  3. ST=FAIL?!
ST=FAIL?!
6 Posts 3 Posters 1.9k Views 1 Watching
  • M Offline
    M Offline
    moskovskiy82
    Compiled the humidity sketch. Looking at the output of serial monitor i see messages as
    send: 11-11-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=fail:53.1
    H: 53.10
    So everything seems working except the string st=fail:53.1
    As i understood from the API - it's the submessage type which gives the fail? What might have went wrong?
    M 1 Reply Last reply
    • S Offline
      Hi @moskovskiy82!
      st=fail" means the receiving node or gateway has problems sending ack back to the sending node.
      Try adding a capacitor to the receiving radio, change powersource, move reciever/sender closer to eachother or build a repeater.
      • M moskovskiy82
        H: 53.10
        M Offline
        M Offline
        moskovskiy82
        The only thing i have changed from the stock sketch is this as i'm using openhab and wifi mqtt client gateway
        gw.begin(NULL,11,true);
        S 1 Reply Last reply
        • M moskovskiy82
          @moskovskiy82
          It has probably nothing with the sketch to do - its hardware (Range/Power issues).
          If you think its a software issue, try clearing the eeprom http://www.mysensors.org/build/debug#clearing-eeprom and reupload your sketch.
          • E Offline
            E Offline
            ericvdb
            You know that your node is also acting as a repeater? If that's not what you want, you need to do
            gw.begin(NULL,11,false);
            • M Offline
              M Offline
              moskovskiy82
              i Know it's in repeater mode.
              I couldn't find any downsides in turning it on except that the sleep function had to be disabled. It still acts as a sensor node
              12.2k
