  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 255.8k Views 53 Watching
  • 8
    I am looking for Gateway that will get me the results to MQTT but will support encryption + signing. That mean it should be easy to add new signatures (recompile/reflash) the module
    I suppose if I use Sensebender with LAN module it will be a pain to do that
    Is this doable if I use Orange zero as USB host for the Sensbender and let it act as serial gateway, then convert serial to mqtt with software on the Linux side? Also is it possible to reflash it easily this way? I do not want to rewire the hardware each time a add new node.
    • tbowmoT
      tbowmoT
      tbowmo
      @8667
      Is it over the air encryption / signing that you are aiming after? Then that is possible with the gateway, it has the ATSHA204 onboard for signing capabilities. And it also works with the W5100 module attached. The Gateway have 256Kb of flash onboard, so it has "enough" room for both network stack, and signing.
      • rzyliusR
        rzyliusR
        rzylius
        Are there performance limitations to be considered for mysensors and SensebenderGW specifically. Will the gateway handle the load of signed communications if rules will be firing messages to different sensors like 1-2-5-10 per second?
        AnticimexA 1 Reply Last reply
        • rzyliusR rzylius
          AnticimexA
          AnticimexA
          Anticimex
          @rzylius if you use the atsha204a chip, it is the single wire interface that limits your throughput. I have no figures, so best is to just test how fast you can push messages through. Of course there is overhead in the OTA handshaking as well. That would probably be the bottleneck if you use software based signing.
          • rzyliusR
            rzyliusR
            rzylius
            I see in logs, that the whole process of signing and communicating to the node takes a bit more than one second. I do not know how to make a stress test properly, so I hoped that somebody else did it :) my question is if gateway will handle load by putting messages in some pipeline, or I should try to make sure that messages are fired with some spaces.
            • rzyliusR rzylius
              AnticimexA
              AnticimexA
              Anticimex
              @rzylius The signing process is blocking, so it should not accept messages if a signed message exchange is in progress. But I have not tested that extensively with "aggressive" controllers.
              • Mitja BlazinsekM
                Mitja BlazinsekM
                Mitja Blazinsek
                im trying to program in arduino ide, installed board... bu when compiling it write mi an error 'The current selected board needs the core 'arduino:arduino' that is not installed.'
                • Mitja BlazinsekM Mitja Blazinsek
                  #348
                  @mitja-blazinsek You'll need to install the Arduino SAMD board as well. I have just now updated the readme.
                  • D
                    D
                    dklinkman
                    wrote on last edited by dklinkman
                    #349
                    Just got my Sensebender GW and soldered it up. Adapted the serial sketch to Ethernet and it almost worked. Found some posts on this topic that helped me locate and fix my config error. Now all is well. Thanks! --edit-- added photo
                    -d
                    • D
                      D
                      dklinkman
                      #350
                      @dklinkman said in 💬 Sensebender Gateway:
                      Sensebender
                      And I got a Sensebender Micro soldered up and running also!! Just temp and humid so far. Too cool
                      --edit-- picture
                      • SoloamS
                        SoloamS
                        Soloam
                        This post is deleted!
                        • 8
                          Is it possible to use the sensebender board as MQTT gateway? Not Ethernet?
                          • SoloamS
                            SoloamS
                            Soloam
                            Yes it is! I use I'm using it as a MQTT gateway for some time
                            • C
                              C
                              Christian Schulte genannt Trux
                              First: Great work! My GW is working very well!
                              I wanted to know for what I can use the SD-Card.
                              My idea is to fetch the logs in the serial and write them to the SD-Card.
                              But I don't know where. Is there a point in the mySensors core where I can fetch all logs?
                              • R
                                R
                                rolandow
                                Forgive me if this isn't the right place to ask; but as a beginner, where do I start? How can I order this thing, or any other stuff from OpenHardware.io ? I see so many design files, I'm not sure what to do with them. Soldering the thing I can probably manage, but is there a guide available how to order the PCB, and maybe the parts as well?
                                alexsh1A 1 Reply Last reply
                                • R rolandow
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @rolandow said in 💬 Sensebender Gateway:
                                  Sesnebender GW can be ordered from Itead:
                                  https://www.itead.cc/mysensors-gateway.html
                                  Other openhardware.io projects maybe ordered either (1) directly from a link; pcb only (2) you can download eagle files and upload them to pcb manufactures like oshpark.com (3) you can purchase the final product. So a generic answer to your question is it depends :)
                                  I do not think there is a guide here, but if you go to oshpark.com there is a guide how to order a pcb. Parts (BOM) can be ordered from Aliexpress, eBay or more reputable supplies like digi-key or mouser
                                  • G
                                    G
                                    Gerator
                                    Hi!
                                    I'm trying to use sensebender GW as ethernet gateway. I loaded the stock W5100 sketch compiled with samd 1.6.21 defs but it didn't worked. I have been trying out different things and realized that it works with 1.6.12 defs. Now it's working but I'm stuck with an old version. Anyone with the same problem? Maybe I'm missing something?
                                    Also I found out ethernet library in 1.0.5 defs is outdated. I have been trying to use stock one (v2.0) without success. Anyone has tried?
                                    Thanks.
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      hi
                                      when i try compile sketch only with change radio to rfm69hw i have this:
                                      Arduino:1.8.9 (Windows 10), Płytka:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
                                      SensebenderGatewaySerial:95:26: error: 'LED_BLUE' was not declared in this scope
                                      static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
                                      SensebenderGatewaySerial:95:36: error: 'LED_RED' was not declared in this scope
                                      SensebenderGatewaySerial:95:45: error: 'LED_GREEN' was not declared in this scope
                                      SensebenderGatewaySerial:95:56: error: 'LED_YELLOW' was not declared in this scope
                                      SensebenderGatewaySerial:95:68: error: 'LED_ORANGE' was not declared in this scope
                                      C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'void preHwInit()':
                                      SensebenderGatewaySerial:116:10: error: 'MY_SWC1' was not declared in this scope
                                      pinMode(MY_SWC1, INPUT_PULLUP);
                                      SensebenderGatewaySerial:117:10: error: 'MY_SWC2' was not declared in this scope
                                      pinMode(MY_SWC2, INPUT_PULLUP);
                                      SensebenderGatewaySerial:130:17: error: 'LED_BLUE' was not declared in this scope
                                      digitalWrite(LED_BLUE, led_state);
                                      SensebenderGatewaySerial:145:16: error: 'LED_GREEN' was not declared in this scope
                                      digitalWrite(LED_GREEN, HIGH);
                                      SensebenderGatewaySerial:149:16: error: 'LED_YELLOW' was not declared in this scope
                                      digitalWrite(LED_YELLOW, HIGH);
                                      SensebenderGatewaySerial:154:16: error: 'LED_ORANGE' was not declared in this scope
                                      digitalWrite(LED_ORANGE, HIGH);
                                      SensebenderGatewaySerial:167:17: error: 'LED_RED' was not declared in this scope
                                      digitalWrite(LED_RED, HIGH);
                                      C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testSDCard()':
                                      SensebenderGatewaySerial:219:33: error: 'MY_SDCARD_CS' was not declared in this scope
                                      if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
                                      C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testEEProm()':
                                      SensebenderGatewaySerial:249:2: error: 'SerialUSB' was not declared in this scope
                                      SerialUSB.print(" -> EEPROM ");
                                      C:\Users\Piotrek\Desktop\SensebenderGatewaySerial-sketch\SensebenderGatewaySerial\SensebenderGatewaySerial.ino: In function 'bool testAnalog()':
                                      SensebenderGatewaySerial:267:30: error: 'MY_BAT_DETECT' was not declared in this scope
                                      int bat_detect = analogRead(MY_BAT_DETECT);
                                      exit status 1
                                      What is error ? please help me
                                      magpernM 1 Reply Last reply
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        I also can not install board in Arduino IDE 1.8.9
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          please help
                                          https://forum.mysensors.org/topic/10548/solved-sensbender-gateway-gives-a-lot-of-hu/2
