  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • M micropet
    Hello everybody.
    I got my Sensebender gateway yesterday. Have the W5100 Ethernet board mounted and loaded a sketch with the WizNET (W5100) Ethernet module and MQTT.
    The gateway immediately ran as desired.
    Unfortunately only for about 2 hours, then it freezes.
    After a restart it runs again 3 hours and freezes again.
    And so on.
    I wanted to replace an RPI Gatway, which has worked flawlessly for many weeks.
    If the Sensebender gateway works only a few hours it is quite useless.
    tbowmoT
    tbowmoT
    tbowmo
    @micropet
    It must be a software issue. Are you using it with nrf24? Do you have a github account? If you have, would you mind filling an issue report on the mysensors library? As we need to dig further into this. Please also make a note of how many nodes you have running in your system.
    • tbowmoT
      tbowmoT
      tbowmo
      @alexsh1
      I would really like to get it solved, so it can bring peace to my mind :) so please, if you can..
      alexsh1A 1 Reply Last reply
        micropet
        I also think that it is a software problem.
        I use only the RFM96HW.
        My "real" network has 20 nodes.
        The Sensebender gateway has only one DS18b20 node on a seperate frequency.
        (#define MY_RFM69_FREQUENCY (868200000ul))
        And yes, I have a github account and will make an issue report today.
        • tbowmoT tbowmo
          @alexsh1
          Did you try my suggestion about hacking the core? Or did you give up on the beast? :)
          I'm curious to hear if it is solved..
          alexsh1A
          alexsh1A
          alexsh1
          #250
          @tbowmo I think I am on the right track here. This is the log:
          0;255;3;0;9;TSF:LRT:OK
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSF:WUR:MS=0
          0;255;3;0;9;TSM:INIT:TSP OK
          0;255;3;0;9;TSM:INIT:GW MODE
          IP: 0.0.0.0
          0;255;3;0;9;MCO:BGN:STP
          The GW Init is correct one, but IP is 0.0.0.0
          This is the sketch:
          #define MY_RF24_CHANNEL    76
          #define MY_GATEWAY_W5100
          //#define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
          #define MY_SOFTSPI
          #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
          #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
          // Enable to UDP
          //#define MY_USE_UDP
          #define MY_IP_ADDRESS 10,1,1,150   // If this is disabled, DHCP is used to retrieve address
          #define MY_PORT 5003
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          #if defined(MY_USE_UDP)
          #include <EthernetUdp.h>
          #include <Ethernet.h>
          I cannot connect to W5100. Tried a different shield with the same result.
          • tbowmoT tbowmo
            @alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            @tbowmo BTW, I cannot ping it (I suppose there was another network device with the same IP on a network).
            If I try to switch to DHCP I get:
            DHCP FAILURE...0;255;3;0;9;!MCO:BGN:TSP FAIL
            • alexsh1A
              alexsh1A
              alexsh1
              #252
              @tbowmo I have received the second GW and I have exactly the same problem. As you suggested, I modified MyHwSAMD.cpp and can see now the start-up message, but there is a problem between the W5100 and GW:
              0;255;3;0;9;660 MCO:BGN:INIT GW,CP=RNNGS---,VER=2.2.0-beta
              0;255;3;0;9;707 TSF:LRT:OK
              0;255;3;0;9;717 TSM:INIT
              0;255;3;0;9;727 TSF:WUR:MS=0
              0;255;3;0;9;742 TSM:INIT:TSP OK
              0;255;3;0;9;752 TSM:INIT:GW MODE
              0;255;3;0;9;762 TSM:READY:ID=0,PAR=0,DIS=0
              0;255;3;0;9;772 MCO:REG:NOT NEEDED
              IP: 0.0.0.0
              0;255;3;0;9;2082 MCO:BGN:STP
              0;255;3;0;9;2092 MCO:BGN:INIT OK,TSP=1
              0;255;3;0;9;17920 TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:1956.28
              0;255;3;0;9;17931 TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:6080.20
              0;255;3;0;9;17942 TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:20.71
              0;255;3;0;9;17953 TSF:MSG:READ,11-11-0,s=1,c=1,t=37,pt=7,l=5,sg=0:13282.11
              I tried different MySensors (stable and dev) and checked solding.
              Now sure what to do now
              EDIT: This is my sketch:
               * Version 1.0 - Henrik EKblad
               * LED purposes:
              //#define MY_SIGNING_ATSHA204
              #define MY_SOFTSPI
              // Enable to UDP
              • tbowmoT
                tbowmoT
                tbowmo
                have you tried the ethernet webserver example sketch (default arduino sketch)?
                Just to rule out mysensors..
                Also, you are using static IP, right? What if you ping that IP address? Do you get a response? If yes, then the W5100 is configured by your sketch, and the connection should be ok between the samd and the ethernet module.
                alexsh1A 3 Replies Last reply
                • tbowmoT tbowmo
                  alexsh1A
                  alexsh1A
                  alexsh1
                  #254
                  @tbowmo ethernet wedserver sketch is giving me this:
                  server is at 0.0.0.0
                  EDIT: I can ping the IP and yes it is static.
                  • tbowmoT tbowmo
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @tbowmo Do you think softSPI is at fault? What pins shall I use? I tried these
                    #define MY_SOFTSPI
                    #define MY_SOFT_SPI_SCK_PIN 24 //13 //23  //14
                    #define MY_SOFT_SPI_MISO_PIN 22 //14 //22 //16
                    #define MY_SOFT_SPI_MOSI_PIN 23 //12 //21 //15
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @tbowmo I cannot ping it though if I load MySensors GW sketch -
                      Destination host unreachable.
                      • tbowmoT tbowmo
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @tbowmo I have just discovered that the second Ethernet module I have is not W5100 but ENC28J60. Not sure if it is supported by sensebender GW (probably using native Arduino ethernet library?).
                        So this module is now being returned and just to figure out any hardware issue I need to order a new W5100
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          You should not use soft spi, as there is separate hardware spi ports for radio and W5100.
                          If you load the default GatewayW5100 example sketch, then it should work out if the box. Perhaps you need to enable rfm69 instead of nrf24 at the top of the file, but that should be all that is needed.. To get a gateway up and running with W5100
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @alexsh1
                            OK, just to recap here, you have a gateway, and a W5100. If you use that combo, and the http server example, you can ping the gateway, and Load the html files in a browser, right?
                            If you load stock GatewayW5100 mysensors example sketch, then does that work? (no need to redefine pins for hardware etc, that is handled by the target hardware profile, you choose in arduino)
                            • tbowmoT tbowmo
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @tbowmo I must admit I have not tried to load files in the browser when trying Ethernet sketch. Only pinging
                              Yes, you are correct - gateway, nrf24l01+ and w5100
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @alexsh1
                                So gateway with nrf and W5100 is working as it should as an ethernet gateway? Then the W5100 is working with the gateway.
                                What is the hardware configuration that you can't get to work? Rfm69 and W5100? Together with the samd GW?
                                (just trying to figure out what is going on :))
                                • tbowmoT tbowmo
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @tbowmo No, sensebender GW is working with nrf24l01+ as a serial GW, but not with W5100 as ethernet GW.
                                  Interesting observation - I cannot ping the IP any more if I load the ethernet sketch. For your understanding the sensebender GW was never working with W5100 with either nrf or rfm69. Something going wrong around W5100.
                                  I'll hook up W5100 shield to Arduino nano to test it - I have a suspicion about it. However, even without W5100 connected, sensebender GW is showing IP as 0.0.0.0 (I set IP 10.1.1.150). Why?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    If the ethernet library can't initialize the W5100, it will just write IP address as 0.0.0.0.
                                    Can you please turn on verbose compile logging in arduino? (file -> Settings, set a checkmark at show verbose output during compilation, and choose "all" in Compiler warnings)
                                    I just want to make sure that it is using the correct ethernet library.
                                    • tbowmoT tbowmo
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @tbowmo I have verbose on already.
                                      I think you hit the nail on the head:
                                      "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-gcc"  "-LC:\Users\Alex\AppData\Local\Temp\arduino_build_753079" -Os -Wl,--gc-sections -save-temps  "-TC:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\variants\mysensors_gw/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.elf" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\sketch\GatewayW5100.ino.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\Dhcp.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\Dns.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\Ethernet.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\EthernetClient.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\EthernetServer.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\EthernetUdp.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\utility\socket.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\utility\w5100.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Wire\Wire.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\SPI\SPI.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\core\variant.cpp.o" -Wl,--start-group "-LC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/core\core.a" -Wl,--end-group
                                      "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary  "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.elf" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.bin"
                                      "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom  "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.elf" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.hex"
                                      Multiple libraries were found for "Ethernet.h"
                                       Used: C:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\libraries\Ethernet
                                       Not used: C:\Program Files (x86)\Arduino\libraries\Ethernet
                                      Using library Ethernet at version 1.1.2 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\libraries\Ethernet
                                      Using library MySensors at version 2.2.0-beta in folder: C:\Users\Alex\Documents\Arduino\libraries\MySensors
                                      Using library Wire at version 1.0 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire
                                      Using library SPI at version 1.0 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\SPI
                                      Sketch uses 45512 bytes (17%) of program storage space. Maximum is 262144 bytes.```
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        It is using "our" ethernet driver, which it should be.. The default arduino ethernet driver is hardwired to SERCOM0 for SPI, while we have it on SERCOM1.
                                        I'll try to bring up one of my own gateways with W5100 later today.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @alexsh1
                                          Below is the startup log from my Gateway with W5100 and RFM69 attached:
                                          0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGS--,VER=2.2.0-beta
                                          IP: 192.168.1.66
                                          As seen, the W5100 is initialized with ip address,
                                          Telnet to the Gateway is also working:
                                          thomas at thomas-ThinkPad-L450 in ~
                                          >telnet 192.168.1.66 5003
                                          Trying 192.168.1.66...
                                          Connected to 192.168.1.66.
                                          Escape character is '^]'.
                                          200;255;4;0;0;FFFFFFFFFFFFFFFF0300
                                          200;255;0;0;17;2.2.0-beta
                                          200;255;3;0;6;0
                                          200;255;3;0;11;Sensebender Micro
                                          200;255;3;0;12;1.4
                                          200;1;0;0;6;
                                          200;2;0;0;7;
                                          200;1;1;0;0;23.3
                                          200;2;1;0;1;46
                                          200;255;3;0;0;81
                                          The above is with the stock example sketch from mysensors (right now latest development branch though). The only things I changed, was to enable RFM69, instead of NRF24, and set a different IP address, to match my network settings.
                                          Everything else is running as is, delivered from the mysensors examples..
