  3. Help with req id
Help with req id
10 Posts 5 Posters 3.8k Views 3 Watching
  • tianaT
    tianaT
    tiana
    wrote on last edited by tiana
    Sensor log
    req id
    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
    repeater started, id=255, parent=0, distance=1
    req id
    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=fail:
    req id
    req id
    Gateway log
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    Somebodey can help me with getting sensor ID
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Hi!
      It looks as your current node sketch is set to request node id from the controller. Do you have a controller connected to the gateway that supports auto assigning node ids?
      If not, you can set a manual node id in the node sketch.
      See "Starting up the library" at http://www.mysensors.org/download/sensor_api_15#the-full-api.
      • tianaT
        tianaT
        tiana
        I reed this manual 100 times but dont understand how to add sensor id manualy.
        Wich file have to change?? wich part of thiss file have to change???
        My controler haven't support or not set auto assigning node id
        • fetsF
          fetsF
          fets
          void begin(void (*_msgCallback)(const MyMessage &), uint8_t nodeId, boolean repeaterMode,uint8_t parentNodeId);
          you must set the 2nd parameter to the value you want (i.e 10).
          • tianaT
            tianaT
            tiana
            10X
            i fix this problem
            • sundberg84S
              Pretty much add this line to setup()
              gw.begin(NULL, 10);
              Null = Node doesnt accept any incoming messages
              10 = node id.
              DdawmeD 1 Reply Last reply
              • sundberg84S sundberg84
                gw.begin(NULL, 10);
                10 = node id.
                DdawmeD
                DdawmeD
                Ddawme
                @sundberg84 where do I add this code? I'm having the same problem
                • sundberg84S
                  You add it in setpu{}
                  Change the gw.begin() to ge.begin(NULL, ID)
                    DdawmeD
                    DdawmeD
                    Ddawme
                    @sundberg84 sorry to be such a pain but I'm not understanding. Do I add that to the node sketch? When I do I get "null was not declared in this scope".
                    Also looking at domoticz log is there a way to know for sure that domo and my gateway are communicating?
                    Thanks in advance for your help!
                    • sundberg84S
                      Hi! Yes, in node sketch
                      Example Binary Sketch: (1.5.X and below)
                      #include <Bounce2.h>
                      #define CHILD_ID 3
                      #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
                      Bounce debouncer = Bounce();
                      int oldValue=-1;
                        gw.begin(NULL, 5);
                       // Setup the button
                        pinMode(BUTTON_PIN,INPUT);
                        // Activate internal pull-up
                        debouncer.attach(BUTTON_PIN);
                        debouncer.interval(5);
                        gw.present(CHILD_ID, S_DOOR);
                        debouncer.update();
                        // Get the update value
                        int value = debouncer.read();
                        if (value != oldValue) {
                           // Send in the new value
                           gw.send(msg.set(value==HIGH ? 1 : 0));
                           oldValue = value;
