  3. RGB Servo spot
RGB Servo spot
2 Posts 2 Posters 1.6k Views 3 Watching
  • siklosiS
    siklosiS
    siklosi
    This is little project I made while ago but just now converted it to mysensors (used to be controlled via bluetooth)
    2_1454273523371_image1 (4).JPG 1_1454273523371_image2.PNG 0_1454273523370_image3 (1).JPG
    #include <Servo.h>
    #define RED_PIN 3
    #define GREEN_PIN 5
    #define BLUE_PIN 6
    #define SERVO_H 7
    #define SERVO_V 8
    #define NODE_ID 5
    #define SERVO_RGB 0
    #define SKETCH_NAME "SERVO RGB"
    #define SKETCH_VERSION "1.0.0"
    #define NODE_REPEAT false
    #define FIRE_EFFECT 22
    Servo myservo_h;
    Servo myservo_v;
    long RGB_values[3] = {0, 0, 0};
    float dimmer;
    //int r = 255;
    //int g = r - 80;
    //int b = 25;
    //int servh = 0;
    //int servv = 0;
    //MyMessage fireMsg(FIRE_EFFECT, V_LIGHT);
      pinMode(RED_PIN, OUTPUT);
      pinMode(GREEN_PIN, OUTPUT);
      pinMode(BLUE_PIN, OUTPUT);
      pinMode(SERVO_H, OUTPUT);
      pinMode(SERVO_V, OUTPUT);
      gw.begin(incomingMessage, NODE_ID, NODE_REPEAT);
      gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
      gw.present(SERVO_RGB, S_RGB_LIGHT, "Servo RGB", false);
      gw.present(SERVO_V, S_LIGHT, "Servo V", false);
      gw.present(SERVO_H, S_LIGHT, "Servo H", false);
      gw.request(SERVO_V, V_LIGHT);
      gw.request(SERVO_RGB, V_RGB);
      gw.process();
      if (message.type == V_RGB) {
        String hexstring = message.getString();
        long number = (long) strtol( &hexstring[0], NULL, 16);
        RGB_values[0] = number >> 16;
        RGB_values[1] = number >> 8 & 0xFF;
        RGB_values[2] = number & 0xFF;
      if (message.type == V_DIMMER) {
        if (message.sensor == SERVO_V) {
          myservo_v.attach(SERVO_V);
          myservo_v.write(map(message.getInt(), 0, 100, 72, 180));
          gw.wait(1000);
          myservo_v.detach();
        if (message.sensor == SERVO_H) {
          myservo_h.attach(SERVO_H);
          myservo_h.write(map(message.getInt(), 0, 100, 0, 180));
          gw.wait(1000);
          myservo_h.detach();
        if (message.sensor == SERVO_RGB) {
          dimmer = message.getInt();
          analogWrite(RED_PIN, int(RGB_values[0] * (dimmer / 100)));
          analogWrite(GREEN_PIN, int(RGB_values[1] * (dimmer / 100)));
          analogWrite(BLUE_PIN, int(RGB_values[2] * (dimmer / 100)));
          if (message.getInt() == 0) {
            digitalWrite(RED_PIN, 0);
            digitalWrite(GREEN_PIN, 0);
            digitalWrite(BLUE_PIN, 0);
          if (message.getInt() == 1) {
            myservo_h.write(0);
            gw.wait(1000);
            myservo_h.detach();
            myservo_v.write(180);
            gw.wait(1000);
            myservo_v.detach();
            myservo_h.write(0);
            gw.wait(1000);
            myservo_h.detach();
            gw.wait(1000);
            myservo_v.detach();
    • D
      D
      drock1985
      Very nice looking project. Do you have a list of the hardware you used and a schematic by any chance?
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
