  2. Announcements
  3. 2.0 Discussion: Units, sensor types and protocol
170 Posts 23 Posters 115.6k Views 7 Watching
  • A Offline
    A Offline
    Anticimex
    About security, I'm looking into that. I am working on a concept involving key exchange and signing using an external circuit.
    • L Offline
      L Offline
      lunarok
      Yes for security can be also a first presentation requiring a signing. Like what Puppet is doing, agents first present themself to the master, master is waiting for someone to accept a request, and after it gives the certificate to the client and then the client tell him verything about itself (facts in this view can be compared to the sketch and sensors presentation)
      But I don't know if it's easy with arduino this type of exchange.
      Other way can be a simple key we put in sketchs, and using the same on every of our home, and use it in the lib to encode the data.
      • A Offline
        A Offline
        Anticimex
        I am working on a security protocol, and have posted my take on things in the security thread. I will weigh in on this thread once I have verified my design, but so far, only two new message types should be needed, one to request security capabilities and once for capabilities and a nonce. I do not think software based security is a suitable solution due to memory constraints so I am going for a hardware based solution with a pre-shared key. I will publish more concrete examples once I have verified them.
        • L Offline
          L Offline
          lunarok
          Is there any move on the V2 ? Can we see the actual status and what it is going to look like ?
          Going to a V2 for the Jeedom controller, will like to see it coming with mySensors v2 changes.
          Precisly will like to have a status about :
          • reboot of node without needing a special bootloader (inside the lib will be the best)
          • sending libversion from presentation including for gateway (this is include for nodes, I don't know for gateway)
          • possible of sending V_type used during presentation, no need to wait to send data
          • possible of sending a short desc name for each sensors created (can be helpfull when you create many sensors with same type and the difference is not only the order)
          • possible to send the power source of node, I don't know inside battery or else. This will be very helpful with battery/plug or battery/solar source for exemple. So we can know how much the battery is full but also if the sensor is actually on battery.
          • getConfig to be used for any paramteres instead of units, like this the node can request parameters from the conrtoler (think about a global sketch for a switch that can talk to a relay node, by the controller side you set which node it's controling)
          Can we have a wiki page maybe with an actual status of where is the V2 ? And is there a dev version we can try ?
          hekH 1 Reply Last reply
          • L lunarok
            hekH Offline
            hekH Offline
            There has been some delays due to workload. But i hope to finish it eventually. :)
            Not sure it is possible to reboot an arduino without watchdog enabled (anyone knows any tricks?).
            Yep, possible to get version from gateway today.
            There will be a different setup.
            Good idea! I'll take that into consideration.
            Thats also a good idea. I'll have to think about how it could be incorporated.
            Config/settings will be a bit different as well.
            Hmm.. my github account (henrikekblad) will contain the source until I feel it's worth trying out by the community. But there is a part of it I'm waiting for a c++ guru at work helping out with (advanced c++ templating which is a bit over my level of c++ knowledge). Those will hopefully make callbacks (incoming messages) usage awesome.
            The plan is the gateway will be able to accept/push json objects instead of the semicolon separated parameters, Much depends on how memory demanding it becomes.
            A 1 Reply Last reply
              A Offline
              A Offline
              axillent
              can we avoid float?
              instead of float a multiplied integer can be used
              for example 34.6 C temperature can be presented as 346 (no dot)
              a single float operation increase HEX size significantly
              @hek what about idea we discussed to have a network with multiple gateways?
              what about adding support for the 2.0 for the nodes be able to have a different BASE address per each gateway?
              this way the future network will allows to have 255 sensors per EACH gateway, not per NETWORK
              sense and drive
              • A axillent
                can we avoid float?
                hekH Offline
                hekH Offline
                @axillent
                Yes, configurable base address would be handy if we choose to create an ESP-gateway. It is already supported today but you have to hard code it into MyConfig.h. Would be neat to have this configurable over WiFi.
                Using OTA transmitted floats is optional. I haven't looked so deeply on how/if this will be supported yet in the upcoming version.
                • T Offline
                  T Offline
                  tekka
                  Any plans for encryption?
                  • A Offline
                    A Offline
                    Anticimex
                    This post is deleted!
                    • D Offline
                      daulagari
                      what benefit is there from encryption vs signing in the MySensors case?
                      If you have a lock or door sensor do you want others to know when it is opened or closed?
                      Signing is quite expensive if you look at additional payload size, you need a big counter to prevent replay and a big MAC to prevent attacks. I think that when encrypting things you can do it with the same additional payload and maybe even a less.
                      • A Offline
                        A Offline
                        Anticimex
                        • D Offline
                          daulagari
                          Yes, signing, when properly done, is for sure a good begin.
                          How many bytes are you using for the truncated MAC and nonce?
                          The AES block size is 128 bytes, so 16 bytes so I do not see why that would not fit.
                          Encryption is already some kind of authentication is a sense that if you can successfully decode the message you can be sure that the other side knows the shared secret, just like in the cause of your SHA25-HMAC.
                          • D Offline
                            daulagari
                            Would be good to move the last five message into a separate thread...
                            • A Offline
                              A Offline
                              Anticimex
                              • A Offline
                                A Offline
                                Anticimex
                                • A Anticimex
                                  hekH Offline
                                  hekH Offline
                                  I'm afraid I can only fork a topic int two threads. Haven't found a way to move posts to another thread/topic.
                                  • A Offline
                                    A Offline
                                    Anticimex
                                    • T tekka
                                      A Offline
                                      A Offline
                                      Anticimex
                                      @tekka Please see the discussion on security.
                                      • L Offline
                                        L Offline
                                        lunarok
                                        A new wish. Possible to have the network gateway listening for nodes also on the ethernet network. Looking for ethernet nodes inside the electric panel. No RF, no security break :)
                                        • A Offline
                                          A Offline
                                          axillent
                                          A support for multi-gateway setup is needed. Currently it is required to hardcode radio-channel or base-address for different segments-different gateways
                                          sense and drive
