  3. 💬 Easy/Newbie PCB for MySensors
mysensorsbatteryeasynewbiepcbmysx
716 Posts 111 Posters 700.4k Views 93 Watching
  • EmeE Eme
    @sundberg84 Yes you are right I meant to say ProMini not Nano - I have 18 of these PCB - not so happy I have to solder directly to the Arduino - that's exactly what I was avoiding in the first place. Do you have a good relay block sketch that works? Much appreciated if you can help.
    One last thing, I am trying to run a node off a 12Volts battery, can you explain this image below again?
    • Will this work for a 5V Promini?
    • What are the blue lines? and
    • what are the red lines?
    #661
    @eme - its is very strange - I have a big batch here with Rev 10 and i checked atleast 20 of them randomly and all have continutiy between D6/pro mini and D6/MysX. You must have had extreme bad luck and if you check the others it should be ok.
    Can you post a picture (close up) of the board not working please showing D6/Pro mini and D6/MysX.
    For 12v I would use the prototyping area with a 12 > 5v converter. If you want to use the internal voltage regulator on the pro mini you can connect to RAW but beware that clones will not handle this very good. The specs are 12v but I have seen many bad clones getting destroyed.
    I dont really remember this image and from which context this is from. I guess the lines represent different voltages. Adding 12V on reg and a 12>5v regulator on the TO92 footprint will convert and feed the board 5v, but kill the radio...
      mickecarlsson
      wrote on last edited by mickecarlsson
      #662
      I just checked my batch of Rev 10, random check of the batch checked out OK. I have 20 boards.
      • J
        J
        JPM
        Dear sundberg84, thanks to your really nice and easy mysensors PCB. I ordered ten of them via SEEED and they were delivered today (REV.10). Unfortunally I found some serious bugs in the PCB design regarding the SPI Flash: First pin 6 (SPI SCK) of the flash chip is not connected at all - should be digital IO pin 13 of the Arduino pro mini. Second mistake: the filter capacitor of the flash chip is not between VCC and GND. Third mistake: pin 3 and pin 7 should be connected to VCC and not to the filter capacitor. I changed that on my arrived boards and the flash chip is now working perfectly. Kind regards, JPM
          mickecarlsson
          I checked the schematic, and:
          First mistake: Seems that the schematic is OK, the label for SCK (pin 6) is connected to physical pin 16 which is PCINT13 on the Arduino,
          Second mistake: that is a bug, filter capacitor is not connected correctly.
          Third mistake: That is also a bug, pin 7 and 3 should be connected to VCC
          Now I am going to check the PCB, be back shortly,
            mickecarlsson
            I have now checked the PCB, and you are right @JPM
            Pin 6 of the flash chip is not connected at all. No wonder I could not get that to work. Strangely is that the schematic is OK.
            Thanks for finding this, I will modify my boards to get them working.
            EmeE 1 Reply Last reply
            • sundberg84S
              #666
              Sorry for this. The flash has been untested by me. I will fix this asap and upload new files.
              The schematics is wrong:
              New schematics:
              The same error goes for RFM version :(
              • M mickecarlsson
                EmeE
                EmeE
                Eme
                @mickecarlsson I found this out and wrote it above that D6 is not connected at all... but it was promptly swept aside cos nobody had reported it before now. I am glad someone else saw it, and that you had the notion to check. D4 is also not connected to the test area. I have been connecting directly to the Nano.
                • EmeE Eme
                  #668
                  @eme im sorry - since your wrote "The provisions to attach sensors are not correctly marked. D6 doesn't actually connect to D6 pin on the Arduino" I thought you was talking about the MysX connector and not flash. If you mentioned flash I would probably found the issue. They are not talking about D6 but pin 6 on flash which connects to D13 on the Arduino.
                  Are you sure it's the same problem? Not much that sounds the same.
                    mickecarlsson
                    @sundberg84 if you look at the schematic you have connected MySX pin 10 to D2, but according to the spec for the MySX 2.4 it should go to D4.
                    • M mickecarlsson
                      @mickecarlsson - I understand your point, and I have changed this back and forth and also asked @Anticimex becuase its a but unclear in the documentation.
                      MysX 9 + 10 should go to a Digital IO with interrupt, and D2 and D3 is the only pins with interrupts on mini.
                      I guess you are refering to Mysx_D3_INT but this is the MysX name.
                      AnticimexA 1 Reply Last reply
                      • sundberg84S sundberg84
                        AnticimexA
                        AnticimexA
                        Anticimex
                        #671
                        @sundberg84 @mickecarlsson
                        It is important to remember that MYSX is agnostic from any devices.
                        Any names in MYSX pins bear no correlation to any device specific pin naming, so D3 and D4 mentioned on pin 9 and 10 has nothing to to with any D3 or D4 on any MCU.
                        If you look here, you will find that the 'A' and 'D' notation is simply an indicator of the pin function (analog or digital) and it simply increments with the pin number, so the lowest analog or digital pin number in the MYSX connector will start at '1' and then increment as the pin number increments with '2' for the next digital being on pin '6'.
                        Also note that since some pins are deprecated in MYSX 2.x, MYSX 2.x analog pins starts with 'A3'.
                        • B
                          B
                          birinderk
                          I was wondering if there are any CAD files for corner through hole size/locations for Rev 10? Trying to design enclosure for it.
                          dbemowskD sundberg84S 2 Replies Last reply
                          • B birinderk
                            dbemowskD
                            dbemowskD
                            @birinderk SHould be easy enough to measure it with a caliper. That's what I did with the earlier revisions of the board (rev 8 & 9). They had pretty much the same hole spacing. Here are a few of the enclosures/sensor cases that I did that fit the rev 8 and 9's.
                            https://www.thingiverse.com/thing:2186286
                            https://www.thingiverse.com/thing:3339158
                            https://www.thingiverse.com/thing:2904969
                            • B birinderk
                              @birinderk - https://github.com/sundberg84/HomeAutomation/tree/master/MysX template EasyPCB
                              • markjgabbM
                                markjgabbM
                                markjgabb
                                Does anyone know where we can find the write ups for old revisions? i have a bunch of Rev9 boards that, now that i have restarted these projects after a year break i cant remember the write ups for them....
                                • markjgabbM markjgabb
                                  @markjgabb do you mean the stuff in README.md in the zip file that can be downloaded on the revisions tab?
                                  markjgabbM 1 Reply Last reply
                                    markjgabbM
                                    markjgabbM
                                    markjgabb
                                    @mfalkvidd yeh i guess so, not quite what i was after the orignal in that version had some good pictures and such of what went where on the board....do doubt i can work it out from an old dead one i have lying around, was just hoping for a nice visual guide to get me back into it.
                                      @markjgabb not sure if this is what you want, but if I paste the contents of the readme into a markdown viewer (for example https://dillinger.io/ ) I get the images:
                                        markjgabbM
                                        markjgabbM
                                        markjgabb
                                        @mfalkvidd ahhhhh That answers my question perfectly....i was just dumping it into notepad ++ ill try that first thing in the morning.
                                        • F
                                          F
                                          fredswed
                                          First of all: I really appreciate the simplicity and flexibility of this board!
                                          Now then, I have a problem with battery life which is only around 3 weeks for my DHT22 node and around 8 weeks for my BMP280 node. Both are 3.3V mini clones with NRF24 radios (probably clones) that run on 2xAAA batteries and a booster. I use NodeManager for software and report sensor values in 2 minute intervals. LED and voltage regulator has been desoldered from the Pro Mini.
                                          Why isn't battery life better - am I missing anything obvious?
                                          1. Can/should I remove C2 (10uF) and C3 (0.1uF) capacitors? I added them first but after checking the schematics I now think they are not used at all for the battery/booster setup?
                                          2. What battery life can I expect for a BMP280 on 2xAAA batteries and booster?
                                          3. New batteries report at 3.13V. When the nodes fail, reported battery voltage is around 2.6V. However, when measured I get it to around 1.6V (at no load). This could be a software problem but I include it as a clue. My setup in NodeManager is:
                                          battery.setBatteryPin(0);
                                          battery.setMinVoltage(1.8);
                                          battery.setMaxVoltage(3.1);
                                          sundberg84S Nca78N 2 Replies Last reply
