  3. Repeater node
Repeater node
3 Posts 3 Posters 1.7k Views 3 Watching
    moskovskiy82
    I have read through the api and it's still a little bit unclear on the repeater mode. No sleeping.... Does it mean if i want to have a repeater node i need to modify the sketches and remove the sleep functions? For example in humidity node - completely remove the
    gw.sleep(SLEEP_TIME); //sleep a bit
    • sundberg84S
      Thats true! You cant sleep a repeater because it puts the radio to sleep.
      You need to keep it alive all the time so it doesnt miss any messages.
      The downside is that if you dont sleep the node you need a good Power supply,
        If you still want the delay you can use gw.wait instead. That will process incoming radio messages.
