseBender Micro:
                                139854 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                139859 TSF:MSG:BC
                                139860 TSF:MSG:FPAR REQ,ID=3
                                139864 TSF:PNG:SEND,TO=0
                                139866 TSF:CKU:OK
                                139868 TSF:MSG:GWL OK
                                140512 !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                141940 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                141945 TSF:MSG:BC
                                141947 TSF:MSG:FPAR REQ,ID=3
                                141949 TSF:CKU:OK,FCTRL
                                141952 TSF:MSG:GWL OK
                                142632 !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                144021 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                144026 TSF:MSG:BC
                                144028 TSF:MSG:FPAR REQ,ID=3
                                144030 TSF:CKU:OK,FCTRL
                                144033 TSF:MSG:GWL OK
                                144746 !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                146101 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                146106 TSF:MSG:BC
                                146108 TSF:MSG:FPAR REQ,ID=3
                                146111 TSF:CKU:OK,FCTRL
                                146113 TSF:MSG:GWL OK
                                146857 !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                I filled this logs into the Log Parser and found out that the Gateway receives informations on the sensor node, but when it responses it does not get the ACK from the sensor node.
                                May I have a faulty NRF24? I just received a new batch from AliExpress and this my first try with them.
                                My gateway is an Arduino Uno Board with the Arduino Ethernet shield and on top of that equipped with the long range version of the NRF24 Board (the one with the antenna).
                                The SenseBender is equipped with the "normal" smt version as suggested. The sensor nodes which are working right now were equipped with the smd version of the nrf-board.
                                I also found out that the initialization of the sensor and the gateway has a different Core initialization, different capabilities (CP). I looked through the API, but didn't find what CP=RNNGA or CP=RNONA stands for.
                                Any suggestions or ideas?
                                • F flybysun
                                  3 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  11 TSM:INIT:TSP OK
                                  12 TSM:INIT:GW MODE
                                  1583 MCO:BGN:STP
                                  139859 TSF:MSG:BC
                                  139866 TSF:CKU:OK
                                  141945 TSF:MSG:BC
                                  144026 TSF:MSG:BC
                                  146106 TSF:MSG:BC
                                  @flybysun information on capabilites is available at https://forum.mysensors.org/topic/7718/mysensors-capabilities-deciphering and https://www.mysensors.org/apidocs/group__MyCapabilities.html
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @flybysun
                                    what is the "official" firmware that you upload to the atmega? If it's the sensebender micro fw, then please observe that this is meant to run with a Si7021 sensor, and not DHT22, so unless you modify things, it won't run without that sensor onboard..
                                    • F
                                      F
                                      flybysun
                                      wrote on last edited by flybysun
                                      #98
                                      @tbowmo
                                      I have a 1:1 build of the sensebender micro, including the Si7021. Something I definetly will try tonight is to change the the radio modules with one of these I had before (and are working). I've just discovered this here:
                                      https://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging
                                      With "official" firmware I mean the Arduino Sketch which is included on the hardware webpage:
                                      https://www.mysensors.org/hardware/micro
                                      • F
                                        F
                                        flybysun
                                        @mfalkvidd @tbowmo
                                        So folks, I finally got it to work. It really seems to be a problem with my radio modules. When I change my PA module on the gateway against one of these I ordered for the SenseBender Micro, everything works fine. But I still don't understand why my pro mini with the smd radio was able to send the data to the pa module, while the sensebender connected to a smd version still didn't work.
                                        Is there anything special on the PA Version, that I've missed? I wonder if I can live with that now, I thought the PA Version has a bit more sensitivity and gain and would be better as the central gateway unit.
                                        • F flybysun
                                          @mfalkvidd @tbowmo
                                          @flybysun the PA version draws much more power than the non-PA version (5x more if I remember correctly). If the power supply can't deliver clean power (without ripples or sudden dips), the radio will malfunction.
                                          With your input, this post could be even better πŸ’—
