  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 255.8k Views 53 Watching
  • M meddie
    Ok i just connected the W5100 and NRF24 Module and uploaded the GatewayW5100 Sketch and when the upload is done after reset i dont get any output on serial monitor.
    The orange, green and red led are lighting.
    When i upload the SensebenderGatewaySerial then i get output on serial monitor. It think the problem must be the w5100. But what going wrong?
    alexsh1A
    alexsh1A
    alexsh1
    @meddie said in 💬 Sensebender Gateway:
    @meddie Did you figure out what the problem is? I have exactly the same issue
    M tbowmoT 2 Replies Last reply
    • alexsh1A alexsh1
      meddie
      @alexsh1
      hi, yes it was very simple :-D the gateway has worked fine in this time, i thought that when nothing shown in serial monitor that the gateway dont work, but it did it, after i connected the gateway to FHEM (my controller) i saw that FHEM connects t mys Gateway.
      So it worked all the time
      Greets Eddie
      • alexsh1A alexsh1
        tbowmoT
        tbowmoT
        tbowmo
        @alexsh1
        Have you tried to enable the debug output in the GatewayW5100 example? I think it is disabled by default, due to the limited memory on the small atmega 328p
        alexsh1A 1 Reply Last reply
        • tbowmoT tbowmo
          @alexsh1
          alexsh1A
          alexsh1A
          alexsh1
          @tbowmo
          Yes, I did
          #define MY_DEBUG_VERBOSE_SIGNING
          • alexsh1A
            alexsh1A
            alexsh1
            #225
            I am running Arduino IDE 1.8.1 on Windows 10
            Arduino AVR 1.6.18
            Arduino SAMD 1.6.12
            MySensors SAMD 1.0.5
            EDIT: I have tried to upload the default sketch on macbook with Arduino IDE 1.6.2
            It is still the same - no debug info in the terminal
            • alexsh1A
              alexsh1A
              alexsh1
              #226
              OK, I did manage to get debug working partially.
              The gateway reads messages, but does not work as the gateway
              0;255;3;0;9;MCO:BGN:STP
              0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=17,pt=5,l=4,sg=0:348
              0;255;3;0;9;TSF:MSG:READ,26-10-0,s=3,c=1,t=24,pt=5,l=4,sg=0:51219479
              0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=24,pt=5,l=4,sg=0:51219482
              0;255;3;0;9;TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:1717.62
              0;255;3;0;9;TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:5338.44
              0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:10.75
              0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:10.76
              0;255;3;0;9;TSF:MSG:READ,11-11-0,s=4,c=1,t=37,pt=4,l=4,sg=0:880
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=2,c=1,t=1,pt=7,l=5,sg=0:64.8
              0;255;3;0;9;TSF:MSG:READ,6-6-0,s=0,c=1,t=4,pt=7,l=5,sg=0:1015
              I never had a message:
              Gateway startup complete.
              EDIT: Self-test with SensebenderSerial sketch gives me this:
              Sensebender GateWay test routine
              Mysensors core version : 2.1.1
              GateWay sketch version : 0.2
              - > SHA204 Failed to wakeup SHA204
              - > SD CARD SD CARD did not initialize!
               -> EEPROM PASSED
              -> analog : 38 Failed
              tbowmoT 1 Reply Last reply
              • alexsh1A alexsh1
                 -> EEPROM PASSED
                tbowmoT
                tbowmoT
                tbowmo
                @alexsh1
                Could you check the soldering of the samd?
                SD card fails, if you haven't inserted a card, when running the self test.
                • tbowmoT tbowmo
                  @alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  #228
                  @tbowmo
                  I do not have the SD card so that's fine
                  The samd looks fine - no bridges etc
                  I can try to re-solder it with a hot fan
                  Do you think samd may be at fault even though the serial GW is working?
                  Unfortunately, I do not have another Ethernet w5100 to try it. Probably have to order a new one
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @alexsh1
                    I know that @Anticimex had problems with one of the pre-production samples that we got from China, with various problems, that was solved with "reflowing" the samd with a hot air gun.. So it was just a thought, that it could be a bad solder joint..
                    The W5100 is using it's own dedicated SPI port, so even though that the radio works, doesn't mean that there couldn't be any solder problems around the samd pins for W5100.
                    We have 3 different SPI ports in use on the gateway, one for the MysX connector, one for radio / sdcard, and one for W5100..
                    • tbowmoT tbowmo
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @tbowmo I do not have the oven to reflow the whole board, but can mount / unmount or re-work certain components 0805 or 0603. Below this it is a pain in the a***
                      Another observation - The GW behaves like this with or without W5100 mounted.
                      Seems like an SPI problem to me. How can I wire W5100 to MYSX please and what shall I can in the sketch please? Thank for your help - very much appreciate it
                      AnticimexA 1 Reply Last reply
                      • alexsh1A alexsh1
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @alexsh1 The ATSHA is not connected to the SPI and is totally unrelated, so I am also inclined to suspect that perhaps one side of the SAMD is not entirely in contact with the pads. I had to hot-airgun mine to get USB working well but it was an early prototype like @tbowmo said.
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          @tbowmo OK, I manage to find the answer here -
                          MYSX
                          D11 - MOSI
                          D12 - MISO
                          D13 - SCK
                          D14 -CS
                          #define MY_SOFTSPI
                          #define MY_SOFT_SPI_SCK_PIN 13
                          #define MY_SOFT_SPI_MISO_PIN 12
                          #define MY_SOFT_SPI_MOSI_PIN 11
                          MY_RF24_CS_PIN 14
                          RF24_CE_PIN ???
                          Am I correct?
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            My current config for nrf24l01+ and w5100 is as follows:
                            #define MY_GATEWAY_W5100
                            #define MY_SOFTSPI
                            #define MY_RF24_CE_PIN 5
                            #define MY_RF24_CS_PIN 6
                            Why CE / CS pins are 5 and 6?
                            Should that be 27 and 3?
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              #234
                              @tbowmo I have just re-worked SAMD and all the connectors (nrf24l01+ and NET_SPI), but still have the same issue sadly.
                              EDIT: If I change to rfm69, the same behavior is observed. It seems that Net_SPI is just not working.
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                #235
                                @alexsh1
                                Configuration of the pins are handled by the hardware configuration file, https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h#L227
                                If you look in the gatewayW5100 sketch, the settings for CE / CS pins are enclosed in ifdefs, so they are only used if they are not defined previously.
                                If you want to connect the W5100 to the mysx connector, you can change line 174 in the hardware definition file, use SPI2 instead of SPI1 for SPI_ETH
                                It could also be a defective W5100 shield? Can you verify that it works on other hardware?
                                • tbowmoT tbowmo
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @tbowmo Swapping SPIs did not resolve the problem. I am now getting another W5100 to test further.
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    Unfortunately, a new W5100 shield did not work - it seems like a production issue with this sensebender gatewsay as the SPI2 did not work either with W5100.
                                    Will get a new one ordered.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      Is it possible for you to check the spi wires with a scope? Just to make sure if mosi/miso/ce/Ss lines are toggling as expected?
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        #239
                                        Another thing, are you using static ip? If yes, can you ping it? If no, does your DHCP server hand out an ip address?
                                        Have you tried the basic ethernet examples for the W5100?
                                        • tbowmoT tbowmo
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @tbowmo I am using the static IP and I can ping it, but the "Gateway Ready" message never comes up. Also I can only see the neg24l01+ log (incoming messages only)
