  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 255.8k Views 53 Watching
  • alexsh1A alexsh1
    @tbowmo I am using the static IP and I can ping it, but the "Gateway Ready" message never comes up. Also I can only see the neg24l01+ log (incoming messages only)
    tbowmoT
    tbowmoT
    tbowmo
    @alexsh1
    If you can ping it, then the W5100 is configured. Something else is wrong..
    One thing that comes to mind, if you compile it as an ethernet GW, then it does not wait for serial console to be active, before initializing the radio. If you compile it as serial GW, then it waits with initialization, until serial is active.
    This means that you probably is missing the GW ready message on the serial port, as it is "sent" before you have an active serial connection.
    Look in MyHwSamd.cpp in the HwInit routine, remove the #ifdef around the while() loop, and try again.
    alexsh1A 1 Reply Last reply
    • tbowmoT tbowmo
      @alexsh1
      alexsh1A
      alexsh1A
      alexsh1
      #242
      @tbowmo Well, if I try the MEGA 2560 with W5100, I get the following:
      0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGAS-,VER=2.1.1
      0;255;3;0;9;TSM:INIT
      0;255;3;0;9;TSF:WUR:MS=0
      0;255;3;0;9;TSM:INIT:TSP OK
      0;255;3;0;9;TSM:INIT:GW MODE
      IP: 10.1.1.120
      0;255;3;0;9;MCO:BGN:STP
      I never get this message with Sensebender GW. I only get
      0;255;3;0;9;TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:2019.12
      0;255;3;0;9;TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:6275.51
      0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:18.77
      or similar messages from nodes.
      tbowmoT 1 Reply Last reply
      • tbowmoT
        tbowmoT
        tbowmo
        #243
        @alexsh1
        on atmega2560 you are resetting the device, when you connect a serial terminal to the usb device, so you get all the debug messages on the serial port..
        On SAMD it uses a native USB port, and the chip is not reset when connecting a serial terminal. When using serialGw it will wait until a serial terminal is connected. before initializing radio transport (this is because it does not make sense to have a serial gateway that spits out data to a none existing port).
        When using it as a ethernet gateway, we skip this, as we do not want to wait for a serial terminal, in case you are just using the USB as a power source. So in this mode, it skips the waiting, and just initializes radio gateway etc.
        as stated in my previous message you could look at the MyHwSAMD.cpp file line 73. Remove the #ifdef recompile, upload, and check your serial terminal again.
        Also the log shows that you actually are receiving data from your nodes, so the radio transport is clearly active.. And you can ping your gateways static IP, which means that the W5100 is initialized with the correct IP address.
        • alexsh1A alexsh1
          IP: 10.1.1.120
          tbowmoT
          tbowmoT
          tbowmo
          @alexsh1
          Did you try my suggestion about hacking the core? Or did you give up on the beast? :)
          I'm curious to hear if it is solved..
          alexsh1A 2 Replies Last reply
          • tbowmoT tbowmo
            @alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            @tbowmo I will try it tomorrow. However, given the amount of time I spent already, I am about to give up...
              micropet
              Hello everybody.
              I got my Sensebender gateway yesterday. Have the W5100 Ethernet board mounted and loaded a sketch with the WizNET (W5100) Ethernet module and MQTT.
              The gateway immediately ran as desired.
              Unfortunately only for about 2 hours, then it freezes.
              After a restart it runs again 3 hours and freezes again.
              And so on.
              I wanted to replace an RPI Gatway, which has worked flawlessly for many weeks.
              If the Sensebender gateway works only a few hours it is quite useless.
              • M micropet
                Hello everybody.
                And so on.
                tbowmoT
                tbowmoT
                tbowmo
                @micropet
                It must be a software issue. Are you using it with nrf24? Do you have a github account? If you have, would you mind filling an issue report on the mysensors library? As we need to dig further into this. Please also make a note of how many nodes you have running in your system.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @alexsh1
                  I would really like to get it solved, so it can bring peace to my mind :) so please, if you can..
                    micropet
                    I also think that it is a software problem.
                    I use only the RFM96HW.
                    My "real" network has 20 nodes.
                    The Sensebender gateway has only one DS18b20 node on a seperate frequency.
                    (#define MY_RFM69_FREQUENCY (868200000ul))
                    And yes, I have a github account and will make an issue report today.
                    • tbowmoT tbowmo
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #250
                      @tbowmo I think I am on the right track here. This is the log:
                      0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGS--,VER=2.1.1
                      0;255;3;0;9;TSF:LRT:OK
                      IP: 0.0.0.0
                      The GW Init is correct one, but IP is 0.0.0.0
                      This is the sketch:
                      //#define MY_DEBUG_VERBOSE_RF24
                      #define MY_RF24_CHANNEL    76
                      #define MY_GATEWAY_W5100
                      //#define MY_W5100_SPI_EN 4
                      // radio on the same spi bus.
                      #define MY_SOFTSPI
                      #ifndef MY_RF24_CE_PIN
                      #define MY_RF24_CE_PIN 5
                      #ifndef MY_RF24_CS_PIN
                      #define MY_RF24_CS_PIN 6
                      // Enable to UDP
                      //#define MY_USE_UDP
                      #define MY_IP_ADDRESS 10,1,1,150   // If this is disabled, DHCP is used to retrieve address
                      #define MY_PORT 5003
                      //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
                      // Enable inclusion mode
                      // Set blinking period
                      // Flash leds on rx/tx/err
                      //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                      //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                      //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
                      #if defined(MY_USE_UDP)
                      #include <EthernetUdp.h>
                      #include <Ethernet.h>
                      I cannot connect to W5100. Tried a different shield with the same result.
                      • tbowmoT tbowmo
                        @alexsh1
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @tbowmo BTW, I cannot ping it (I suppose there was another network device with the same IP on a network).
                        If I try to switch to DHCP I get:
                        DHCP FAILURE...0;255;3;0;9;!MCO:BGN:TSP FAIL
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          #252
                          @tbowmo I have received the second GW and I have exactly the same problem. As you suggested, I modified MyHwSAMD.cpp and can see now the start-up message, but there is a problem between the W5100 and GW:
                          0;255;3;0;9;660 MCO:BGN:INIT GW,CP=RNNGS---,VER=2.2.0-beta
                          0;255;3;0;9;707 TSF:LRT:OK
                          0;255;3;0;9;717 TSM:INIT
                          0;255;3;0;9;727 TSF:WUR:MS=0
                          0;255;3;0;9;742 TSM:INIT:TSP OK
                          0;255;3;0;9;752 TSM:INIT:GW MODE
                          0;255;3;0;9;762 TSM:READY:ID=0,PAR=0,DIS=0
                          0;255;3;0;9;772 MCO:REG:NOT NEEDED
                          IP: 0.0.0.0
                          0;255;3;0;9;2082 MCO:BGN:STP
                          0;255;3;0;9;2092 MCO:BGN:INIT OK,TSP=1
                          0;255;3;0;9;17920 TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:1956.28
                          0;255;3;0;9;17931 TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:6080.20
                          0;255;3;0;9;17942 TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:20.71
                          0;255;3;0;9;17953 TSF:MSG:READ,11-11-0,s=1,c=1,t=37,pt=7,l=5,sg=0:13282.11
                          I tried different MySensors (stable and dev) and checked solding.
                          Now sure what to do now
                          EDIT: This is my sketch:
                           * Version 1.0 - Henrik EKblad
                           * Contribution by Tomas Hozza <thozza@gmail.com>
                           * LED purposes:
                           * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
                          //#define MY_DEBUG_VERBOSE_SIGNING
                          //#define MY_SIGNING_ATSHA204
                          //#define MY_SIGNING_REQUEST_SIGNATURES
                          #define MY_SOFTSPI
                          // Enable to UDP
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            have you tried the ethernet webserver example sketch (default arduino sketch)?
                            Just to rule out mysensors..
                            Also, you are using static IP, right? What if you ping that IP address? Do you get a response? If yes, then the W5100 is configured by your sketch, and the connection should be ok between the samd and the ethernet module.
                            alexsh1A 3 Replies Last reply
                            • tbowmoT tbowmo
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #254
                              @tbowmo ethernet wedserver sketch is giving me this:
                              server is at 0.0.0.0
                              EDIT: I can ping the IP and yes it is static.
                              • tbowmoT tbowmo
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @tbowmo Do you think softSPI is at fault? What pins shall I use? I tried these
                                #define MY_SOFTSPI
                                #define MY_SOFT_SPI_SCK_PIN 24 //13 //23  //14
                                #define MY_SOFT_SPI_MISO_PIN 22 //14 //22 //16
                                #define MY_SOFT_SPI_MOSI_PIN 23 //12 //21 //15
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @tbowmo I cannot ping it though if I load MySensors GW sketch -
                                  Destination host unreachable.
                                  • tbowmoT tbowmo
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @tbowmo I have just discovered that the second Ethernet module I have is not W5100 but ENC28J60. Not sure if it is supported by sensebender GW (probably using native Arduino ethernet library?).
                                    So this module is now being returned and just to figure out any hardware issue I need to order a new W5100
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      You should not use soft spi, as there is separate hardware spi ports for radio and W5100.
                                      If you load the default GatewayW5100 example sketch, then it should work out if the box. Perhaps you need to enable rfm69 instead of nrf24 at the top of the file, but that should be all that is needed.. To get a gateway up and running with W5100
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @alexsh1
                                        OK, just to recap here, you have a gateway, and a W5100. If you use that combo, and the http server example, you can ping the gateway, and Load the html files in a browser, right?
                                        If you load stock GatewayW5100 mysensors example sketch, then does that work? (no need to redefine pins for hardware etc, that is handled by the target hardware profile, you choose in arduino)
                                        • tbowmoT tbowmo
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @tbowmo I must admit I have not tried to load files in the browser when trying Ethernet sketch. Only pinging
                                          Yes, you are correct - gateway, nrf24l01+ and w5100
