  3. Problem compiling sketch on library 1.5 DEVEL
5 Posts 2 Posters 3.0k Views 1 Watching
  • X
    X
    xefil
    I know it's in development, but I've moved to library 1.5 DEVEL to test the MQTT clientforwarder.
    Now, I'm trying to compile an old sketch that worked on previous libraries and it fails here:
    In file included from my-example.ino:17:0:
    \arduino-1.6.1\libraries\MySensors/MySensor.h:223:3: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    my-example.ino:109:1: error: 'MySensor' does not name a type
    my-example.ino: In function 'void setup()':
    my-example.ino:129:3: error: 'gw' was not declared in this scope
    my-example.ino: In function 'void loop()':
    my-example.ino:190:3: error: 'gw' was not declared in this scope
    my-example.ino: In function 'void incomingMessage(const MyMessage&)':
    my-example.ino:298:6: error: 'gw' was not declared in this scope
    Line 109 is where i declare MySensor outside any void:
    Line 129 in void setup() :
    gw.begin(incomingMessage, 20, true, 0);
    Line 190 - in void loop() :
    gw.process();
    Line 298 - in void incomingMessage(const MyMessage &message) {:
    Any suggestion?
    Thanks!
    Simon
    korttomaK 1 Reply Last reply
    • X xefil
      gw.process();
      Any suggestion?
      Thanks!
      Simon
      korttomaK
      korttomaK
      korttoma
      Looking at the MySensors example sketches from the develoupment branch it seems like you can remove:
      and from the rest just remove
      gw.
      • Tomas
      • X
        X
        xefil
        wrote on last edited by xefil
        Thanks @korttoma but, if I remove:
        and then move from:
        to:
        I get
        my-example.ino:128:37: error: 'begin' was not declared in this scope
        • korttomaK
          korttomaK
          korttoma
          I think you need to include MySensor.h after any configuration defines
          I found a post by @hek pointing to the following document -> https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#
          There I read:
          Converting sketch from 1.5 to to 2.0
          Add the following to activate NRF-radio support
          Remove MySensor constructor
          MySensors gw;
          Remove MySensors setup() call
          gw.setup(....);
          If node expects incoming messages, add the following function to handle data:
          void receive(const MyMessage &msg) {}
          Move present() and sendSketchInfo() from setup() to a new function called presentation().
          void presentation() {
               sendSketchInfo(...)
               present(...);
          If you’re using static ids , add:
          #define MY_NODE_ID xx
          If static parent node is used, add:
          #define MY_PARENT_NODE_ID xx
          If you want node to be a repeater, add
          #define MY_REPEATER_FEATURE
          Remove all “gw.” before MySensors library calls.
          If node requests time using requestTime(), remove callback argument define define the following function to handle time response:
          void receiveTime(unsigned long ts) {
          Make sure to include MySensor.h after any configuration defines.
          • Tomas
          • X
            X
            xefil
            Thanks a lot for pointing me to the right place! Now it compiles correctly.
            It's only to understand if it works. Cannot test it here right now. I'll do it soon!
            Thank you ;)
            Simon
