  3. 💬 Sensebender Micro
💬 Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 50.6k Views 38 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @phildefer
    I think it's a leftover from a cleanup at some point in time. Not used anymore.. The MySensors core library is handling the sleep mechanism now.
    • denisvdbD
      denisvdbD
      denisvdb
      To reprogram the sketch in a sensbender micro, wich board must be selected in the arduino prg?
      I have problem with inclusion in jeedom, the command are not loaded.
      thx
      • fearoffishF fearoffish
        Anyone managed to get this working with PlatformIO (through Atom) yet? I'm struggling.
        marceltrapmanM
        marceltrapmanM
        marceltrapman
        @fearoffish did you manage to get this working?
        And, if so, what was the issue?
        I am looking into changing to PlatformIO on Atom or even CLion...
        Fulltime Servoy Developer
        • loic13L
          loic13L
          loic13
          Hi, I'm getting this error message when compiling the sketch with the 2.1.1 MySensors library:
          SensebenderMicro:168: error: 'getConfig' was not declared in this scope
          isMetric = getConfig().isMetric;
          I just commented out the line as workaround, but not sure that its correct.
            Hmm.. The api was recently changed to getControllerConfig().isMetric;
            I'll update the example.
            • loic13L
              loic13L
              loic13
              Thank you.
              • T
                Toyman
                How difficult is to replace 0402 components with 0603 or 0804 components in Eagle? I am too old for 0402 soldering :-)))
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @Toyman
                  Not that hard, but you'll probably need to redesign the board, to get room for the larger components.
                  Another option is to order the board pre-assembled from our partner, itead studio
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    I've tested to upload a sketch to the Sensebender Micro using platformio.
                    Put the following JSON into a json file in a folder named boards either in the MySensors library folder (your project in platformio), or somewhere else on the search path. Use the name of the json file in platformio.ini in the board setting. See for more info:
                    http://docs.platformio.org/en/latest/platforms/creating_board.html
                    • Create a folder named boards in MySensors project folder.
                    • Create a file in boards named sensebendermicro8MHz.json.
                      "build": {
                        "core": "arduino",
                        "extra_flags": "-DARDUINO_ARCH_AVR -DARDUINO_AVR_PRO",
                        "f_cpu": "8000000L",
                        "mcu": "atmega328p",
                        "variant": "standard"
                      "frameworks": [
                        "arduino"
                      "fuses": {
                        "efuse": "0x06",
                        "hfuse": "0xD2",
                        "lfuse": "0xE2",
                        "lock": "0x3F"
                      "name": "Sensebender Micro (3.3V, 8 MHz)",
                      "upload": {
                        "maximum_ram_size": 2048,
                        "maximum_size": 30720,
                        "protocol": "arduino",
                        "require_upload_port": true,
                        "speed": 57600
                      "url": "https://github.com/mysensors/SensebenderMicro",
                      "vendor": "MySensors"
                    • Add an env in platformio.ini.
                    [env:sensebendermicro8MHz]
                    platform = atmelavr
                    framework = arduino
                    board = sensebendermicro8MHz
                    lib_deps = MySensors
                    • Compile sketch.
                    • Upload sketch.
                    I think I've got the settings correct, but it was the first time I did this. But it's tested and works as far as I can see.
                    Should we add a JSON file to one of the mysensors repos on github?
                    • openhardware.ioO openhardware.io
                      https://www.mysensors.org/view/1/Sensebender-Micro
                      marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      I have a bunch of W25X40CLSNIG-ND lying around.
                      They have the same size and same layout as far as I can see.
                      Is my thinking correct that I should be able to simply replace the AT25DF512C-SSHN-B, change the sketch and use it?
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @marceltrapman
                        If it's a jedec compatible flash, then you should be able to swap.. But what is the usecase of a larger flash? You can't execute code in the external flash.. So for OTA you still only have a bit under 32Kbyte usefull space..
                        • tbowmoT tbowmo
                          @marceltrapman
                          marceltrapmanM
                          marceltrapmanM
                          marceltrapman
                          wrote on last edited by marceltrapman
                          #32
                          @tbowmo no case at all, just that I have them and otherwise probably won't use them..
                          • Michiel van der WulpM
                            To reprogram the sketch in a sensbender micro, wich processor frequency do I choose?
                            After choosing Board "Sensebender Micro", the menu in Arduino 1.6.12 has choice Processor "Atmega328 8MHz" and "Atmega328 1MHz".
                            My code seems to be executed equally fine with both settings.
                            But the Arduino Serial Monitor not:
                            If I choose the 1MHz version, the Serial monitor only produces garbage, whatever setting I choose for baud (in the sketch and in the serial monitor UI).
                            If I choose the 8MHz version, the serial monitor works fine.
                            I am confused. The Sensebender is a 1MHz device, isn't it? Is it able to run on 8MHz too?
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @Michiel-van-der-Wulp
                              No, it runs at 8Mhz. It is asleep most of the time, so running at 8Mhz is actually more battery conserving, than running at 1Mhz (in theory), as shown in calculations over in this post. This is due to the shorter time powered on, when running at 8Mhz, compared to running at 1Mhz.
                                OK, I understand.
                                My confusion was caused by the second sentence at https://www.mysensors.org/hardware/micro : "... it operates at 1Mhz ..."
                                That's a mistake then?
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  Yes, sorry that was a false statement. I have modified the description, so that it now states that the Micro is running at 8Mhz.
                                  • marceltrapmanM
                                    marceltrapmanM
                                    marceltrapman
                                    I am thinking of expanding the Sensebender Micro and learn Kicad in the process.
                                    Unfortunately every attempt to convert from Eagle to Kicad failed.
                                    Is there a Kicad version available or did any of you manage to convert the project?
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @marceltrapman
                                      There is no kicad project available for the Sensebender Micro, I tried to convert it myself, but didn't succeed with it either.
                                      blaceyB 1 Reply Last reply
                                      • tbowmoT tbowmo
                                        @marceltrapman
                                        blaceyB
                                        blaceyB
                                        blacey
                                        wrote on last edited by blacey
                                        #39
                                        @tbowmo said in 💬 Sensebender Micro:
                                        @marceltrapman
                                        I haven't tried this Eagle->KiCAD convertor myself but it might do the trick or at least reduce a lot of the manual labor to convert...
                                        There's even a tutorial video.
                                        tbowmoT marceltrapmanM 2 Replies Last reply
                                        • blaceyB blacey
                                          @marceltrapman
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @blacey
                                          thanks for finding that tutorial.. Might give it a spin, and see if I can convert the sensebender micro to kicad
