  3. Relay node delays
Relay node delays
1 Posts 1 Posters 785 Views 1 Watching
  • afulkiA
    afulkiA
    afulki
    I have a serial gateway (Arduino Uno) and two sensor nodes (Arduino Nano 5v), one reporting temperature (working great) and one with a relay board and 4 relays attached, while the board is working I'm seeing delays of 2s to 3os before the relay is activated.
    On the serial monitor attached to the relay control nano , I see the incoming message almost immediately, but not the ack (or what I assume is the ack as I'm new to this).
    Incoming change for sensor:2, New status: 0
    read: 1-1-0 s=0,c=1,t=0,pt=7,l=5,sg=0:17.9
    read: 0-0-2 s=3,c=1,t=2,pt=0,l=1,sg=0:1
    send: 2-2-0-0 s=3,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
    Sometimes I see the read, but no ack and no change on the relay control pin:
    Incoming change for sensor:3, New status: 1
    read: 1-1-0 s=0,c=1,t=0,pt=7,l=5,sg=0:18.0
    Any help would be appreciated.
